325_driver 422 Report post Posted March 26, 2010 (edited) I think its about time we have a "rangi mods" page, here was a little bit of fun i had, on a fwd 4age, i hate the buggers because their so damn tight. So any way , i spent 6 hours swearing and managed to undo 4 bolts max, because i got stuck on the crank pulley bolt, some one had put thread locker on it, and torqued it up past 120nm, that was all i could measure, so after failing to obtain a rattle gun, since every one had conveniently misplaced theirs, i decided to go into my "think pad" and i came up with this genius idea, as a careless, see what happens, means to an end. To my amazement, worked like a charm . . . Any other strange rangi mods, any of you have resorted to come up with? Resize your photos please Edited March 26, 2010 by *Glenn* Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 26, 2010 If you did what I think you did, don't try it with a Honda. Quote Share this post Link to post Share on other sites
DRTDVL 0 Report post Posted March 26, 2010 how good an idea is this thread? Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted March 26, 2010 Cable Ties can hold a whole car together. Quote Share this post Link to post Share on other sites
thorburn 120 Report post Posted March 26, 2010 and you still have all your toes? to be truely rangi you must have done it in barefeet Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted March 26, 2010 Cable Ties can hold a whole car together. Yes. My front number plate and lip are held on with cable ties. My rear right brake light is held on with double sided tape. (you would never guess looking at it). My boot popper mechanism is an improvised bit of string after the cable broke. My air intake hose is sealed with duct tape. A special technique involving pliers (known only to me) must be employed to get the bonnet popper to work. I have drilled several holes in my jack compartment to stop it from filling up with water when it rains hard. The plasitc compartment under my head unit fits only because I had to file the sh*t out of it. Some of my exterior trim is held on with improvised washers made from black mesh. As much as I crave a BMW, often I enjoy owning a toyota more, as I can thrash the sh*t out of it without it missing a beat and rangi fixes really don't matter. Cost of above "repairs"... probably about $2, haha Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted March 26, 2010 and you still have all your toes? to be truely rangi you must have done it in barefeetHardly "rangi", we do this on RWD cars to get the crank pulley undone, only thing you can do, of course taking the radiator out goes without saying. Quote Share this post Link to post Share on other sites
E30BMA 0 Report post Posted March 26, 2010 ^ +1 on that, done that plenty of times. Id call it Handy, Not Rangi. LOL on the honda comment glenn, Im sure someone somewheres done that. Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted March 26, 2010 how good an idea is this thread? +1... I'm sure it will go titts up Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted March 26, 2010 Hardly "rangi", we do this on RWD cars to get the crank pulley undone, only thing you can do, of course taking the radiator out goes without saying. We use the proper tool "Mr Rangi" Quote Share this post Link to post Share on other sites
soarer260@hotmail.com 0 Report post Posted March 26, 2010 Perhaps we could critique a BMW like the example bellow of a crappy Soarer. Quote Share this post Link to post Share on other sites
*Glenn* 854 Report post Posted March 26, 2010 Perhaps we could critique a BMW like the example bellow of a crappy Soarer. I could do that with 30% of what I see on here Quote Share this post Link to post Share on other sites
CamB 48 Report post Posted March 26, 2010 I think a little rangi has its place in many cars. Not so much as a substitute for "doing it right" - more for "doing it at all". My best mate fixed the slop in the gear shift in his Pug 205 with a few strategic zip ties. Believe it or not it works reasonably well and has lasted quite a while. I tend to forget the rangi stuff I do - quite a bit on the race car - usually I fix it later when its not urgent. Quote Share this post Link to post Share on other sites
Driftit 1964 Report post Posted March 26, 2010 I would take the soarer over half the modified cars on here . At least it has the balls to make up for its appearance. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted March 26, 2010 gosh my day gets better, bought a water pump from repco, they assured me that while the pump was their "repco brand" identical to genuine. and it did look identical, and bolted up fine, untill it came to bolting up the pulley wheel onto the waterpump, turns out they got the dimensions wrong by 2mm diameter. Which is enough to make it impossible with out either returning the product, or improvising. Having already wasted half a day with the previous frustration. (Block your ears glenn, and dont read this) i decided to drill into the pulley wheel so that the bolts would be able to line up (after carefully measuring), works like a charm. . . . that is not some thing im proud of, but after 5 hours of your day gone, i had had enough. I didnt bother to take photos because it may have frightened some mechanics. So i have learnt a lesson, if im ever going to buy after market again, (if ever) i will be taking verniers and every thing needed to measure accordingly Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted March 26, 2010 This is inspiring ^^ Quote Share this post Link to post Share on other sites
soarer260@hotmail.com 0 Report post Posted March 26, 2010 Aerodynamic... Quote Share this post Link to post Share on other sites
danutt 4 Report post Posted March 26, 2010 Aerodynamic... haha topspeed...80kph with that wind drag haha Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted March 26, 2010 haha topspeed...80kph with that wind drag hahaProbably, before you take flight and back flip with all that frontal dynamics Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted March 26, 2010 http://failads.com/50-really-ridiculous-car-mods/ Quote Share this post Link to post Share on other sites
greenday-rulz21 4 Report post Posted March 26, 2010 http://failads.com/50-really-ridiculous-car-mods/ Almost look like E30 M3 arches! haha Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2122 Report post Posted March 26, 2010 if i posted all the rangi things ive done over the years (all 'ill fix that properly later' things, which i have for the most part) id run out of characters? *Volvo lip cut using a belt sander and then zip tied on (since replaced with tech2) *underdash wiring i used packing tape for insulation (since redone) *sub and amp wiring 'tidyed up' using twistieties (the one time i run out of zip ties is the one time id be using them for what they were desgined for!). also since redone *various bolts lost and left unattached. get replacements from the yards for free *etc... also various cases of not so much rangi, but not having the correct tools on hand and improvising. never been unable to get a job done using a jack, a 200piece socket set, a bfh and a hack saw LML Quote Share this post Link to post Share on other sites
e30plz 1 Report post Posted March 26, 2010 if i posted all the rangi things ive done over the years id run out of characters?+1, I enjoy my rangi mods though.*Volvo lip cut using a belt sander and then zip tied on (since replaced with tech2)Garden edging + masses of cable ties = rangi Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted March 26, 2010 (edited) I replaced the radiator drain bung with a metal bolt with thread seal <.< It still leaks. other than that though... nothing is too "handy". Oh, and I have no rego holder pocket, so It's just magically stuck there using magic. Edited March 26, 2010 by antil33t Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted March 26, 2010 We use the proper tool "Mr Rangi" Oh there's a proper tool? Drill a big f**k off hole in the radiator and use a large extension? Quote Share this post Link to post Share on other sites
