Mr2low 57 Report post Posted February 26, 2013 Well it started first try no hesitation at all and idled fine, however lol. The fuel gauge started dropping so I turned it off and when I got out noticed the smell of petrol, under the passenger side there's a damp patch where the 3 pipes go back upto the tank, also a bigger damp patch under where the passengers seat would be. Tomorrows task find source of leak, any ideas would be very handy. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted February 26, 2013 good work . replace loose once only type hose clamps or try retightening them , check the hoses , they shrink/crack etc when sitting around Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted February 27, 2013 (edited) Well got the underbody panel off that covers the filter and rubber hoses joining the hard lines together, did have a nice big damp patch there, so guessing this is where I have the issue, I'm going to replace all the short joiners with new hose and get a new filter. also removed and binned the aftermarket hands free kit because it looked ugly as sin, and who knows what it fits. Edited February 27, 2013 by Mr2low Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 1, 2013 well been lazy taking photos and not uploading them, so heres a few just to prove I am doing stuff head lights used to look like this with 1500,2000,3000 grit sand paper with scratch x on the buffer and then polished now ill be able to see in the dark broken bumper, nothing msport one wont fix after hitting it with every compound I own still left with this, not really the scratches more the damage from sitting for so long and having water sit on the paint then getting baked into the paint not to worry nothing a full body wet sand wont fix(future plan not urgent) the other night 20 seconds of running hahaha Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted March 1, 2013 Good to see you've got it running again. With the petrol leaks I had a similar problem on my mums car from old rubber hoses starting to crumble away where they honed onto the fixed lines. Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted March 1, 2013 well done! Keep up the good work! Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 1, 2013 i beleive a din 66 would be the absolute minimum required.From memory even my e34 was rated above this Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 2, 2013 Cool I'll check out on what's recommended was only from memory been 8 years since I worked for repco memory a little hazy could still walk in and pick a Subaru timing belt kit out though Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted March 2, 2013 Cool I'll check out on what's recommended was only from memory been 8 years since I worked for repco memory a little hazy could still walk in and pick a Subaru timing belt kit out thoughi t will likely be 100s od dollars but having a car of about 1600 kg with a flat battery is no fun at all Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 2, 2013 Have already had to push it a few times now and it isn't fun would've thought mid 200's for battery though Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted March 2, 2013 Yes will be a DIN 66 for your car spec. 88 better though Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted March 2, 2013 i beleive a din 66 would be the absolute minimum required.From memory even my e34 was rated above this Not to be mr negative, but possibly expect a trans failsafe program pop up on the MID in winter. Not enough grunt to activate the trans solanoids and throws a fault. You should really be running a DIN88. Good stuff on the restore, I need to do this to my headlights My give it a crack next weekend. Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 3, 2013 Cheers saves me looking will do the phone around tomorrow see who has one Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 6, 2013 Finally got fuel filter and fuel line joiners fitted today not ideal with out a jack lol but got it done(have no idea where my jacks vanished too plus car is missing its) gave battery good charge and she ran fine for 15mins just idling plus a couple of trips up and down the drive way just to make sure brakes work, only interesting thing is odd readout from fuel gauge reckons its got 30l in there ? Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted March 26, 2013 (edited) well had a major blow today, finally got an answer on my proof of ownership issue. Have to wait for probate to be , then get a letter from the executor of the saying that ownership has been transferred to me then have it witnessed by the courts. Yay may as well get the sedan over and get that running. Edited March 26, 2013 by Mr2low Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted May 15, 2013 What was the outcome of the onwership issue? Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted May 15, 2013 basically waiting for probate to finish, every time its almost all done they find something else to ask and so it drags on 8 months and counting, that will give me all of the paper work vinz needs Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted May 15, 2013 Far out. What a bureaucratic headache! Quote Share this post Link to post Share on other sites
Mr2low 57 Report post Posted May 15, 2013 tell me about it, mum just sold the house too, im only waiting on two cars shes waiting on a large sum of $$, every time the lawyers need to send a letter, email, phone call the bill grows Quote Share this post Link to post Share on other sites
