polley 916 Report post Posted September 8, 2013 i won't ask what your doing, it will spoil the suspence, i cant wait to see how you make it run! Already sorted that, had it running before it was installed in the car. Running standard ECU's Quote Share this post Link to post Share on other sites
topcat 11 Report post Posted September 9, 2013 Already sorted that, had it running before it was installed in the car. Running standard ECU's I like flames Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 9, 2013 Mad bastards skid machine. Fully approve. 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 9, 2013 So tonight me and pete married the two drive shafts together. It had to be shortened and the front half of the E32 shaft welded to the E28 shaft, they are completely different. Not a lot of photos but, front half of E28 drive shaft was machine down so perfectly round and then parted off, front half of E32 shaft was measured and then parted off to length. The E32 shaft is larger in diameter so a bush was made that fitted the two together, then it was all welded together. The victims: Machining of the E28 shaft: E28 shaft compeleted: Parting off the E32 shaft to length: Driveshaft was completed, but didnt get any photos it was a bit dark, will post some tommorrow. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 9, 2013 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 9, 2013 A large engine, small car swap? Awesome work! This will make for an interesting drive! Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 10, 2013 Today I decided against the E28 so I pulled the engine out and started mocking it up in the land rover instead: Ok not really, but I pulled the engine out so I can finish off everything in the engine bay like brake lines and stuff, I cut the frame rails to fit a larger radiator. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted September 10, 2013 at this rate you'll be swinging O's by the weekend! nice work Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted September 10, 2013 Bloody hell, ya don't muck around eh!! Nice work This so needs to be road legal when complete! Quote Share this post Link to post Share on other sites
2052NV 43 Report post Posted September 10, 2013 wow awesome work man!!! im a massive fan of big engines in small cars! Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 10, 2013 at this rate you'll be swinging O's by the weekend! nice workThat would of been nice, but I'll be away from the car until the weekend :/ Bloody hell, ya don't muck around eh!! Nice work This so needs to be road legal when complete! I get about 2 hours of work in after work before it gets too dark. I'm not sure it'll be road legal though, it's kinda nice been able to modify what I want how I want with out worrying what a certifier might think. wow awesome work man!!! im a massive fan of big engines in small cars!Same Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 10, 2013 Flaaaange: Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 28, 2013 (edited) Brake lines did, a bit ugly but this is the second time around after using some shitty fittings from apex that f**ked me off, so I didn't have much patience doing them again Edited September 28, 2013 by polley Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 28, 2013 Boxed in the chassis rails where I cut them. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted September 28, 2013 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 3, 2013 Put the engine back in the hole, put the driveshaft in and the driveshaft universals were on a sh*t angle so had to modify the gearbox crossmember and raise the gearbox. Trimmed the alternator to clear the chassis rail: Dropped the engine back in the hole and mounted the oil filter: I removed some unneeded interior items and mounted the ECUs: Removed the diff and made sure it will spin both wheels: Not a lot of time left before I have to have this running, havent got much done over the last few weeks because of tech and work :/ 1 Quote Share this post Link to post Share on other sites
Phil-540i 166 Report post Posted October 3, 2013 Small car, V12, & CIG locker - nope, I'm not seeing any problems - should be lots of $hits & giggles........You're a legend!! Mad ba$tard too probably - should be mega fun!! Good on ya!! Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted October 3, 2013 EPIC Quote Share this post Link to post Share on other sites
2052NV 43 Report post Posted October 8, 2013 holy crap thats a lot of Control units! Are they all just for the engine? Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 9, 2013 Three for the engine, one for the trans. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 19, 2014 Alrighty, long time no update, kinda got distracted with other things. Pete did most the work on the zoomies, so thanks for that.. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted January 19, 2014 Love the exhaust! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 19, 2014 (edited) how are you doing the throttle are you going to convert it to a normal cable setup or keep the "die by wire"* system? *trademark Lance (melowpuf) lol Edited January 19, 2014 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
polley 916 Report post Posted January 19, 2014 (edited) going to keep drive by wire at this point. Edited January 19, 2014 by polley Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 19, 2014 That is fn badass dude! Quote Share this post Link to post Share on other sites
