simonvv 2 Report post Posted April 25, 2012 Gave it a clean and Sunday drive Thinking it needs more power- chip,cam,airflow meter change??? 5 speed, cream leather, the best 1 Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted April 25, 2012 How about my mapecu2 unit which is custom fuel mappable and enables you to eliminate the afm (internal map sensor in mapecu). Has been running both my motronic ecus (1.1 & 1.3). Quote Share this post Link to post Share on other sites
BM WORLD 1258 Report post Posted April 25, 2012 very nice , looks great yes after years of playing around with m30's etc , doing cams , head swaps , etc etc http://www.millerperformancecars.com/catal...p;category_id=6 best bang for buck is one of these and a remap of the ecu to suit also lightening the flywheel to 7kg will help and a diff swap to a 3.73 ratio etc Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted April 25, 2012 That looks sweeeeeet! Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted April 25, 2012 How much could I expect with that chip and airflow meter change? Safe on the motor? very nice , looks great yes after years of playing around with m30's etc , doing cams , head swaps , etc etc http://www.millerperformancecars.com/catal...p;category_id=6 best bang for buck is one of these and a remap of the ecu to suit also lightening the flywheel to 7kg will help and a diff swap to a 3.73 ratio etc Quote Share this post Link to post Share on other sites
BM WORLD 1258 Report post Posted April 25, 2012 How much could I expect with that chip and airflow meter change? Safe on the motor?normally one of these 635csi engines will get about 110-120kw at the rear wheels (on gavins dyno), i would say about 130-140kw with the maf unit and a remap. but also a decent punch of usable toque through the midrange which is where you use it mostly. best thingto do is run it up on teh dyno as it is , just make sure you have good spark plugs and set right also vlave clearances are done correctly , good air filter and fuel filter etc good dizzy and rotor etc. do a run so you get a base line to start with then go from there with mods etc Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 26, 2012 (edited) the biggest issue with remapping is you need the software to do it or someone that has it and your limited to what you add on and the remap wont allow afm removal the mapecu allows the owner to do many many things when ever they wish without going back and spending more just for a small change. the mapecu allows you control over fuel/ignition and duel tables launch control flat shifting data logging etc etc etc and the stock ecu wont do that, and as Brent has found the final tune is only as good as the tuner to how good it comes out which applies to all tuning but you can atleast have control over it your self with out reflashing costs. you get so much more to play with using the mapecu over the reflash then again i dought youll go any other way but a reflash Edited April 27, 2012 by crunchy Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted April 27, 2012 MAF and Chip it is then! Quote Share this post Link to post Share on other sites
Silver Fox 43 Report post Posted April 27, 2012 My M30 535 has Miller conversion, mild regrind on cam and remap and puts out 155kw at the wheels, not hard to do. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted April 27, 2012 Back to the topic opener - Love the car! Quote Share this post Link to post Share on other sites
BM WORLD 1258 Report post Posted April 27, 2012 My M30 535 has Miller conversion, mild regrind on cam and remap and puts out 155kw at the wheels, not hard to do.go on tell the full story david planned and skimmed head and block to raise the compression, nice open headers and exhaust system etc but yes thats good results from the old m30 block Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 27, 2012 (edited) My M30 535 has Miller conversion, mild regrind on cam and remap and puts out 155kw at the wheels, not hard to do. thats a good result dave the 535 i did had headers/stock exhaust and stock everything else and the mapecu and a hour road tune no dyno making 140.7kw wheel and no drop off up top be interesting with a few extras what i could have done, still each to their own and for under 1k for the mapecu cant complain. so whats the maf/w.a.r chip cost? 1000nz with shipping and gst plus the dyno if you need to sort out issues another 5-800? i guess like all kw/hp numbers if cant drive or are just a poser the numbers arnt worth the paper their written on.( not directed at you dave ) but make funny youtube watching Edited April 28, 2012 by crunchy Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted April 28, 2012 Isn't the standard HP 210? Or would that have dropped drastically after 30 years ha go on tell the full story david planned and skimmed head and block to raise the compression, nice open headers and exhaust system etc but yes thats good results from the old m30 block Quote Share this post Link to post Share on other sites
BM WORLD 1258 Report post Posted April 28, 2012 Isn't the standard HP 210? Or would that have dropped drastically after 30 years harear wheel horse power , not the flywheel hp that bmw give in the owners manual.635csi 218hp 160kw 310nm at the flywheel works about about 110-120rwkw depending on dyno and air temp etc when all in good order or new etc. have seen some others with less and the odd one with more. millar maf unit and adaptor chip and housing about $380usd incl fr8 (you dont need the war chip thing) plus local nz remap talk to gavin etc as you might be surprised by the cost Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted April 28, 2012 ^ Factory HP figures are measured at the crank. Dyno figures are measured at the wheels. You need to adjust for around 20% drivetrain loss. So, 155kw at the wheels is 207hp or around 240-250hp at the crank. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted April 28, 2012 ^ Factory HP figures are measured at the crank. Dyno figures are measured at the wheels. You need to adjust for around 20% drivetrain loss. So, 155kw at the wheels is 207hp or around 240-250hp at the crank. Sounds about right i use 15% for rear wheel and 20% for a four wheel or two wheel auto. So taking a m5 286hp factory spec motor would be 248-238 wheel or 185-177kw wheel again sounds about right, again just a number the track or a stop watch tells all. Quote Share this post Link to post Share on other sites
Michael. 2312 Report post Posted April 28, 2012 I love this car. Well done Simon! Quote Share this post Link to post Share on other sites
simonvv 2 Report post Posted August 21, 2014 Managed to find some funds to justify a new MAF, Chip and since I was on the Miller website i ordered a N21 cam to Do I need the HD rockers or will the stock handle it ok? If I do need HD rockers are they available in NZ? Cheers Quote Share this post Link to post Share on other sites
kulgan 1042 Report post Posted September 15, 2014 I love these cars. So sexy.. Looking forwrd to reading the updates on how your performance mods go. Oh, and more pics please. Quote Share this post Link to post Share on other sites
Cab 148 Report post Posted September 16, 2014 H/D rockers arent that expensive so youre probably best to do it while the heads off Quote Share this post Link to post Share on other sites
