Tony james 1 Report post Posted April 27, 2015 I need please the cam and crank lock tools as well as vanos setting tools for a 2000 m62b44tu. I'm located In palmerston North. Would be awesome if I could get them by Saturday thanks. Can come pick up if need be. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 1, 2015 Can lend a RTAB tool (only for newer style non flanged bushes), OBD1 Scanner, spring compressors, brake hose spanners and ball joint splitter. In Upper Hutt. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 9, 2015 Looking for a 17mm socket to undo a oil drain plug on my vw. What a nightmare. Nothing else works. Let me know if anyone can lend me one. Otherwise ill go buy one tommorrow no worries Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 9, 2015 Ok gonna see if i have one in my other cars. I tried with a plus sign shaped one i normally use but was too tight to manouver that under the car Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 9, 2015 All done. The oil plug bolt on the vw was so bad. It would warp when using monkey wrench or vice grip. Anyway i was able to borrow the right socket from a nice neighbour and its all done. Yay Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 9, 2015 i have a socket set.. just didnt have that size.. lol Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 9, 2015 All done. The oil plug bolt on the vw was so bad. It would warp when using monkey wrench or vice grip. Anyway i was able to borrow the right socket from a nice neighbour and its all done. Yay Jesus... 4 Quote Share this post Link to post Share on other sites
sonic_attack 89 Report post Posted June 9, 2015 I still live up the road from you don't I? Who doesn't have a 17mm socket kicking around Lol! That's one of life's basic utensils, like a fork or can opener. 3 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted June 9, 2015 I still live up the road from you don't I? Who doesn't have a 17mm socket kicking around Lol! That's one of life's basic utensils, like a fork or can opener. OP would use a fork to open a can.. 2 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 9, 2015 How did u know? Anyway..it was getting late and i didnt realise that it was the same size as a wheel bolt... ha.. Lol im not in the city anymore. Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted June 16, 2015 Can any one lend a DCAN > USB cable for INPA and NCS Expert? ive got the software and laptop. I can pick up in auckland. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted July 20, 2015 Might be needing a car trailer for an e28 this weekend. I would only need it for half a day probably, just moving it from Wellington to Porirua. Does anybody have one that would be available to lend/borrow? Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 24, 2015 does anyone have a long 3mm hex key? has to be about 9cm long. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted July 24, 2015 I do, I'm on the shore though. Welcome to grab it. Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 24, 2015 so.. far... Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted July 24, 2015 yea ill go pick up a set over the weekend. i have those multi hex things on a handle that flip out but its not long enough for this one particular computer. how annoying Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 24, 2015 does anyone have a long 3mm hex key? has to be about 9cm long. I have one you can use. I'm in Otahuhu, so not far from your cafe. Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted July 30, 2015 (edited) Hello, Can anyone lend a N54 walnut blaster manifold cleaning tool? Manafold adapter thing that connects to shop vac for blasting. Cheers Edited July 30, 2015 by FRT Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3047 Report post Posted July 31, 2015 I might be able to get you one to use.. have you got access to a blaster and the walnut shells?? Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted July 31, 2015 (edited) Awesome ok! Yes i have got a blaster and bag of walnuts from countdown.... they look too big to go down but i guess if you have enough pressure and stand far enough back... Edited July 31, 2015 by FRT 3 Quote Share this post Link to post Share on other sites
vtgts300kw 90 Report post Posted July 31, 2015 Please, dear god, tell me that's how you plan on doing this. 4 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3047 Report post Posted July 31, 2015 I've got some nut crackers so we can eat the nuts afterwards.. Or should that be first?? 1 Quote Share this post Link to post Share on other sites
FRT 144 Report post Posted July 31, 2015 Worth a crack!! .... but if that dont fly ill score a bag of turbo walnut shell mix from Syntec (who supply BMW dealers) and get into it. I've got a small compressor but Dave from Autoblast has also offered one of his booths and his meggatron blaster thats got a compressor the size of a small city (and uses the same amount of electricity) that would probably cut my car in half if i held the loud button down for too long. 4 Quote Share this post Link to post Share on other sites
Ahmedsinc 414 Report post Posted July 31, 2015 Still on the scrounge for M5x cam lock tool and crank pin please! Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted August 3, 2015 Just found my dual mass fly wheel removal tool, T60 torx head with tapered shaft if anyone needs to borrow. Quote Share this post Link to post Share on other sites
