Shady 0 Report post Posted June 9, 2011 As per the photo. There are spanners. Screwdriver. Allenkey. Sparkplug remover. And I forget the name of that tool that looks like pliers. But as for the others, what are they called and what are they for (how do you use them?) Only asking cos been told the far bottom left is for electric windows, but dont see how you'd use it? And the other 2 random bar things? I also need that thinnist one (inside the plug tool) if anyone has one? I want to complete my tool kit. Quote Share this post Link to post Share on other sites
pureboiracer 0 Report post Posted June 9, 2011 polygrips, spanners, double ended screw driver, spark plug tool and handle for said tool, allen key. Unsure of plastic bit. Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted June 9, 2011 Far right is a stud hanger, used to help put wheels on, chuck it in the top hole of your hub, slot the wheel on to it, let it hang there while you put in 2 studs, pull it out through the wheel... Saves you swinging the wheel round and round trying to line up the studs. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted June 9, 2011 /\ I wondered what that was for... Quote Share this post Link to post Share on other sites
dubman 39 Report post Posted June 9, 2011 where does the BMW locknut key go? Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted June 9, 2011 On your keyring... it was a little physical key, wannit? Quote Share this post Link to post Share on other sites
huff3r 347 Report post Posted June 9, 2011 On your keyring... it was a little physical key, wannit? Indeed, it was for mine! Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted June 9, 2011 Far right is a stud hanger, used to help put wheels on, chuck it in the top hole of your hub, slot the wheel on to it, let it hang there while you put in 2 studs, pull it out through the wheel... Saves you swinging the wheel round and round trying to line up the studs. Hmm! Im going to try that next time! good idea. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted June 9, 2011 /\ I wondered what that was for... Ditto! Oh the enlightenment. Quote Share this post Link to post Share on other sites
Forrest 35 Report post Posted June 10, 2011 The allen key is for if your electric windows fail, you pop the round circle cover off the door card and the allen key will fit into the head and you can manually wind the window up or down Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted June 10, 2011 Woah, 2 new things in one day! Quote Share this post Link to post Share on other sites
westy 614 Report post Posted June 10, 2011 Woah, 2 new things in one day! Don't over do it, mate. Quote Share this post Link to post Share on other sites
Shady 0 Report post Posted June 10, 2011 (edited) I knew that allen key thing, I figured that out when I needed to remove windows from the wreck I had. But what about the rod thing in the sparkplug remover -assuming it slides thru the holes and you use it to twist the plug remover? And that small plastic thing, Im guessing I was wrong about using it for windows (but no idea how) - what else could it be for? And yes, definitely gona use that rod for the wheels now... Edited June 10, 2011 by Shady Quote Share this post Link to post Share on other sites
leithcm 0 Report post Posted June 10, 2011 (edited) The pliers are sometimes known as slip-jaw pliers, or waterpump pliers. the plastic thingy to the left/bottom is to remove the plastic dummy nut that slips onto the lock stud for the wheels. The bar inside the spark plug tool is a tommy bar - slips in the holes at the top as a handle to turn the spark plug socket. Edited June 10, 2011 by bikerchris Quote Share this post Link to post Share on other sites
Sick Puppy 1 Report post Posted August 11, 2011 (edited) Not that I want to thread hijack, but... I'm wondering what I'm missing from these two toolkits please? This one is obvious - the tow eye (I have one, but it's too long ), and something else on the right side; What about this one though? No space for the eye or 10mm socket at all... but something in the middle, under the spanners etc? Thing is, I'm sure there are other tools that can be found with the E34, I just have no idea what they are! Anyone have any info? Oh, and how much do tow eyes go for at the wreckers? Need to complete the kit I have... Edited August 11, 2011 by Sick Puppy Quote Share this post Link to post Share on other sites
KwS 2448 Report post Posted August 12, 2011 (edited) As i found out, the allen key can also be used for opening/closing the sunroof in the event of failure. In the E36 you pop the panel off behind the map lights, and you can stick the key into the sunroof gearbox. In terms of the E34 kit, the only reference i can find to anything being in that empty spot on the top one is this image. i still dont know what is there Edited August 12, 2011 by KwS Quote Share this post Link to post Share on other sites
Matty104 0 Report post Posted August 12, 2011 Looks like a tyre pressure guage maby Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted August 12, 2011 Not that I want to thread hijack, but... I'm wondering what I'm missing from these two toolkits please? This one is obvious - the tow eye (I have one, but it's too long ), and something else on the right side; What about this one though? No space for the eye or 10mm socket at all... but something in the middle, under the spanners etc? Thing is, I'm sure there are other tools that can be found with the E34, I just have no idea what they are! Anyone have any info? Oh, and how much do tow eyes go for at the wreckers? Need to complete the kit I have... e34's dont need to screw in tow hook as they have tow loops behind the tow hook covers.the thing on the right should be for the 2 lock nut keys Quote Share this post Link to post Share on other sites
