M3AN 4182 Report post Posted May 23, 2016 No way! I grew up in Celtic Cres and the family house is still there! Way! 200m down the road from me. And I've just discovered a massive BMW parts shop on Marua road also, lots of cars and containers. Not a sponsor here though which is a bit of a bummer but I'm still going to check them out. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 23, 2016 Way! 200m down the road from me. And I've just discovered a massive BMW parts shop on Marua road also, lots of cars and containers. Not a sponsor here though which is a bit of a bummer but I'm still going to check them out. That parts shop is pretty good, although I've heard pretty sketchy stuff about the BMW place behind it at the end of the dead end street. Pretty sure they are not related though. Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted May 23, 2016 Probably needed a clean! Which warehouse? I live on Marua Rd. Haha me too, just taken over 132E Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted May 23, 2016 That parts shop is pretty good, although I've heard pretty sketchy stuff about the BMW place behind it at the end of the dead end street. Pretty sure they are not related though. Thanks for the heads up, only ever been down that dead end to turn around, didn't know there was a Bimmer place there! Haha me too, just taken over 132E Directly opposite the BWM parts place! If you ever want an after work beer drop me a line. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 23, 2016 Haha me too, just taken over 132E I'd love to pop over one day too. Be great to have a beer and check out your projects 1 Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted May 23, 2016 I'd love to pop over one day too. Be great to have a beer and check out your projects More than welcome! I'm around most of the time. Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted May 23, 2016 Where abouts are you? yea Im directly opposite them.We should have a few beersies sometime soon and talk cars haha Quote Share this post Link to post Share on other sites
MJW 0 Report post Posted May 29, 2016 Sounds like it will be an awesome car when all done. Where did you get the Vanos rattle kit? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted May 29, 2016 Sounds like it will be an awesome car when all done. Where did you get the Vanos rattle kit? I often wonder if it will ever be all done?!? Rattle kit from here: http://www.beisansystems.com/ 1 Quote Share this post Link to post Share on other sites
MJW 0 Report post Posted May 30, 2016 I often wonder if it will ever be all done?!? Rattle kit from here: http://www.beisansystems.com/ At least yours is driving. My car is in pieces all over the workshop. Doing all the ancillaries while engine is out of the car. Water pump, oil pump, thermostat, upgraded oil cooler, under drive pulleys and new idlers and tensioners, oil seals, frost plugs, main and rod bolts, Vanos overhaul, EGR delete, breather delete from intake into catch bottle, CAI, new coils and plugs, leak test, cat delete, dyno tune. You done the viscous fan delete? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted May 30, 2016 You done the viscous fan delete? I have, but that's literally all I did - remove the fan. I didn't change the thermostat, temp switch or install another fan. No problems so far; touch wood. Although it has been suggested I get an aux temp sensor to keep a better eye on things there. Under consideration. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted May 31, 2016 What did removing the fan actually achieve? Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted May 31, 2016 What did removing the fan actually achieve? Primarily more space to see/work at the front of the engine. Consequentially car also runs cooler but there's a small risk of temps rising in heavy traffic on really hot days. Quote Share this post Link to post Share on other sites
328targa 0 Report post Posted May 31, 2016 What did removing the fan actually achie As mine is a race engine, it spends most of it's life in the high RPM bracket, over 6000 RPM. This can cause the viscous coupling to fail. and a failed viscous coupling leads to a fan going bersec in the engine bay, wrecking everything. So for me was primarily preventative, but it gained a coupel HP on the wheels. I popped in an oversize electric fan on the radiator with a thermostat to kick it in at a lower temp. Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 9, 2016 (edited) Installed these last night and am very happy with the result. Was a real PITA and even cost me some blood but job done. They're aluminium (rather than plastic) with a nice dark chrome finish. Similar to that seen in the Z and later M cars. Got rid of that hideous idiot sticker for the fuel grade as well. Before: After: Edited May 18, 2018 by M3AN 2 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted June 9, 2016 Did you have to use the bmw tool to remove the fan, or did you use the hammer method? Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 9, 2016 Rings look good, shame you took the sticker off though Is it just me, or is your ///M logo monochrome? Sure my M3 had much brighter colors. Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 9, 2016 Did you have to use the bmw tool to remove the fan, or did you use the hammer method? Rubber mallet and long screwdriver to wedge the water pump. Tried it a couple of times first and failed. Then gave it a proper whack and it worked fine. You just need to consider where your swing arc will go if you miss or slip so you can adjust to avoid breakage. It's only really tight if the fan hasn't been removed for ages, now mine just requires a light tap (when it's on). Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 9, 2016 Rings look good, shame you took the sticker off though Is it just me, or is your ///M logo monochrome? Sure my M3 had much brighter colors. Cheers and I can always buy a new sticker if I need it. ///M logo is coloured, just poor lighting and a phone camera to blame. The colours aren't really bright but they are there. Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 24, 2016 (edited) Right, so I collected the start of my upholstered bits today, rear seat assembly and front seat inserts. Also dropped front the bolsters off to get fixed and recovered. Must get on to those door cards or it's going to look a little odd for a while! Edited May 18, 2018 by M3AN 5 Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 25, 2016 (edited) Far from complete but you get the picture. Front seat inserts are just placed in there for the time being and I still need to clean up the fronts properly. Very different, very dark! But I like it. They need some use so that everything starts to settle into place but that'll happen over time. Edited May 18, 2018 by M3AN 4 Quote Share this post Link to post Share on other sites
atlantiskiwi 73 Report post Posted June 25, 2016 Were the recaros a straight bolt in with a kwnz adapter plate? What are they out of? Sent from my SM-N910U using Tapatalk Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 25, 2016 Were the recaros a straight bolt in with a kwnz adapter plate? What are they out of? Yes, with the NZKW base and slider they bolt straight in. I need to raise them ~25mm however because they're too low. They're SR3's out of an Evo IV. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 26, 2016 That looks so much better than that ugly white leather. Really like the recaro. If you dont mind me asking, what sort of money is the work to recover the seats costing? Quote Share this post Link to post Share on other sites
M3AN 4182 Report post Posted June 26, 2016 That looks so much better than that ugly white leather. Really like the recaro. If you dont mind me asking, what sort of money is the work to recover the seats costing? Thanks and no problem... Reupholster supplied rear seat (base/back) retaining existing leather and using supplied material Reupholster supplied front seat inserts (base/back x2) using supplied material Create new front seat base bolster covers (x4) using supplied material Repair front seat base bolsters (x4) = approx. $1000 So, add the seats, the material, the mounting bases, the sliders, the belt buckles, the door cards and you're looking at a silly amount... :-/ Quote Share this post Link to post Share on other sites
