M5V8 337 Report post Posted September 30, 2014 http://www.trademe.co.nz/a.aspx?id=786907252 Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 30, 2014 All it does is mess with the electronic throttle signal, less pedal requests more throttle essentially Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted September 30, 2014 (edited) So $500 to boost the throttle sensor signal - bargain. A great "performance upgrade" right there, for all those people that can't push the throttle peddle harder.. Edited October 4, 2014 by E30 325i Rag-Top Quote Share this post Link to post Share on other sites
westy 614 Report post Posted September 30, 2014 There be money in snake oils I tells ya! Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted September 30, 2014 It's the same as the Sport button on an e46 M3 Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted September 30, 2014 I can't believe people actively sell junk like this. Quote Share this post Link to post Share on other sites
BreakMyWindow 1984 Report post Posted September 30, 2014 People are dumb. 1 Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted September 30, 2014 doesn't make it right Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted September 30, 2014 SprintBooster works independently with other modifications, making the car 'feel' Quicker and Faster. SprintBooster is simple but effective - it makes the car more responsive and thus... more 'fun'! lol Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 30, 2014 If anyone actually cares to read about how it works http://www.sprintboostersales.com/whyitworks.cfm Often remaps do the same function via drivers wish maps. You can make a car feel faster by just changing it haha Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted October 1, 2014 I would disagree as a "re-map" does exactly that, changing the fuelling, VANOS and ignition maps in the cars ECU which can give increases in torque and power over the factory maps, so there is an actual performance increase. All this module is doing is taking the signal from the fly-by-wire throttle pedal and amplifiying the signal, basically fooling the car into thinking you have got your foot flat to the floor when it is only 1/4 down for example. Not actually doing anything in terms of performance, just saving your ankle a bit of work. Which is what I am trying to get the seller to admit by trolling his auction, just in case there are people dumb enough to buy this crap. Again, I would say that is very different to the Sport button in an M3, which does switch to a different set of maps for the engine, gear shift, etc. suspension settings as well as the throttle response (similar to a re-map but on-demand as it were). 1 Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted October 1, 2014 I would disagree as a "re-map" does exactly that, changing the fuelling, VANOS and ignition maps in the cars ECU which can give increases in torque and power over the factory maps, so there is an actual performance increase. All this module is doing is taking the signal from the fly-by-wire throttle pedal and amplifiying the signal, basically fooling the car into thinking you have got your foot flat to the floor when it is only 1/4 down for example. Not actually doing anything in terms of performance, just saving your ankle a bit of work. Which is what I am trying to get the seller to admit by trolling his auction, just in case there are people dumb enough to buy this crap. Again, I would say that is very different to the Sport button in an M3, which does switch to a different set of maps for the engine, gear shift, etc. suspension settings as well as the throttle response (similar to a re-map but on-demand as it were). Here you go, some basics on drivers wish Quote Share this post Link to post Share on other sites
Auzeras 28 Report post Posted October 2, 2014 $500 to push the pedal faster.. that's a joke right!? Is there any actual legitimate use for this? Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted October 3, 2014 . Which is what I am trying to get the seller to admit by trolling his auction, just in case there are people dumb enough to buy this crap. Good on you Jon. Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted October 3, 2014 I would disagree as a "re-map" does exactly that, changing the fuelling, VANOS and ignition maps in the cars ECU which can give increases in torque and power over the factory maps, so there is an actual performance increase. All this module is doing is taking the signal from the fly-by-wire throttle pedal and amplifiying the signal, basically fooling the car into thinking you have got your foot flat to the floor when it is only 1/4 down for example. Not actually doing anything in terms of performance, just saving your ankle a bit of work. Which is what I am trying to get the seller to admit by trolling his auction, just in case there are people dumb enough to buy this crap. Again, I would say that is very different to the Sport button in an M3, which does switch to a different set of maps for the engine, gear shift, etc. suspension settings as well as the throttle response (similar to a re-map but on-demand as it were). Ummm...where did you get that statement about the sport button on an M3 switching to a different set of maps etc. because I think you are wrong. Anyone else have a definitive answer? Quote Share this post Link to post Share on other sites
jeffbebe 1586 Report post Posted October 3, 2014 Jon does work for BMW so you'd hope he has an idea or two. There's a tonne of hearsay on the interweb from Sport Mode doing nothing but change throttle response through to Sport Mode activating all sorts of features (stiffer suspension, tighter steering, different maps, etc, etc). I can tell you that in the E39 auto, Sport Mode does a lot more than make the throttle more sensitive - it completely changes the shift points and makes the shifts harder and faster. No idea whether it changes the maps but I did read somewhere that it selects from a number of preset maps based on your driving style in economy vs sport. Quote Share this post Link to post Share on other sites
M5V8 337 Report post Posted October 3, 2014 I hated the sport mode in my M5. Made the steering too heavy for NZ driving. Wtgn to Taupo my wrists hurt the next day. Throttle was nicer tho. Quote Share this post Link to post Share on other sites
Haitoman 110 Report post Posted October 3, 2014 I'm talking the E46 M3 sport button. Are you guys talking about the M button? It is a well known fact that on an E46 the sport button does nothing except : http://www.m3forum.net/m3forum/showthread.php?t=123378 Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted October 3, 2014 I thought it injects more snake oil for more power? 1 Quote Share this post Link to post Share on other sites
jeffbebe 1586 Report post Posted October 3, 2014 I'm talking the E46 M3 sport button. Are you guys talking about the M button? It is a well known fact that on an E46 the sport button does nothing except : http://www.m3forum.net/m3forum/showthread.php?t=123378 Not sure if it's a fact but there's certainly a lot of speculation on the interweb. Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted October 3, 2014 All this does is change the voltage curve of the two linear potentiometers (active variable resistors) in the pedal. You can do the same thing by adjusting the throttle map in ECU or drivers wish as Hans has pointed too. Non of this has anything to do with engine maps (fuel, ignition etc) Quote Share this post Link to post Share on other sites
michhod 26 Report post Posted October 3, 2014 Someone buy it an' let us know how it goes..or not Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted October 3, 2014 Can't you like... remap a diesel for just a bit more cost and it gives you a decent power increase? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted October 4, 2014 Can't you like... remap a diesel for just a bit more cost and it gives you a decent power increase? Yes haha, and do the same job at the sprint booster Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3041 Report post Posted October 4, 2014 Terminology is a wonderful thing, have corrected my initial post in this thread. The visual programming tool in the video Hans posted is a great way of understanding the concepts, shame the bloke talking is not though. I wish stuff like that was available when I was coding and mapping ECUs for the early electronic controlled diesel FIE, had to do it old school in hex with assembler/disassembler and EPROM blowers. Still a lot easier than working out the mechanical hysteresis of a spring and lever governor assembly though, so it was progress. Would love to know why you feel a diesel is not as responsive as a petrol though Ron, a lot may depend on your definition of "throttle response"? Quote Share this post Link to post Share on other sites
