Arma 134 Report post Posted September 16, 2014 Think the trans oil on my e39 530i is getting pretty old; no idea whether it's been changed before. How often are these supposed to be changed? (along with the filter)I think the oil has turned black/dirty. Also, will I notice much difference after putting new oil in? Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted September 16, 2014 It uses lifetime oil so you don't need to ever change it, unless you want the gearbox to last more than BMWs 'lifespan' of the gearbox that is Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted September 16, 2014 I've always suggested 100,000km when asked. Oil does not last for ever and yours is black as.... remember when I checked the level for you ?? Quote Share this post Link to post Share on other sites
BreakMyWindow 1999 Report post Posted September 16, 2014 I believe you can't get all the old fluid out without removing the torque converter. You could get a flush machine to try and get all the old fluid out. fwiw my old e39 540i is still going strong with the original fluid - has now done 312,000kms. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted September 16, 2014 Does depend on the conditions and the owner but anywhere from 50,000km-100,000km is what ive seen Just did my "lifetime" fluid and an adaption reset at 222,000km, quite brown but no filings. Shifting may have slightly improved but has elimated the slight torque convertor shudder i had. Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted September 16, 2014 I've always suggested 100,000km when asked. Oil does not last for ever and yours is black as.... remember when I checked the level for you ?? Yup, I was pretty much describing it from what you saw when you checked the level. Might have to bring it around to yours to get the oil changed. Does the filter have to be replaced at the same time? On another note: there seems to be a small coolant leak again - not sure what since the thermostat was replaced and does not seem to be leaking out of the sensor like the last one. So might have to bring it to you for that too . Can definitely see some small particle spray (likely from coolant falling on the belt(s) ). Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted September 21, 2014 You'd be wasting your time to change the fluid without dropping the pan and replacing the filter & Seal. Quote Share this post Link to post Share on other sites
euroriffic 630 Report post Posted September 21, 2014 You'd be wasting your time to change the fluid without dropping the pan and replacing the filter & Seal.Yea just had the e46's done. Was told it was quite horrible fluid and that's at 160,000kms.Shifts a lot nicer now, highly recommend. Quote Share this post Link to post Share on other sites
Auzeras 28 Report post Posted September 28, 2014 Once you do the trans fluid, filter and seal then assuming no trans failure that job is pretty much set for life. Would certainly recommend it for an older 2nd hand vehicle, especially if there's not much else that needs money spent. It's certainly one I'd put off if you've got more major issues though, if it shifts ok now it's not going to cause massive damage in the same way old oil will. You'll not get all the fluid out but unless you've got exceptionally dirty/burnt fluid or lumps of clutch material floating in it I would think a flush or removal of the torque converter to drain the system is a waste of time. If you want to "flush" it without a machine you can empty and refill what you can from the sump a few times with 2000km intervals but to be honest I don't think it's worth it unless you're changing to some incompatible special fluid or the old stuff was really bad. Some transmissions have a mesh filter screens and others have one similar to an oil filter. If it's a mesh one you don't need to change it unless the seal is bad or its damaged. If it's a filter type one change it out. My ZF4HP22 has the mesh type, replaced it because the seal kit came with a new one. Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted September 28, 2014 I'd opt for the full change - fluid, drop the pan and replace the filter - every 100,000km. Flushing may not always be a good idea - this pushes all the old stuff, and any foreign matter through the trans. Or so I've been told. Marshalls in Hamilton did our E46 at something over 200,000 miles... The fluid that came out was thin and water-like, but fortunately no bits of any sort. Marshalls recommend every 25000km, which I think is as much about them making a job for themselves as anything else. (And it'd mean them changing ours 3 times a year at $250 a time...) Quote Share this post Link to post Share on other sites
Arma 134 Report post Posted September 29, 2014 (edited) It's certainly one I'd put off if you've got more major issues though Didn't really have any major issues when I posted this thread. But now I do. Either way, I'll probably get the trans work done after I've repaired the car. Don't really want to keep dirty black oil going through my transmission. Edited September 29, 2014 by Arma Quote Share this post Link to post Share on other sites
Auzeras 28 Report post Posted September 29, 2014 If it's black I'd be right concerned! I assume you just mean old & dirty! Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted September 30, 2014 I've always done mine every 30,000km regardless of the car. On my E39 they drained the fluid and replaced the filter/gasket (fluid was described as very dirty @ 120K). As mentioned you can't get all the fluid out of these cars so I drove with the new fluid for a few thousand km's and then they drained and replaced the fluid only again to get most of the old fluid diluted to the point it didn't matter. Yes, might be overkill but it made me feel better. I noticed a very marginal improvement in shifting quality, really in the E39 you should not be able to feel the shifts. Quote Share this post Link to post Share on other sites
