Palazzo 533 Report post Posted June 9, 2022 Looking at the exhausts on this which look like a 90s Bighorn, is this poor running or the result of deleting the blue system? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 9, 2022 Prob never been cleaned. Deleting adblue would only turn it into a NZ spec vehicle Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted June 9, 2022 Just curious, never seen one with that level of soot around the exhaust. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 9, 2022 6 hours ago, Palazzo said: Looking at the exhausts on this which look like a 90s Bighorn, is this poor running or the result of deleting the blue system? That level of black soot is more likely to be poor running, worn turbo, clogged injectors, overdue oil changes, etc. Possibly jammed up EGR valve. My understanding is that the AdBlue system is to reduce levels of the NOx emissions, which are much smaller / finer particles than the soot, by a chemical reaction. So no AdBlue shouldn’t mean more soot, unless it’s not been done properly and now it’s not running right.. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted June 9, 2022 You only get soot deposits on the tailpipes of Diesels that have had the Cat's removed. Diesels with Cats = clean tailpipes. Quote Share this post Link to post Share on other sites
curryinahurry 39 Report post Posted June 10, 2022 Probably had a DPF delete. The DPF takes care of all the particulates... adblue only converts the NOx gases to CO2 and are not visible. Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3043 Report post Posted June 10, 2022 Did the E70 come with a DPF..? It might have in some markets, EU maybe hence the AdBlue which wasn’t required for NZs lax emission rules. All the more reason why people should not be allowed to muck about with emission control systems on cars. Really pisses me off, glad to see they are starting to pick up on this kind of dumbf**kery at WoF time now. 1 Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted June 10, 2022 All e70 diesels have DPF AFAIK, was a market option on the last of the e53s too 1 Quote Share this post Link to post Share on other sites
yekmekci 0 Report post Posted February 15, 2024 On 6/9/2022 at 9:23 AM, Gaz said: Prob never been cleaned. Deleting adblue would only turn it into a NZ spec vehicle looks like a faulty exhaust system. Quote Share this post Link to post Share on other sites
