jeffbebe 1587 Report post Posted October 23, 2013 (edited) I'm assuming that coding it AFTER the software upgrade won't affect the data. I'd be tempted to code it to the car, and leave it fitted (since it's now in there), while sending YOUR one to the US of A. then swap back. You can hten change abck and forth willynilly Yep, that's what I was thinking. The EGS has to be coded to the VIN (and run in the car) before it is upgraded, hence why I can't just buy a cheap matching EGS in the USA on eBay and ship directly to Dinan... Has to go in my car and be coded first. Edited October 23, 2013 by jeffbebe Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 23, 2013 Interesting, took my EGS out to check the part no. and it isn't listed (on RealOEM.com) for my car. Rather it's listed for an E38 740i. Same engine and gearbox obviously, but would they have had identical software? Quote Share this post Link to post Share on other sites
BM WORLD 1298 Report post Posted October 24, 2013 Interesting, took my EGS out to check the part no. and it isn't listed (on RealOEM.com) for my car. Rather it's listed for an E38 740i. Same engine and gearbox obviously, but would they have had identical software? they changfe part numbers on ecu's like there underwear , they are pretty generic boxes with sleightly different coding programmed depending on the car they are fitted too Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 24, 2013 Also Jooles, your car is one of those funny change over cars ... half half of the modules Pre OBDII standard and the rest comply. This is why you have two diag ports. 16pin square and 20 pin round. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 24, 2013 (edited) Uncompromising would be if you applied it to your own decisions. Black and white is forcing your 'uncompromising' opinion on everyone else even when they have stated up front that the opinion you're offering has been deliberated and ruled out. Edited October 24, 2013 by jeffbebe 1 Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted October 24, 2013 (edited) I'm sure there's someone closer than I am, who can do the coding etc, but otherwise - I'm up here. (I don't have an adapter to fit your 20 pin either - I need one though anyway) I also seem to recall that the Japanese 'boxes were different to the Euro/NZ ones... even on the V8's Did they have the US type box??? Edited October 24, 2013 by Allanw Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 24, 2013 Thanks Allan. According to Dinan all the boxes - US, Japanese, Euro, etc - were the same. Also, pretty certain the EGS can be accessed via the OBDII connector (my car has OBD I and II). Quote Share this post Link to post Share on other sites
HELLBM 1697 Report post Posted October 24, 2013 Can do you an egs and coding for $100 ( bimmersport super special). 1 Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted October 24, 2013 Ray, you're a legend, thanks. Will see you this weekend (either at Puke or on Monday). Cheers Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted October 25, 2013 Ray to the rescue. What a guy! Quote Share this post Link to post Share on other sites
jcerecke 2 Report post Posted November 9, 2013 I'd be interested in your results. I've often wondered if I could have a readout of the gear while in Drive/Sport mode. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted November 9, 2013 I'd be interested in your results. I've often wondered if I could have a readout of the gear while in Drive/Sport mode. Pretty certain you can do that... Josh (hybrid) mentioned he'd done or seen something similar. Quote Share this post Link to post Share on other sites
craigo1498 0 Report post Posted September 8, 2020 (edited) Hi Sorry to bump this 7 year old thread but did you get what you were looking for in terms of the performance increase on the auto trans? I have a 328ci (japan) and was hoping to do the same. Cheers Edited September 8, 2020 by craigo1498 Quote Share this post Link to post Share on other sites
