M3AN 4183 Report post Posted November 5, 2017 1 hour ago, zero said: I don't want two different styled mirrors on the same car. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted November 6, 2017 Given the ABS and traction control lights are illuminated, is it more likely that the issue is with an ABS sensor on the rear (driven) axle? Quote Share this post Link to post Share on other sites
allan 295 Report post Posted November 6, 2017 Remove and check have seen these covered with metal like filings stuck to them Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 18, 2017 Hi team, new here but searched first so apologies if I missed a previous answer to this question. 1987 E30 325i, is the dash cluster dimable? Mine doesn't seem to light up at all so I'm guessing it's blown bulb(s) but thought I'd run it past the guru's first. Thanks in advance. Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted December 18, 2017 (edited) Hey @obi_wan Thanks for searching first, it's actually pretty tricky to search on this forum given the search engine ignores anything with three characters or less (you know, like basically every model and chassis number). If it's dimable, you'll have a wheel below and probably to the right of your steering wheel if memory serves, it'll look like this The bulbs are meant to last forever, and are specific to BMW, you'll need to go to a proper BMW parts dealer to get them, or order online, mostly smaller lamps but a couple of bigger ones too in the centre, it's usually the bigger ones that blow. Replacing is pretty straightforwards, and if your miles are getting on, and it hasn't been done yet, not a silly time to look at replacing the odometer gears while it's out. Edited December 19, 2017 by EUROLESS 1 Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 19, 2017 Hi @EUROLESS, wow thanks for that, hugely helpful. I had a decent look for a dimmer switch in that area so it sounds like the bulbs are toast. I'll take you up on the odometer gears advice and get those sorted at the same time. Really appreciate you help. Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted December 19, 2017 @obi_wan The only bitchy thing about the odo gears is there are a few types, and the only way to know the type you need is to remove it, because i didn't want to put it out and in more than i needed, or spend two weeks without my E30, I just bought both KM sets, the vendor was happy for me to return the set i didn't need for a refund. I got mine here If you're electrically apt, I'd recommend re-flowing any solders that look shady while you have it apart also, stitch in time and all that jazz. Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 19, 2017 Thanks again, I'll get some on order. I wouldn't call myself a master soldererer but I'll give it a go and report back once I've solidly balls'd it up. Thanks again for your input, glad I joined this forum :-) Quote Share this post Link to post Share on other sites
LemonHunter 583 Report post Posted December 19, 2017 Generally everyone super nice unless you break the three golden rules; Try avoid digging up ancient threads unless neccesary Try search first Don't refer to SMG as Manual Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 19, 2017 Consider them tattooed on the back of my hand Quote Share this post Link to post Share on other sites
OP6 27 Report post Posted December 19, 2017 Before you get too deep, try rotating the headlight switch. Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 19, 2017 @OP6 never would have thought of that, thanks for the suggestion, I’ll give it a go before I get the mallet and grinder out haha Quote Share this post Link to post Share on other sites
obi_wan 14 Report post Posted December 21, 2017 @OP6 we have a winner *round of applause* cheers for the suggestion! Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 26, 2017 Car battery... A couple of times recently Miss M's car hasn't started. Click... Nothing. Flat battery. No worries - charge it up and off we go. It's only a problem if left for a few days. I'll look at possible causes of drain over Christmas. Yesterday, while doing some work on another car, I put the Miss-M-mobile battery on charge. 3-4A for most of the day. And... This morning it was a no-go situation. Click - nothing. The little inspection window on top of the battery is showing black, suggesting it needs charging. I suspect it's a dead 'un, but before I splash out (let's face it -students don't have money for car batteries) I thought I'd check the wisdom hereabaouts. Green is good, black is charge, and white is replace. Are we just a step away from seeing the white? Or is the discharge I'd expected to investigate enough to kill the battery overnight? Quote Share this post Link to post Share on other sites
allan 295 Report post Posted December 26, 2017 Feel you need to find out is it the battery or do you have a current draw from some thing coursing the flat battery. .When you charged the battery do you load test it to see if it holds a charge and comes back before refitting it in the car. As you say green generally means all good black could mean flat need a charge or stuffed new battery.required bugger. By chance does it have a label on it or letters stamped on the terminals might help find out how old it is. Best of luck getting it sorted can be a right PITA at this time of year. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 26, 2017 29 minutes ago, allan said: Feel you need to find out is it the battery or do you have a current draw from some thing coursing the flat battery. .When you charged the battery do you load test it to see if it holds a charge and comes back before refitting it in the car. As you say green generally means all good black could mean flat need a charge or stuffed new battery.required bugger. By chance does it have a label on it or letters stamped on the terminals might help find out how old it is. Best of luck getting it sorted can be a right PITA at this time of year. I've taken the battery off the car to charge overnight - I'll do some more checks tomorrow. This one suggests three colours - green, black and white. White is "replace me!" There is an 'installed on' label, but none of the dates have been selected. It's not original, but could easily have been on the car for some time. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 26, 2017 2 hours ago, allan said: Feel you need to find out is it the battery or do you have a current draw from some thing coursing the flat battery. .When you charged the battery do you load test it to see if it holds a charge and comes back before refitting it in the car. As you say green generally means all good black could mean flat need a charge or stuffed new battery.required bugger. By chance does it have a label on it or letters stamped on the terminals might help find out how old it is. Best of luck getting it sorted can be a right PITA at this time of year. 1 hour ago, gjm said: I've taken the battery off the car to charge overnight - I'll do some more checks tomorrow. This one suggests three colours - green, black and white. White is "replace me!" There is an 'installed on' label, but none of the dates have been selected. It's not original, but could easily have been on the car for some time. I was basing my 'dead battery' theory on what appears to be an accelerated rate of battery discharge. Just to check, I removed the battery from the car, left it in the sun for several hours to remove any surface charge, then put it on charge. Less than an hour later, the charger suggests 'charge complete'. This after the battery wouldn't turn the engine over earlier today - solenoid click, dimming of instrument lights, nothing more. For reference, I've checked for: Broken terminal Bulge or bump in the case Crack, rupture or other damage to the plastic Leaking Discoloration All negative. I'll low-rate charge the battery for a while, leave it to stand, then get Miss M to help do a load test. (She can turn the key - I'll watch the multimeter!) Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted December 26, 2017 Hey Graham, this is from r/MechanicAdvice and has helped me in the past finding parasidic draws and weird battery issues. voltage drop testing in six easy steps 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 26, 2017 12 minutes ago, Gabe79 said: Hey Graham, this is from r/MechanicAdvice and has helped me in the past finding parasidic draws and weird battery issues. voltage drop testing in six easy steps The imgur link is interesting. "Now. start the engine." Well, that'd be nice! Actually (and while I haven't tried today) the car will start when the battery has just been charged, and the other measurements could be very useful. It's an odd situation. I've had batteries die before, but not quite like this. Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted December 27, 2017 Replacing transmission fluid on my 530i. I read all kinds of recommendations for the US, but what is good to use here? I'm a fan of SCA. Is this good enough? Castrol Auto Transmission Fluid - Dex III http://www.supercheapauto.co.nz/Product/Castrol-Auto-Transmission-Fluid-Dex-III-4-Litre/309868 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted December 27, 2017 Oh well... An unloaded and disconnected 10.65V across the posts, hours after showing full charge, tells us everything we need to know. Anyone got a cheap, working battery available? Quote Share this post Link to post Share on other sites
Eagle 1784 Report post Posted December 27, 2017 13 minutes ago, Gabe79 said: Replacing transmission fluid on my 530i. I read all kinds of recommendations for the US, but what is good to use here? I'm a fan of SCA. Depends on your exact transmission but i definitely would not use that (not full synth for starters). Valvoline MaxLife ATF fairly cheap and commonly used overseas (transmission dependent) Ive always used the specified Fuchs from BNT for all transmissions ive ever done. Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted December 27, 2017 (edited) 12 minutes ago, Eagle said: Depends on your exact transmission but i definitely would not use that (not full synth for starters). Valvoline MaxLife ATF fairly cheap and commonly used overseas (transmission dependent) Ive always used the specified Fuchs from BNT for all transmissions ive ever done. Sorry, I even had this open and forgot to add to the post... I have a A5S 325Z/ZH 5HP19 on my car. EDIT: Reading the BMW fluid document, looks like this is a better bet: http://www.supercheapauto.co.nz/Product/Penrite-Automatic-Transmission-Fluid-FS-1-Litre/396371 Penrite ATF Full Synthetic (although the Semi-Synthetic also meets the spec) BMW Trans Oil Chart.pdf Edited December 27, 2017 by Gabe79 Quote Share this post Link to post Share on other sites
Eagle 1784 Report post Posted December 27, 2017 Yep plenty of oils that say they meet the spec. ZF lifeguard is probably the proper choice but not cheap. I'll probably use full synth Maxlife for mine soon but that mainly because i got a lot of it Any of the good brands should have it in 20L containers which are much cheaper for the $. I don't know what method you are using for the oil change though, Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted December 27, 2017 1 hour ago, Eagle said: Yep plenty of oils that say they meet the spec. ZF lifeguard is probably the proper choice but not cheap. I'll probably use full synth Maxlife for mine soon but that mainly because i got a lot of it Any of the good brands should have it in 20L containers which are much cheaper for the $. I don't know what method you are using for the oil change though, I quite like Penrite, I use HPR5 for my engine. I might just go with them. I might check out BNT tomorrow if they have larger quantities than 1L though. Quote Share this post Link to post Share on other sites
