No name user 379 Report post Posted May 26, 2013 https://www.facebook.com/photo.php?v=102005...e=2&theater playing Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted May 27, 2013 Steve, are you using an M30 3.5l for your e34 weapon? Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 27, 2013 Steve, are you using an M30 3.5l for your e34 weapon? M50B25 Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted May 27, 2013 Nice! Am definatley keen to read/see more about this beast. It seems quite common to turbo the old m30 or if you're well off an s36 or s38. Props to ya for having a tinker on the M42 and M50! Someone should gift you an m60 to turbo Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 27, 2013 Nice! Am definatley keen to read/see more about this beast. It seems quite common to turbo the old m30 or if you're well off an s36 or s38. Props to ya for having a tinker on the M42 and M50! Someone should gift you an m60 to turbo the M30 is such a strong engine even in stock form apart from the rockers if you rev it to hard thus i went for the M50 as itll run past 8k, the little M42 has just gone past 11k since the build and still runs strong as for the M60? someone want to be the donor im keen Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted May 27, 2013 That looks real menacing, if I saw that in the rear view mirror id turn into a old granny pull over and let you past ! Start a tread we are all keen to follow the making of this machine Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted May 27, 2013 That looks real menacing, if I saw that in the rear view mirror id turn into a old granny pull over and let you past ! Start a tread we are all keen to follow the making of this machine its not far off being done so its not worth a putting thread up but youll know when im in your streets Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 (edited) Got asked nicely on an update for e34 turbo so ill keep it brief. Car is running and tuned fuel system was completed or should i say upgraded on weekend just gone, upon testing it only tuned to 5psi which it makes by 4500rpm which im pretty happy with its pretty good since i run it to 8500 giving a large window for use. Pulls well to 5k smooth and responsive from there to redline it gets interesting i swear the tow bar hits the deck and front end gets very light mind you the rear coil overs are set a tad soft but it hits the limiter at a blink of the eye with not bad traction. Down side the sintered saw blade clutch didnt like it too much letting go at the topend of third so making another flywheel and clutch but twin plate solid center then itll get turned up to 10psi and another tune ( if the clutch holds )as for power? Well the clutch had a 400ft/lb rating im sure those interested will get the idea plus its just a number Edited August 28, 2013 by crunchy Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted August 28, 2013 Good to see you back, even if it is brief, looks like you've been having fun! Are you planning on running it up on a dyno? Be very interested to see what it's putting out. And some vids!!! Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 (edited) apologies i have a very short tolerance to special people as such and no not you itll go to the dyno after the new clutch etc its to hard to catch the tune for flash road tuning now my daughter will tag my FB page when we had a play with the launch control which totally destroyed the clutch which to be honest was great fun doesn't take long to remove the box so no big deal Edited August 28, 2013 by crunchy Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted August 28, 2013 Just love your skiteing style Crunchy! Subtle but brutal. Great work! Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted August 28, 2013 All good Steve, it's people like you I love in life! Take an idea that seems impossable and makes it happen, and shut afew people up on the way haha! Can't wait to see her in action. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 https://www.facebook.com/photo.php?v=102012...e=2&theater Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted August 28, 2013 Got asked nicely on an update for e34 turbo so ill keep it brief. Car is running and tuned fuel system was completed or should i say upgraded on weekend just gone, upon testing it only tuned to 5psi which it makes by 4500rpm which im pretty happy with its pretty good since i run it to 8500 giving a large window for use. Pulls well to 5k smooth and responsive from there to redline it gets interesting i swear the tow bar hits the deck and front end gets very light mind you the rear coil overs are set a tad soft but it hits the limiter at a blink of the eye with not bad traction. Down side the sintered saw blade clutch didnt like it too much letting go at the topend of third so making another flywheel and clutch but twin plate solid center then itll get turned up to 10psi and another tune ( if the clutch holds )as for power? Well the clutch had a 400ft/lb rating im sure those interested will get the idea plus its just a number 8500rpm!? What kind of work is involved to get the m50 to handle that ? Can't wait to see this Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 its a long list opps forgot to mention this isn't the good motor thats sitting on the engine stand Quote Share this post Link to post Share on other sites
blonky 2 Report post Posted August 28, 2013 Video doesn't work? Keen to see more been following your progress Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 Video doesn't work? Keen to see more been following your progress just tried it works fine Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted August 28, 2013 Needs to be made public, can't be viewed otherwise. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 28, 2013 shared it on my timeline which should be for all to see barring that youll need to take my word on it Quote Share this post Link to post Share on other sites
328bema 18 Report post Posted August 29, 2013 Sounds good man, upgrades upgrades & more upgrades haha Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted August 30, 2013 Sounds good man, upgrades upgrades & more upgrades haha or maybe just do it once do it right Quote Share this post Link to post Share on other sites
charles28 142 Report post Posted September 12, 2013 Very Cool! your setup will definitely overcome the weight of the E34 Chassis and be crazy as Of course by todays standards an E34 525i isn't really that heavy I guess, since a new VW Golf is close to 1400kg (for a small ish hatchback) . Quote Share this post Link to post Share on other sites
Jibs05 86 Report post Posted January 14, 2014 How is the MAPECU? I really want to use it for my 3L stroker. Quote Share this post Link to post Share on other sites
No name user 379 Report post Posted January 14, 2014 mapecu worked very well i since then stepped up to larger injectors thus had to go aftermarket ecu as the mapecu cant control them to well being over 50% larger than stock it will however depending what your doing will run yours well Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted March 1, 2014 Real keen to see more of the e34 if you have any updates? Quote Share this post Link to post Share on other sites
