chuckitinbro 11 Report post Posted December 16, 2021 So i've driven my e61 for a year now with no spare on tyres that arent run flats. Figured i was pushing my luck. Found a pair of 19x8 aftermarket alloys with 235/35 on them for a bargain so i grabbed them but they are slightly to wide a diameter to fit in the wheel well even with all the trim removed. What do other people do since spare's seem to be hard to come by these days. Do i hunt for a 16" with a low enough profile to fit ? Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 16, 2021 I have an AA Plus membership, that's my spare wheel 😅 1 Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted December 16, 2021 I don't have runflats and to begin with I carried a battery powered pump and a can of miracle puncture fixing goop. But I was never really happy about relying on that, so I hunted down a spacesaver spare plus a jack and wheel brace. The spare rides in the boot with a couple of ratchet tiedowns holding it secure. Takes up a lot of room but I don't ever carry much in the coupe so no problem. Cheers... 1 Quote Share this post Link to post Share on other sites
Driftit 2230 Report post Posted December 16, 2021 Can of goop and an AA membership. Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted December 16, 2021 Tried Pickapart for a space saver? Just calculate the size to see if it will work. Also, if you get a flat with non run flats, you need to stop immediately. I shredded an $850 Michelin in 800m between noticing and stopping. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted December 16, 2021 If you do get a space saver also check the wheel bolts are suitable. Some cars run different or shorter bolts for the space saver. Quote Share this post Link to post Share on other sites
jon dee 500 Report post Posted December 17, 2021 4 hours ago, KwS said: If you do get a space saver also check the wheel bolts are suitable. Pretty sure I checked that when I bought the spacesaver... but... you know... paranoia So I went and had another look and yes, I can use the factory wheel bolts to attach the spare. Bolt length is also OK as the spare is a BMW factory item and when fitted the bolts have the same engagement in the hub as with a factory mag (as you might expect with a factory spare ) Wheel I bought is size 125/80-17 which is the BMW recommended size for the 335i Msport on factory 18" wheels and using factory recommended tyre sizes. Cheers... Quote Share this post Link to post Share on other sites
Mop 9 Report post Posted December 17, 2021 I bought the official space saver from a wrecker, came out of an e60. It fits in my e61 wheel well tightly with the carpet/trim modified slightly, or I understand you can buy different trim to suit (or just take the trim out). If it helps I can check the wheel size when I’m in the boot next? Quote Share this post Link to post Share on other sites
