duvey 245 Report post Posted June 4, 2016 P&S are the best. Only place I know of in Auckland you can trust to actually do a proper wheel alignment. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted June 9, 2016 New windshield wipers and a nose job. Before : After : Fitment is spot on. Not bad for Made in Taiwan 2 Quote Share this post Link to post Share on other sites
dkonsta1 109 Report post Posted June 9, 2016 Would you sell the chrome ones? I am desperate to get them for my 540i Sent from my SM-G925I using Tapatalk 1 Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted June 9, 2016 No more sikaflex! 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted June 9, 2016 No more sikaflex! That was the other M5... Sorry Russell ! 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted June 9, 2016 Would you sell the chrome ones? I am desperate to get them for my 540i Sent from my SM-G925I using Tapatalk Sure. PM me. Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted June 21, 2016 Decided to give the interior a bit of a spruce up and make it a better place to be. The driver seat has some typical bolster wear and the leather was looking a little shiny in areas. Using a 10:1 mix of meguiars all purpose cleaner, a bore hair brush and half a dozen microfibre towels, the seats and leather surfaces are much cleaner. Not a fan of leather conditioner so I only applied it to areas exposed to UV rays and wear and tear i.e inner door handles and seat bolsters. Drivers seat before : Cleaning process : After a few hours of vacuming leather cleaning and further detailing : Finished of with a thorough cleaning of the steering wheel. Amazing how much grime accumulates. Used the same cleaning process as for the leather in the rest of the interior : 10 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted August 21, 2016 Today marks 100 years of the BMW AG. In prep for the 100 year anniversary drive with the BMW ccnz I spent about 350 minutes cleaning the M5. First clay bar and wax since the ocd treatment last November. Before : After : 6 Quote Share this post Link to post Share on other sites
kulgan 1042 Report post Posted August 21, 2016 So much want in one post. Looking awesome Martin. 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 21, 2016 Mint Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted November 13, 2016 (edited) On 12/05/2016 at 3:16 PM, BreakMyWindow said: Based on research this is more of an issue with the s54 engines. There is about 4mm of material between the cylinders of the s54 and s62 engines, so there is not much gasket material there either. The cause of this could be several reasons... lean mixture, faulty gasket material etc The rattling sound, under medium throttle in higher gears at lower revs produced a rattling type sound for many of the S54 owners, and I could only find 2 concrete examples of other s62 engines with the same symptoms that turned out to be the result of HG failure between the cylinders. I was lucky enough to find a sound clip of the rattling sound from one of the S62's with HG failure. I've added this as a play list with my sound clip to compare the sound, and it was quite the same. S62 head gasket failure : S54 head gasket failure : Finally fixed the engine rattle. A lifter was either dry or getting blocked under certain conditions i.e high engine load. On cold start it would occasionally chatter for a couple of seconds. It seems two oil and filter changes in 12,000kms has cured it. No more rattle or cold start lifter tick. Now to fix low speed brake squeal Edited November 13, 2016 by BreakMyWindow 3 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted March 9, 2017 New Shoes and a fancy wheel alignment that uses Lasers. 4 Quote Share this post Link to post Share on other sites
NZ BMW 368 Report post Posted March 9, 2017 Out of interest who did the alignment? 1 Quote Share this post Link to post Share on other sites
BM WORLD 1294 Report post Posted March 9, 2017 hhhhhmmmmmm nice mufflers 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted March 9, 2017 4 hours ago, NZ BMW said: Out of interest who did the alignment? Bmworkshop in Grey Lynn. 1 Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted April 22, 2017 Mowed the lawns on a paddock today with it... 4 Quote Share this post Link to post Share on other sites
jeffbebe 1560 Report post Posted April 23, 2017 Sweet!! Pity the 8er is too low or I'd have come too! Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted April 24, 2017 And another clip of me being a bit too keen with the throttle..... 4 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 24, 2017 Best sounding lawn mower, ever. Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted July 22, 2020 Sorting out the rear door vapour barriers (VB’s). They started leaking about 3 years ago, but not bad enough to soak the carpet thankfully. Back then i decided to use some butyl mastic in a caulking gun which turned out to be a temporary fix. This attempt I’ve decided to go with the official bmw procedure using new VB’s as the old ones I couldn’t bear cleaning off old butyl. Below is a description of the procedure. So starting with removing the old VB I then heated up and scraped off as much butyl as possible from the inner door panel. Using a rag and some prepsol I managed to fully clean off all the old butyl followed by a wipe down of the contact area with isopropyl. Then apply fresh butyl tape to the VB leaving the wax paper on. Offer it up to the door panel. Peel the wax paper off as you press down until the VB is fully attached to the inner door panel. Heat up the perimeter of the door panel and use a seam roller to press down on the butyl for good adhesion. Instructions say to let the butyl “set” for 5 hours before doing and load tests (i.e leak test, open/closing door). Fingers crossed this is a lasting repair. 2 Quote Share this post Link to post Share on other sites
Eagle 1755 Report post Posted July 22, 2020 How much are new ones? Local I assume? Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted July 22, 2020 2 hours ago, Eagle said: How much are new ones? Local I assume? Local i was quoted between 150 and 190 + gst depending on if they needed to be ordered ex Germany. FCP euro were $40usd ea so went with that. No gst to pay either. 2 Quote Share this post Link to post Share on other sites
Eagle 1755 Report post Posted July 22, 2020 Shipping is cheaper than i expected. Although they are listed for $61 usd now. Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted July 22, 2020 10 minutes ago, Eagle said: Shipping is cheaper than i expected. Although they are listed for $61 usd now. Whoops, yeah they were 61usd ea Quote Share this post Link to post Share on other sites
BreakMyWindow 1950 Report post Posted October 14, 2020 A belated 21st present has been ordered for the M5. - Clutch kit and at the same time a shifter rebuild using some new bits I have had stored away. -full suspension kit including shocks, all arms, ball joints, steering parts etc. Everything except subframe bushes and wheel bearings. diff bushes, diff seals, drive shaft cv, centre bearing and flex coupling were replaced in late 2018. -valve cover seals, air filters, cabin filters and fuel filter. Oil change to be done at same time. Be a good opp to also fit 4 new CPS's i've had in storage too. Planning to take it down to the end of the south island next year and will be looking forward to driving it on all the fresh parts. 9 Quote Share this post Link to post Share on other sites
