westy 614 Report post Posted March 12, 2012 Spose I should really read the auctions a bit more closely. Quote Share this post Link to post Share on other sites
tcbaurpower 5 Report post Posted March 12, 2012 (edited) I tried that link on the auction but it went no where. Would be good to see how they welded it in regard to your plinth vs plate options. westy said: Was an auction for a prebent and cut cage. It mentioned plates, but nothing more. I meant the link on the auction for the cut cage. My bad it did mention plates.. haha who thought reading an auction can be so hard. "TO GET AN IDEA OF HOW THE KIT LOOKS WHEN INSTALLED, PLEASE FOLLOW THIS LINK AND LOOK AT DRAWING NO. 253-4 ON PAGE 49 http://motorsport.org.nz/assets/MotorSport...-2010.pdf" Cant read that pdf. Edited March 13, 2012 by tcbaurpower Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted March 12, 2012 Also I think you may need to make them out of something sturdier than cardboard . As for welding the top of the cage, mine we dropped the front bars through the floor and managed to do the whole top pretty well using that... can't remember if we dropped the main bar too, but I don't think so. The holes are well and truly covered by the 3mm steel plates. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 12, 2012 tcbaurpower said: I tried that link on the auction but it went no where. Would be good to see how they welded it in regard to your plinth vs plate options. Was an auction for a prebent and cut cage. It mentioned plates, but nothing more. huff3r said: Also I think you may need to make them out of something sturdier than cardboard . As for welding the top of the cage, mine we dropped the front bars through the floor and managed to do the whole top pretty well using that... can't remember if we dropped the main bar too, but I don't think so. The holes are well and truly covered by the 3mm steel plates. MDF ya muppet! Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted March 17, 2012 westy said: MDF ya muppet! Oh right, sorry my mistake, carry on.... that should do fine. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 18, 2012 Started it today. Runs for about 10 secs then dies, catches, die, catches. Wont respond to throttle. Meh. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted March 18, 2012 So little progress then. Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted March 18, 2012 In all seriousness, is it an M52tu or 54? M52tu has the electronic throttle body with back up mechanical cable, M54 is soley electronic. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 18, 2012 M52tu Greg. How do you mean backup cable? Was under the impression it was solely cable operated? Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 19, 2012 Things I now know. Both intake boots have small splits in them. Disa valve is intact. Gotta win somethings. Idle Control Valve was nice and stuck. Cleaned and freed. Throttle body hmmm... Was stuck shut. Cable wasn't moving it (it's spring loaded against the cable lever thingie). Electrical connector looked clean and shiny and seemed tight. Thanks for that tip Ray. Removed it and cleaned some caked on grime off and polished the inner surfaces clean. Seems to work freely now and the pedal isn't as stiff which is nice! Leaving an engines sitting for 3 years possibly isn't ideal ha. Will try for a start up sometime, she's a bit loud straight out the pipes... Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted March 19, 2012 westy said: Things I now know. Both intake boots have small splits in them. Disa valve is intact. Gotta win somethings. Idle Control Valve was nice and stuck. Cleaned and freed. Throttle body hmmm... Was stuck shut. Cable wasn't moving it (it's spring loaded against the cable lever thingie). Electrical connector looked clean and shiny and seemed tight. Thanks for that tip Ray. Removed it and cleaned some caked on grime off and polished the inner surfaces clean. Seems to work freely now and the pedal isn't as stiff which is nice! Leaving an engines sitting for 3 years possibly isn't ideal ha. Will try for a start up sometime, she's a bit loud straight out the pipes... The M52tu operated electrically via fly by wire but had a back up emergancy throttle cable also, M54 went solely fly by wire. If you only have the throttle cable connected that'll still do the same thing. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 19, 2012 westy said: If you have some of the floor mounts yeah, stick 'em up here. If he doesn't mind. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted March 24, 2012 Now starts and idles if I jump the fuel pump, for some reason it wont trigger the pump itself. Still wont rev past about 1500 and is a bit rough at idle, but at least it runs. Will need proper diagnostics from here though, probably. Vaguely remember a running issue while it was still in the e46. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 16, 2012 Teaser... Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted April 16, 2012 Good colour choice. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 16, 2012 westy said: Teaser... Im calling BS Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 16, 2012 westy said: Now starts and idles if I jump the fuel pump, for some reason it wont trigger the pump itself. Still wont rev past about 1500 and is a bit rough at idle, but at least it runs. Will need proper diagnostics from here though, probably. Vaguely remember a running issue while it was still in the e46. Missed this part ... got the tools to check it... let us know when you have it fired up next and brendon and I will pop up with the gear. Unless you feel like bring it to the pub ? thought not Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 16, 2012 Heh. Make it Sat/Sun arvo if ya free. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 16, 2012 Should be will let ya know. Also, round plug or sqaure ? and what is the qaulity of that road of yours? will determine e30 or not Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 16, 2012 Round plug. Road's ok (ish). Always easier from north end. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 16, 2012 Also, did you update your headlights to F/L Josh? Still got the old ones? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 16, 2012 cool e39 it is yes yes Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 17, 2012 Swap ya for oil cooler? Also, what are ya doing with those sport seats? Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 17, 2012 haha, you can just have em. James has the tech1 seats now. I would go for a set of sparcos ... Recaros (even second hand) are retardardly expensive. orrrr try find some like the nappa ones I have. They are around. sort of Quote Share this post Link to post Share on other sites
OLLIE 26 Report post Posted April 17, 2012 Yus progress! If you do end up templating your own bars Tony I can throw them into CAD and get the bars NC bent for you. Fast accurate and cheap. Could go as far as getting all the plate parts laser cut too. Let me know if you are keen. Quote Share this post Link to post Share on other sites
