bravo 35 Report post Posted March 19, 2009 Update: Day 5 & 6 I had some time up my sleeve whilst waiting for parts and a couple of other things, so I decided to modify my factory SA sump guard. It is now SA sump guard LW fuh raze v1.0: And as some of you may know I shaved several litres and 7odd kg off my sub box install by making it 300mm shorter so it didn't take up the entire width of the boot. Obviously this meant a fair bit of redesign and reporting, but the final result is as follows: Then my parts etc arrived, so I could get down to business. So new motor now out of the van, flywheel and clutch installed, gearbox fluids replaced, rear gearbox seal and selector shaft seal replaced, diff fluid changed, box ready to go onto motor: Plus a few pics of the exciting bits for those interested: So motor will go into the car tomorrow night or Saturday (I'm going to a funeral tomorrow so depends on how much we drink at the wake whether I'm in a fit state to use heavy machinery). Once it's in the real work starts cutting holes for the IC piping and making it all work. Stay tuned! Oh, and I know you're all dying to know.... Current beer count: 33 Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted March 19, 2009 TUI!!! Great reading mate. Super charging my car is one my wish list atm too, so it'll be great to see how this goes down. Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted March 19, 2009 Awesome its coming along well mate Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted March 19, 2009 Ewww, you drunk an Export Gold! Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 19, 2009 Haha I got given a 15pack for a favour - I intersperse them now and again. it's been 3 weeks and I have 8 to go. The Tuis were also for services rendered, but I don't mind them so much. Summit was on special (plus its pretty good), and Heineken, Grolsch, Stella and Becks are my usuals. Credit crunch plus car bills = cheaper beer for now. BTW the unlabelled bottle was a macs gold I found in the cow water trough a couple of days ago. Must have been there since the last paddock racing. Cap wasn't rusted, and tasted fine - score! Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 19, 2009 Are you running the throttle body before the SC like the original toyota setup?? Increasing the size of it?? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 19, 2009 No. Filter, AFM, BOV return, S/C, IC, BOV, TB Stock TB, larger injectors from m30, m30 AFM. At this stage anywya. Will be tweaking it once it's running eventually running link or similar. Running RRFPR, and remapped ecu. Quote Share this post Link to post Share on other sites
E30-323ti 66 Report post Posted March 19, 2009 bravo said: No. Filter, AFM, BOV return, S/C, IC, BOV, TB Stock TB, larger injectors from m30, m30 AFM. At this stage anywya. Will be tweaking it once it's running eventually running link or similar. Running RRFPR, and remapped ecu. Is it a pretty big BOV / recirculation Valve?? I'm sure you can imagine how much it has to flow when the throttle shuts @6000rpm. Not to mention if the SC is still drawing & compressing air at a greater rate than the BOV can recirculate it, ie. flow through the AFM = lots of fuel, not much air into the engine. This is why the toyota's run the TB before the SC and provide an idle bypass (when the SC is switched off) and not a BO/Recirc Valve, and MAP sensors not AFM's. Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted March 19, 2009 Looking good dude. 85 beers Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 19, 2009 E30-323ti said: Is it a pretty big BOV / recirculation Valve?? I'm sure you can imagine how much it has to flow when the throttle shuts @6000rpm. Not to mention if the SC is still drawing & compressing air at a greater rate than the BOV can recirculate it, ie. flow through the AFM = lots of fuel, not much air into the engine. This is why the toyota's run the TB before the SC and provide an idle bypass (when the SC is switched off) and not a BO/Recirc Valve, and MAP sensors not AFM's. SC shouldn't be drawing too much at closed throttle. But I totally see where you are coming from. Not sure if you know, but this was a working setup in another car. My theory is that I should be able to get it working in my car for fairly limited cost, and then spend the money in the right places to improve it. From what I know on the subject, and what I know about this system, there are some minor tuning issues. Whether I can resolve these and leave the TB as it is is yet to be decided. The BOV is fairly large, and has a fairly large (IMO) return line. Thanks for your comments - definitely food for thought. Quote Share this post Link to post Share on other sites
QuickSilver 0 Report post Posted March 19, 2009 (edited) Lookin good Graham. Curious about the pulley system, is it a custom front pulley? Or was there a fit from a m50 or something that bolted straight on? Whats the story there? Edit: What is the tensioner mounted to? Edited March 19, 2009 by QuickSilver Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 19, 2009 (edited) Custom front pulley. The powersteer pump is now a few mm further forward - just shimmed up the powersteer pump mounting bolts so it's still inline. Tensioner mounted to custom SC bracket and is adjustable (obviously). Edited March 19, 2009 by bravo Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted March 20, 2009 wow, that looks like a LOT of work. Should be awesome. I think a beer thread is needed! Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted March 20, 2009 André3000 said: TUI!!! Surely that weasel piss can't add to the beer count? Quote Share this post Link to post Share on other sites
Boost Junky 1 Report post Posted March 20, 2009 Atleast its not Double Brown or Lion Red Quote Share this post Link to post Share on other sites
Andrew 30 Report post Posted March 20, 2009 I don't care about the car. That was a seriously solid dragon! But seriously badass work. 103 beers. Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 20, 2009 (edited) Day 7 BMW Special Tool BMW3025 - home made thin-walled 30mm socket for removing flanged nut on gearbox output flange. Thanks to Glenn for showing me his so I could copy. Its a cheaper impact driver that I shaved down. I managed to fit the oil cooler filter housing from my old motor - had to bend one of the pipes a wee bit to clear the SC, but they perfectly miss the SC piping! Great Success! And finally - in! Lots to do, but its in its final resting place = win! Will do more tomorrow. Beer Count = 39 Edited March 20, 2009 by bravo Quote Share this post Link to post Share on other sites
bmw_guy 0 Report post Posted March 20, 2009 Im loving your car and how its coming along Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted March 20, 2009 Looking good Graham Quote Share this post Link to post Share on other sites
drifty325i 0 Report post Posted March 20, 2009 Looks dam near factory! Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 21, 2009 Nice work dude! What PSI wheel are you running again ? Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 21, 2009 0.4 bar aka 6PSI Quote Share this post Link to post Share on other sites
bravo 35 Report post Posted March 21, 2009 Day 8 Busy day mocking up and test fitting everything. Of course everytime I moved something somethign else wouldn't fit. I finally got the IC lines sorted, but then couldn't fit the oil cooler anywhere without it being a hazard for hitting the ground (bad since it contains the life-blood of the engine). So I got the sump guard to fit (a bit of hammer modification to get it to fit past the SC), and then flipped the oil cooler upside down and reversed the flow direction (swapped lines around) so hot end was still up, and voila! Anyway, here are pics of the finished mockup - will bolt in place tomorrow and start rewiring and fitting everything else. Still lots of little finishing off to do aswell - rust protecting areas of bare metal, etc. Somehow I missed pics of the hot side of the IC piping and AFM. Will post tomorrow. Beer Count= 48 Quote Share this post Link to post Share on other sites
Guest Ari Gold Report post Posted March 21, 2009 Yea yea! Quote Share this post Link to post Share on other sites
Grant 4 Report post Posted March 21, 2009 Looking really great, love your work!! Quote Share this post Link to post Share on other sites
