Guest Andrew Report post Posted December 5, 2006 (edited) A new sticky thread. Post up your engine power/torque [measured at the wheels] and 1/4 mile times. Must be accompanied with Dyno graph and drag slip times. Please convert to kW and trap times to kph List will constantly be updated. Right now i'm just going off the top of my head on some powers so we will correct the list as it gets updated by members. Darren [sR20DET] - E30/240 kW (?) 1/4 ET: (?) Glenn [E30323Ti] - E30/2JZ-GTE - 218 kW (?) 1/4 ET: (?) Riley-{drifty340}-E30/1UZFE V8 -208kw 1/4 ET (?) Andrew - E30/M42 Turbo - 190 kW (?) 1/4 ET: 13.99 (with car problems and much less power) Atta [CrazyArab] E36/S50B30 - 172.3 kW 1/4 ET: (?) Cain [cainchapman] E34/m60 4.0 - 172 kW 1/4 ET: 14.78 Andrew - E30/m20 2.5 - 138 kW 1/4 ET: (?) Graham [bravo] - e30 m20b25 SC - 134kw 1/4 ET: (?) Tim [bumpstop325] E30/m30 3.5 - 133 kW 1/4 ET: (?) Gus - E30/m20 2.5 - 111 kW 1/4 ET: (?) 2002 - 2002/m10 2.0 - 72 kW 1/4 ET: (?) Edited April 7, 2012 by hybrid Quote Share this post Link to post Share on other sites
2002 1 Report post Posted December 5, 2006 I might be in the running for the lowest power, don't know 1/4 mile times - drag racing is for people who can't turn corners Engine is stock 2L M10 with E30 318 fuel injection & Link (Go faster bits on order) Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted December 5, 2006 Is that ATW ? I hope ill be putting out around 260hp atw Quote Share this post Link to post Share on other sites
Guest Spargo Report post Posted December 6, 2006 Can this version of invision utilise the garage function within your user profile? If so, drew could you impliment it, and have everyone on the list put their info there with a link to it in the stickied post. ie: info there could include dyno plots, mod lists, a description of the car? Quote Share this post Link to post Share on other sites
OLLIE 27 Report post Posted December 6, 2006 Can this version of invision utilise the garage function within your user profile? If so, drew could you impliment it, and have everyone on the list put their info there with a link to it in the stickied post. ie: info there could include dyno plots, mod lists, a description of the car? it's ideas like this that i like, all that stuff is in the working sam, thanks for your comment. Quote Share this post Link to post Share on other sites
bumpstop325 0 Report post Posted December 6, 2006 No Power Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 6, 2006 dead stock 535,M30 139 kw at rear wheels measured with the dyno that actually bolts to the hubs.....I have an excel version of the plot at home Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted December 6, 2006 dead stock 535,M30 139 kw at rear wheels measured with the dyno that actually bolts to the hubs.....I have an excel version of the plot at home Does the dyno sheet say SAE corrected? Quote Share this post Link to post Share on other sites
Carl 3 Report post Posted December 6, 2006 Does the dyno sheet say SAE corrected?Yes they're SAE correctedDynapak Quote Share this post Link to post Share on other sites
martyyn 2 Report post Posted December 6, 2006 263bhp at the rear wheels...also on the Dynapak Thats about 196kw isnt it (multiply bhp by .7457) ? Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted December 6, 2006 263bhp at the rear wheels...also on the Dynapak Thats about 196kw isnt it (multiply bhp by .7457) ? Thats about what im budgeting for on my conversion Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted December 6, 2006 Yes they're SAE corrected Dynapak That means they are an attempt at flywheel hp - so they do not mean anything in terms of rwhp. Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted December 6, 2006 172kW and 14.78sec for the 1/4 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted December 6, 2006 so the figure we got at Petone arent actual rwhp?They are some corrected figure thats massaged to figure power loss through the g/box and diff? Quote Share this post Link to post Share on other sites
BM WORLD 1299 Report post Posted December 6, 2006 done 15.37 . 88 535i with hartge head etc . maybe around 220hp flywheel on a good day . stock should be 211hp . this motor had stuffed rings etc . Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted December 6, 2006 From Tech talk regarding Horsepower correction. http://www.land-and-sea.com/dyno-tech-talk...-horsepower.htm Quote Share this post Link to post Share on other sites
Guest Andrew Report post Posted December 6, 2006 so the figure we got at Petone arent actual rwhp?They are some corrected figure thats massaged to figure power loss through the g/box and diff? Essentially yes - For e.g Martyn claims 197 rwkw - which is WAY more than an m3 puts out at the rear wheels. It would be more like 165 kW at the wheels for a 740 auto Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted March 31, 2007 hey whats the figure to change kw to hp?? apparenty my m3 is 210kw at the engine so whats that in hp and also what percentage is lost theough the drive train ?? Quote Share this post Link to post Share on other sites
cainchapman 0 Report post Posted March 31, 2007 (edited) hp = kw/.75 So yours is around 300hp at the flywheel. Drivetrain loss anwhere between 15 and 30%. Edited March 31, 2007 by Cain Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted April 1, 2007 So if you read through all the drivell the key is the DIN standard is reliable, SAE has had so many changes and is based on "non true" values e.g. not real pressure so forget the outmoded imperial crap and get with the metric program that has been in place for 50 years. and based on units establised by scientests over 150 years ago. Phyiscs does not lie. Fly wheel power is only of value to engine builders Rear wheel power is relevant to a specific car/ drive line For the list 135.1 kW at the wheels M52 B28 in a 95 328 AGREEDS - lets not see any SAE estimated HP values. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted April 1, 2007 (edited) has anyone on here heard of a turbo kit for the s50 engine in a right hand drive m3???? im thinking of shelling out for a supercharger kit from active autowerk but only because of a lack of room for a turbo with the steering rack so close to the exhuast manifold and all. id like over 400 ponies and im told the standard bottom end on my engine is plenty strong enough. Edited July 19, 2007 by btccm3 Quote Share this post Link to post Share on other sites
conrod 1 Report post Posted April 1, 2007 Active Autowerk do a RHD M3 turbo kit from memory, the guy from AA even posted on here a a year or so ago with the relevant info.Not cheap, but quality never is! cheers Conrad Quote Share this post Link to post Share on other sites
Guest Denny Crane Report post Posted April 1, 2007 has anyone on here heard of a turbo kit for the m50 engine in a right hand drive m3???? im thinking of shelling out for a supercharger kit from active autowerk but only because of a lack of room for a turbo with the steering rack so close to the exhuast manifold and all. id like over 400 ponies and im told the standard bottom end on my engine is plenty strong enough. RHD M3's still have the S50, son. Bore spacing and head port gap is the same for S50 / M50 though. Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted April 4, 2007 RHD M3's still have the S50, son. Bore spacing and head port gap is the same for S50 / M50 though. i stand corrrected right you are Quote Share this post Link to post Share on other sites
btccm3 1 Report post Posted April 5, 2007 i did see a right hand drive kit on active but it only said it would fit a 325 or 328 correct me if im wrong but are these not "M" blocks, if the port spacing is the same on the m50 block to the s50 like mine, would i be correct in thinking it would fit my s50 engine aswell. maybe i should just buy the supercharger!?!? Quote Share this post Link to post Share on other sites
