e30ftw 433 Report post Posted January 22, 2010 Hmm thought I'd start a project on my 'latest' e30 project since the photos are accumulating to a project-thread-worthy status. Here she is, m50b25 NV 138,000kms I got from Kerry. Changed the valve cover and spark plug gaskets cos I noticed abit of leaks around the areas. Added my m20 lightweight flywheel. 6puk clutch and heavy duty pressure plate I had from my 2.7 turbo. New pilot bearing and what not. The valve cover etc was all dirty so I cleaned it all up and painted it. I also cleaned up and painted some other bits to make it look more tidier. For the conversion I chose to use what Kerry uses, so I also got this Getrag 220 off him. This will bolt up using my e30 driveshaft and crossmember and will sit on the right angle that the m50 is on. Brake booster wise, I went for a mk2 Golf booster. Got it for very cheap of VASK, Just gave it a quick clean and paint. Now since the m50 was from an e36, I also needed the e34 oil pan and pickup. Have some m52 stainless manifolds to modify, front section of e36 exhaust to play with to make the exhaust work with the rest of my system (full 2.5" exhaust). Oh and can't forget my full body loom from Mike. Legend! Anywho, still have the same old e30. Originally a 89 320i jap import. Then to 327i. Then to 327i turbo, which we all know didn't go down to well Had a guy I know do a full panel / paint on it inside and out for a good price. Shaved side repeaters (1 front panel was from a pre f/l e30 which was already shaved, other side not so much). Aerial hole shaved. Boot was already shaved, But picked up a new bonnet of Chris and had it shaved too lol. Personal preferance anyways, I reckon the boot looks alot cleaner shaven, the bonnet I am partial on but meh. Engine bay has had all the unecessary brackets shaved off too.. Sooo here she is, suprisingly I can't find any decent photos LOL... Yes, It's royalblue metallic, Yes that's the same as Matty104's e30 (LOVE IT!!) Now.... Onto the project side of things.... The standard big ass e30 brake booster and master cylinder. Take that shiz out and move the master onto the mk2 brake booster. Bolts straight up. This is what Luke used with his e30 m50. Only mod is it needs a bolt or rod put in the end of the mastercylinder because the rod inside these boosters sits about an inch too far in, meaning you would push the pedal and it wouldn't even touch the master cylinder until it hits the floor. Took all of about 5 mins to find and grind a bolt down to size, stick it in there and bolt the master to the new booster. Then it's just a matter of putting the booster in place and bolting it up. Everything on the backside lines up as if it were made to fit in here... Now here was the problem I created last time with my e30 fail project, where I shorted out the loom and created a HUGE wiring disaster. Thanks to Mike (323e30), who happen to have a 4 door facelift loom with everything I needed, I was some what saved from trying to mess around with the old loom where half the things were working and then you would fix one thing and another one stops working. So I ripped out the old loom. Lay out the 'new' replacement loom (from front to rear of car), laid it out how it would sit in the car and double checked everything was there just incase I needed bits of my old loom etc. Good c*nt even labelled it for me haha. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 Hell of a place to be feeding the loom through.. Getting there Done feeding it through.. Not sure why the grommet thing has another hole, Maybe it's meant to be covered with something else unelss something else fits through there?? Now I need to tuck all this sh*t where it belongs.. ughh.. Got a battery to boot conversion off of Jon, So put that through and couldn't find any pre-holes for the terminal so I drilled some where I could fit it out of the way. Then cover it all with this m3 cover I got mmmmmm Once I've done that loom the m50 should be ready to drop in.. Am currently making the adapter loom and I'll probably get around to sitting out the body loom and testing it works this weekend. Oh and more of whats to come... Think you know where I'm going with this hehe Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted January 22, 2010 this is going to be a blast Quote Share this post Link to post Share on other sites
SIR E30 68 Report post Posted January 22, 2010 Shes pretty big job!! Good on ya for tackling that wiring yourself, must be a prick of a job. Looking good so far mate, keep the updates coming Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted January 22, 2010 Only just saw this John. Awesome work! Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 22, 2010 And it lives again... Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted January 22, 2010 Good stuff John, measure twice cut once this time round keep up the updates I love the color. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted January 22, 2010 Fantastic write up and pic's. Keep em coming. Looking forward to the next installment! Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted January 22, 2010 Looking good dude, colour came out mint, cant wait to get mine resprayed to look that mint. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 Good stuff John, measure twice cut once this time round keep up the updates I love the color. Haha cheers, yeah definitley double checking everything this time and not rushing anything. Took me a whole day to get that loom sorted out and put back in. So far all I have done is feed it through and roughly lay everything out to where the clips are. Looking good dude, colour came out mint, cant wait to get mine resprayed to look that mint. Yeah it's pretty good, a few places it went abit weird. On the passenger side door just above the handle he burned through the paint when he was sanding and buffing over it after it was painted (1500 then buffed, makes the surface appear like glass instead of the orange pealy look you get from the spray gun). Sick colour though, I love it! Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 22, 2010 looking good man how much were your m3 cover bits. Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 It's just that last panel, I think it was like $76 shipped ex-germany through SPEEDNZ. Wasn't toooo overly bad I thought, Will look alot tidier as it will cover all the wiring continuing from the m40 loom cover into the firewall. P/N is 51711380392 Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted January 22, 2010 My only suggestion is to paint your door handles black again Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 (edited) Yeah it does look abit bland being the same colour eh. I'm shadow lining around the windows etc though. He painted my key holes too lolz Edited January 22, 2010 by e30ftw Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 22, 2010 Meaaan Quote Share this post Link to post Share on other sites
mark247 41 Report post Posted January 22, 2010 Great build thread. Looks like you are doing it right the first time. A project bimmersport should be proud of. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 22, 2010 might have to be another e3024v shoot Quote Share this post Link to post Share on other sites
mark247 41 Report post Posted January 22, 2010 Keen. Hurry up John You have 4 weeks. Quote Share this post Link to post Share on other sites
grantdavis28 8 Report post Posted January 22, 2010 Looks like you are doing it right the first time. haha you mean doing it right the second time. nah love the car john... some nice wheels and then just slam it! Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 Was the first time right though? haha. Will be getting some wheels for it next week. Should be pretty low to the ground too, got 5" 650lb rear springs with the ground controls. So should be low, But stiff Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted January 22, 2010 AFAIK and if I remember right, 650 lb on an inboard spring like that isn't that much? I would have expected a much higher rated spring if you really wanted it stiff? Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 Yeah I used henry's flash calculations and worked the front and rear ratios. Then I talked to GC to see what they would recommend, It should be good enough for a daily driver, I don't want it to be overly bumpy and all. They said 650 would be about right for me, I'm not tracking this car or anything Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted January 22, 2010 Lil update on the looming job... Have to work today so just managed to get a lil done this morning.. Have sorted out one side, Just needs to be clipped and run the check panel loom up the pillar. Then onto the other side, 1 part runs around to the boot and splits behnd the rear seat, comes back around and joins at the driver side pillar. Then the other part runs across the middle, to the window switches, across the middle again and to the doors for the windows, central locking etc then up to the driver pillar. Then just need to plug this big in, which is for the headlight switches, hazard lights etc. Rear spring size comparison Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted January 22, 2010 Have been waiting for this! The standard of e30s again keeps rising... will def be a beast once complete. Good stuff. Quote Share this post Link to post Share on other sites
e30_capri 0 Report post Posted January 22, 2010 good to see your taking your time and having some patience to do it properly mate good on ya and good luck. Quote Share this post Link to post Share on other sites
