Tristan 338 Report post Posted December 7, 2012 Hi guys My girlfriend's car has been used at the beach a lot over the past few years and subsequently has sunscreen handprints around the windows and doors. I've tried clay barring it but that didn't work. Any other suggestions or does it need professional attention? Thanks Tristan Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted December 7, 2012 We see this alot... I can't help but I would like to know Quote Share this post Link to post Share on other sites
Smac01 12 Report post Posted December 7, 2012 A professional machine cut and polish. That's the only thing that worked for me previously. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted December 9, 2012 It's probably the zinc oxide in the sunscreen that won't come off as it's a mineral. Try a product for removing water stains (also mineral-based) and that might work. Can't recommend any off the top of my head, I'm afraid. Quote Share this post Link to post Share on other sites
cliffdunedin 8 Report post Posted December 10, 2012 I had this same problem on my Subaru door a couple of years ago, nearly new paint too I did some research and tried a few things (Claybar, Desolve it) I eventually tried a good cut and polish then tried a Meguiars product QuikWax, SwirlX or something like that with a polisher then another wash, cut and polish it came up good as new... so much so i had to do the rest of the car because it seemed dull. Quote Share this post Link to post Share on other sites
Kaz 64 Report post Posted December 13, 2012 (edited) Not sure if this could be relavant, but I had hand prints on my old car which were left by the mechanics that wouldn't come off with a good wash. I bought a very good Meguiars Cut & Polish (I'll check the name when I get home) and it seemed to do the trick. Might work for sunscreen too. Edited December 13, 2012 by Kaz Quote Share this post Link to post Share on other sites
Apex 693 Report post Posted December 13, 2012 Easiest way to get rid of it is to dump her Have you tried decent polishing or cutting compound and a foam polishing pad?… maybe wait until after summer as it will likely happen again. Quote Share this post Link to post Share on other sites
digitalashley 7 Report post Posted July 1, 2016 Old thread but i had this issue and used a paste type product from CRC called paint doctor and a nice micro fiber cloth. You rub on leave for ten minutes the buff off. I was amazed. Works perfectly. 1 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 2, 2016 Hmm i have some handprints on the Pajero too i woonder if it is sunscreen.? Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted July 2, 2016 I used a polish on the Falcon, then needed to go down to a quick compound and then buff to remove, seems to discolour the clear coat hence the need for a compound out. Been three months still good Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 2, 2016 I find it funny you tried to claybar chemical damage... 1 Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted July 2, 2016 clay bar is just another polish/cleaner.It just as good(or bad) as any other polish/cuttimg attempt isnt it? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 3, 2016 clay bar is just another polish/cleaner.It just as good(or bad) as any other polish/cuttimg attempt isnt it? It's a particulate matter cleaner, removes stuck on debris. From what I've seen its easy just to polish over stuck on debris, not removing them properly hence the use of a clay bar with lubricant. If anything I believe its a post wash, pre polishing tool. Another technique in the car detailing arsenal ! 2 Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted July 3, 2016 Yip clay bar removes all that nasty debris to prep for polishing, doesn't impact the clear coat or paint. Great for making your paint super smooth before a wax as well. Also wicked on glass to remove buildup Quote Share this post Link to post Share on other sites
Olaf 3421 Report post Posted July 6, 2016 (edited) it's not these marks you're trying to remove, is it? Edited July 6, 2016 by Olaf 4 Quote Share this post Link to post Share on other sites
Breaker 980 Report post Posted July 6, 2016 Hahaha I like it Quote Share this post Link to post Share on other sites
Olaf 3421 Report post Posted July 11, 2016 ^^ that's what she said! 1 Quote Share this post Link to post Share on other sites
Autoglym 255 Report post Posted July 14, 2016 What have you been doing on that car!!! Quote Share this post Link to post Share on other sites
Olaf 3421 Report post Posted July 17, 2016 ^^ That's what he said! 1 Quote Share this post Link to post Share on other sites
