liyi_92 37 Report post Posted October 1, 2012 (edited) Hi guys, car is a e39 540i After suffering an oil leak (Which is getting fixed on Wednesday) I would like to clean out all the remaining oil which is left there as after a while of driving there is a smell of burnt oil. Which are the parts to cover up? Wash while engine is running or disconnect battery? (Searched google and many different opinions) I also read dish soap would work? Any other important notes I should be aware of? Thanks Edited October 1, 2012 by andy_e39 Quote Share this post Link to post Share on other sites
Andre3000 55 Report post Posted October 1, 2012 Just use a can or two of brake clean/degreaser, wash that sh*t off with low pressure hose end. Obviously cover all electrical plugs/fuses that might get wet in the process. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 1, 2012 If you want it really clean. Use above method, then get out a old tooth brush and rag and go buy some Meguairs Tar and Bug Remover. Its a cream in a trigger bottle, spray it onto/into the tooth brush for hard to reach areas and the rag for bulk areas. It safely pull all grime and grease / oil etc out of the paint and it will look like new. My trick for show winning engine bays revealed haha Quote Share this post Link to post Share on other sites
Allanw 1078 Report post Posted October 1, 2012 Be VERY careful what brake cleaner you use - some of it strips paint (The partmaster stuff does!) and some will dissolve rubber or swell it - Not sure how that's safe for BRAKE cleaner, but it does! Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted October 1, 2012 Some people have advised using tyre shine spray/foam, but I've never seen it done in person. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 1, 2012 I've always used WD40, some cloths and a fine mist spray of water to wash it off, then dry it all with some clean towels. Works a charm, just take the precautions around electric areas. Quote Share this post Link to post Share on other sites
liyi_92 37 Report post Posted October 2, 2012 So it would not be a good idea to use a garden hose to hose down the cleaned parts? Thanks guys Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 2, 2012 (edited) So it would not be a good idea to use a garden hose to hose down the cleaned parts? Thanks guys Not on full blast, that would be asking for trouble. After puting a nice layer of WD40 over the engine bay I use a fine mist and cover up the key electric bits Its enough to let some of the WD40 run off with the dirt. The trick then is to wipe down every inch of the engine bay with a few rags Edited October 2, 2012 by Michael. Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted October 2, 2012 Taking the car for a drive or letting it idle for a bit is also a good way to get rid of any moisture, letting it get up to operating temp should boil anything off that's still there. Quote Share this post Link to post Share on other sites
Neal 568 Report post Posted October 2, 2012 Another altenative is 1 part dynamo to 3 parts warm water put into a spray bottle. Spray on and leave for 5 mins. Rinse of with lower pressure water. Works well on the Ducati to remove road grime off the engine and chain oil off the swing arm. Also brought the M3 engine bay up to scratch. PH natural and breaks down better after than most car cleaning products. Quote Share this post Link to post Share on other sites
