Palazzo 533 Report post Posted April 29, 2014 Mother of god. At least you could have given it some dignity and posted the Fairmont Ghia version. But still incorrect, that car "competed" with the E38. Ford was into the BA buy the time the E65 was released. And the BA is a reasonably smart looking car. In any case, they are more likely to be compared with the 5 series anyways. E39 and E60 Or the XR versions. AU finished in 02, BA started, same as E65? Think you'll find the Falcon is more 7 size than 5. Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted April 29, 2014 (edited) Or the XR versions. AU finished in 02, BA started, same as E65? Think you'll find the Falcon is more 7 size than 5. Probably more Fairlane size as they sit on the station wagon chassis from memory.I think the E65 started in 2001? Edited April 29, 2014 by The Diesel Guy Quote Share this post Link to post Share on other sites
jjs 64 Report post Posted April 29, 2014 Worth a punt if it's cheap enough so you don't care if it blows up. Probably not in that category yet though... When I was a student at Otago (nearly 10 years ago) a good mate bought a 88 750il travelled 300kms as bit of a laugh for $2k thinking he would have heaps of fun until the next WOF then scrap it... He had it for more than 3 years and from memory only did a couple of oil changes and put on one new tyre for a WOF, then sold it and got his $2k back! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted April 29, 2014 was this the days when student loans got paid out in a lump sum? no uni student i know has 2k lying around, luck to have $20! Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted April 29, 2014 E32 750il aren't too complex and were built to last, the E65 is the opposite. Quote Share this post Link to post Share on other sites
jjs 64 Report post Posted April 29, 2014 was this the days when student loans got paid out in a lump sum? no uni student i know has 2k lying around, luck to have $20! Not the good old days with the annual lump sum payment but I remember you got up to $1k "course related costs" - Dick Smith etc used to get so sick of students asking for quotes they had a stack of pre printed quotes for new laptops sitting on the counter Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted April 29, 2014 was this the days when student loans got paid out in a lump sum? no uni student i know has 2k lying around, luck to have $20! That 20 is spent on piss lol Quote Share this post Link to post Share on other sites
Allanw 1081 Report post Posted April 29, 2014 Then again an 7'er of the same era doesn't look like this either. Feast your eyes on the magnificence.. Yep... Deffo looks better than the E65! Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted April 30, 2014 E32 750il aren't too complex and were built to last, the E65 is the opposite. still expensive to sort out/keep on top of though. spent about 2500 or so on my engine alone over last year or two. Mind you its pretty straight now, won't be spending anything on it for a couple years at least now apart from oil changes etc Quote Share this post Link to post Share on other sites
BreakMyWindow 2003 Report post Posted April 30, 2014 Run a scan on that e65. Every single module. Clear any codes, see what comes back after operating every single electronic device. Then make your decision. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted April 30, 2014 still expensive to sort out/keep on top of though. spent about 2500 or so on my engine alone over last year or two. Mind you its pretty straight now, won't be spending anything on it for a couple years at least now apart from oil changes etc Guess it depends on your definition, to me they aren't expensive on the grand scale of things. Ive probably spent 1.5k on my M30 doing the same type of thing as you. Quote Share this post Link to post Share on other sites
Cheyne 17 Report post Posted May 1, 2014 The e65 in the first post is a Singapore import (first clue is the basic Heater Panel installed). My E38 was a Singapore import and I had to spend a fortune replacing everything made of plastic/rubber and also the engine wiring loom because of the heat/humidity. I can't imagine what the Singapore heat and humidity would do to a car like the E65, especially a 2001/02 model that wasn't exactly known for a stable electrical system to begin with. The other problem you'll run into is that it is very common in Singapore to leave your car running when parked so that you can keep the AC going so the KMs shown will likely only be a fraction of the time the engine has actually spent running. In my opinion you'd be better off getting the $6k in $1/$2 coins, put them in a pillowcase and have someone smack you in the nuts with it. It'd be way less painful in the long run. 2 Quote Share this post Link to post Share on other sites
elmarco 56 Report post Posted May 1, 2014 In my opinion you'd be better off getting the $6k in $1/$2 coins, put them in a pillowcase and have someone smack you in the nuts with it. It'd be way less painful in the long run. I think that has to be near the top for quote of the year.... 1 Quote Share this post Link to post Share on other sites
deeveus 81 Report post Posted May 2, 2014 (edited) I think that has to be near the top for quote of the year.... Yep, I think we have a winner. Perhaps two pillow cases (one for each plum) but with 10cent pieces instead. Edited May 2, 2014 by The Diesel Guy Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted May 2, 2014 The e65 in the first post is a Singapore import (first clue is the basic Heater Panel installed). My E38 was a Singapore import and I had to spend a fortune replacing everything made of plastic/rubber and also the engine wiring loom because of the heat/humidity. I can't imagine what the Singapore heat and humidity would do to a car like the E65, especially a 2001/02 model that wasn't exactly known for a stable electrical system to begin with. The other problem you'll run into is that it is very common in Singapore to leave your car running when parked so that you can keep the AC going so the KMs shown will likely only be a fraction of the time the engine has actually spent running. In my opinion you'd be better off getting the $6k in $1/$2 coins, put them in a pillowcase and have someone smack you in the nuts with it. It'd be way less painful in the long run. Outstanding. You need to post more Quote Share this post Link to post Share on other sites
