M3_Power 636 Report post Posted November 16, 2015 Beautiful!! Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted January 19, 2016 Got a repeating dtc for the bank 2 exhaust cam sensor. Swapped it out for a spare I had from my other M5. Never had any errors on the spare sensors but it's probably on borrowed time. Car was running like a bag of d1cks when the dtc showed up. Hopefully a quick fix. Next up is front discs and pads, the twilight track day didn't help but they were already nearing the end of their life. Will post up some pics when I do the job. 3 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted February 3, 2016 Had a re-occuring fault code to do with the e-box fan which is a small electric fan that draws in air from the outside and in to the box where the DME lives. With a pretty intense summer this year I though it'd be a good idea to replace it. I tried activating the old one in DIS but I could not hear it running. Did the same one with the new one in place and it hummed away nicely. Nothing broken during the process and all back together now. Next job, front discs, pads and wear sensor. 3 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted February 6, 2016 Front discs, pads and wear sensor all replaced. 3 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted February 7, 2016 got your money's worth outa those pads! out of interest (in the 'could I ever afford to run/maintain an e39 M5)... what sort of money (ballpark) do BMW rotors, pads, wear sensors for the front, run you ? Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted February 7, 2016 With bmwccnz discount it was $1200.00 all up. Quote Share this post Link to post Share on other sites
Lewis91 114 Report post Posted February 7, 2016 With bmwccnz discount it was $1200.00 all up. From Jerry Clayton yeah? Thought I saw some large brakes for a chap called Martin haha Quote Share this post Link to post Share on other sites
dkonsta1 109 Report post Posted February 7, 2016 Not too bad for original M5 stuff... Sent from my SM-G925I using Tapatalk Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted February 7, 2016 Yeah genuine bmw brakes are the best bet imo for this kind of car. 2 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted February 7, 2016 Wow that little venting fan for the DME is so cool. Quite a good idea too. What are you doing with the old unit? Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted February 8, 2016 With bmwccnz discount it was $1200.00 all up. thanks for that. given they're factor, big-ass floating rotors, not excessive. I'll put an M5 on my santa/lotto win list. #8 ) Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted February 8, 2016 Wow that little venting fan for the DME is so cool. Quite a good idea too. What are you doing with the old unit? I tested it with a 9v batt and it appears to be dead, probably just the elec motor. It's yours if you want it. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted April 26, 2016 Uh oh. A noise has cropped up in the past 1000kms and I've decided to investigate. An interesting rattle that occurs only under high load in higher gears. Quote Share this post Link to post Share on other sites
jeffbebe 1587 Report post Posted April 27, 2016 I hate new noises. Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted April 27, 2016 Flywheel? Maybe even heat shielding came loose somewhere? Obviously there's a bit more vibration under high load in a higher gear so something may have just come loose..Hopefully not anything serious. Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted April 27, 2016 Yeah i need a hoist to go over any loose heat shields, exhaust clamps etc. Doesn't affect drive ability, just a heinous rattle sound.. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 28, 2016 Annoying. Probably a good time to sell it. Jk Quote Share this post Link to post Share on other sites
M3AN 4191 Report post Posted April 28, 2016 "Heinous rattle"? It's a lost cause, give it away more likely. Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted May 12, 2016 Think I may have found a source of the rattle.. The header exhaust section connecting to the cats is of double-walled construction. The PO had removed the cats and replaced with straight piping. If I knock the exhaust around this area I can hear metal on metal rattling inside the exhaust. Bit of a pain as it means the exhaust needs to be cut, investigated and repaired. I did a lot of research on the rattling and it seemed to point to the early signs of head gasket failure, the type of failure where the gasket gets cracked in between the cylinders. I decided to do a compression test on the engine this morning and can confirm all is well. Results, Cylinder 1-8 in PSI 206 217 217 216 206 206 206 203 Quote Share this post Link to post Share on other sites
M M 250 Report post Posted May 12, 2016 I did a lot of research on the rattling and it seemed to point to the early signs of head gasket failure, the type of failure where the gasket gets cracked in between the cylinders. I decided to do a compression test on the engine this morning and can confirm all is well. Forgive me, but I fail to see the relation. Could you explain? Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted May 12, 2016 Based on research this is more of an issue with the s54 engines. There is about 4mm of material between the cylinders of the s54 and s62 engines, so there is not much gasket material there either. The cause of this could be several reasons... lean mixture, faulty gasket material etc The rattling sound, under medium throttle in higher gears at lower revs produced a rattling type sound for many of the S54 owners, and I could only find 2 concrete examples of other s62 engines with the same symptoms that turned out to be the result of HG failure between the cylinders. I was lucky enough to find a sound clip of the rattling sound from one of the S62's with HG failure. I've added this as a play list with my sound clip to compare the sound, and it was quite the same. S62 head gasket failure : S54 head gasket failure : 1 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 12, 2016 I had a m54b30 with gasket like that a few years back , low compression on number 3 and 4 cylinders but not loosing any coolant etc . engine had been hot I guess , various signs or hoses and coolant plastics been replaced . car ran ok then would start to miss fire then the engine check light would come on. Quote Share this post Link to post Share on other sites
M M 250 Report post Posted May 12, 2016 Right, I understand. Quote Share this post Link to post Share on other sites
BreakMyWindow 1995 Report post Posted June 1, 2016 Wheel alignment done! 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted June 1, 2016 yay P&S Auto, they're a pretty good bunch down there. Quote Share this post Link to post Share on other sites
