Andre3000 55 Report post Posted September 21, 2015 I have a family member looking at buying an e46 m3. Having only a small amount of experience with this model I want to know the inherent issues, common faults, things to look for and avoid. If anyone could share their findings either from ownership or preferably a BMW tech I'd be very grateful. Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted September 21, 2015 Owned one for 4 years and use it daily. Clocked up 60,000 kms and the cars done 107,000 kms Went against internet and bimmersport M3 E46 buyers advice guide and brought a 2002 (April) with SMG. Wanted an M3 with less than 50,000 kms . Drove a few and this one was nice and tight and seemed have a bit more go for some reason. Car has most options except headlight washers, electric seat bolsters and 19 inch wheels (prefer tyre choice options in 18s) Issues Rear view mirror dimming failed shortly after purchase (replaced mirror glass ($130 usd) Power Steering hose developed leak. ($500 ish , gold plated part ? ) CD stacker played up after track day. (DYI repair, lub required $15 ) Maintenance Usual services (intervals 24,000 km) Front rotors and pads @ 77,000 km ($1800) Rear rotors and pads @ 92,000 km ($1000 ish) Tyres 53,000 km Bridgestone Re11's ($2,200) Tyres 106,000 km Michelin PSS ($2,200) AMG Battery @ 95,000 km ($500) Mods Run 235/40/18 & 265/35/18 on factory rim rather than 225/45/18 255/40/18 standard size (don't see DSC warning light flash as much) Stereo project $NDA encase wife sees this (BM53 tuner mods for sound quality , kilowatt of headroom, carpc integration) Mk4 Nav with 2014 map , Bluetooth ULF SMG re-flash with Z4mcoupe software (smoother auto changes) Thinking of CSL load next with DME mods ISOfix top tether brackets Dyno ( car is supposedly standard, 56,000km 307 rwbhp , 90,000km 302 rwbhp on dynopack dynos) which is 20 - 30 above what it should be. Good bits Car corners like on rails SMG grin factor Shift lights on tacho with sMg with upper shift programs Xenon headlights , high beam is fantastic Nav options with rev camera (don't back over kids toys) Grip in wet and ability to put power down (see tyres) Cross wind has little effect on car Stable at speed and under hard braking (Taupo track) Induction sound / exhaust rasp Bad bits Hitting cats eyes / highway joint sections Ride on rough roads Stop start traffic uphill with SMG SMG in reverse gear (fine line between moving slightly and moving lots ) Handbrake goes off every couple of years Rubberised trim easy to mark and scuff No Aux in on factory radios / nav until late 2002 Factory hifi option is very average, HK system slightly better. What I'd change / add if money was no object Supercharger ECS 530hp option BBS e88's on 18's 245 / 275 combo P Plate 3 Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted September 21, 2015 It's a pretty heavily documented car so if you have a bit of a search there's no shortage of information Quote Share this post Link to post Share on other sites
MISS BM 712 Report post Posted September 21, 2015 Saw this one a few days ago. Highly recommend. Excellent car. Don't let SMG deter you - loved mine. No problems given you look after them. I'm in the market for another one, but yet to see the right one pop up - I have a demanding list which seems impossible to achieve haha. 1 Quote Share this post Link to post Share on other sites
allan 295 Report post Posted September 21, 2015 (edited) E46 rear sub frame problem does this also apply to the m3. Oh on the early SMG pump/ Hydraulic system give trouble also. Edited September 21, 2015 by tim 325 Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted September 21, 2015 Owned one for 4 years and use it daily. Clocked up 60,000 kms and the cars done 107,000 kms Went against internet and bimmersport M3 E46 buyers advice guide and brought a 2002 (April) Apparently there's a sticker in the boot that shows if recall work was done - The 2002 ones had bearing issues and had a recall done as part of this to have the bearings replaced as they apparently failed at around 20,000km. But as far as I know the bearings were just replaced with more cheap chinese ones that were used in the first place? Might pay to find your sticker and see if this was done Quote Share this post Link to post Share on other sites
Rubix 434 Report post Posted September 21, 2015 E46 rear sub frame problem does this also apply to the m3. Yes yes and yes. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted September 21, 2015 Talk to Tom, Andrew. If there's something he doesn't know about these cars it isn't worth knowing. 1 Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted September 22, 2015 Here's the "scare" list that us owners propagate on the internet to keep prices low and second hand options up ( might be some truths ) Window regulators fail Smg pumps fail at an alarming rate smg relays fail Manual gearboxes chew out syncros on second gear which equals box replacement Subframes fail at rear Bearing recall and replacement bearing failure ( get oil analysis done every now and then) Vanos seal failure Vanos bolt failure pre 2003 Diff clunk DIFF BOLTS ALTERNATOR failure Bm53 tuner module failure Airbag seat occupant senor mat failure Oil pump failure Nav screen failure Amp failure Rear view mirror acid of death failure Rear window aerial amp failure Rotor warping DSC module failure Some of these items can be viewed as preventative maintenance items such as diff & vanos bolts. Others can be roll of the dice. Just got to remember they are a 9-14 y/o car. Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted September 22, 2015 Best way to check bearing condition is to sample engine oil and have a report done similar to what many truck owners do. I haven't checked my own service advisory recall status, but oil analysis has come up with little signs of bearing wear. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2152 Report post Posted September 22, 2015 Best way to check bearing condition is to sample engine oil and have a report done similar to what many truck owners do. I haven't checked my own service advisory recall status, but oil analysis has come up with little signs of bearing wear. how would one go about having a test done? whom? price? Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted September 22, 2015 http://www.oillab.co.nz/home Think its about $45. They send you a kit, you fill up a bottle with oil and post it back to them. Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted September 22, 2015 That's the one. Plenty of USA M3 owners do this as well just to check engine change as there are rumours of the bearing recall bearings still wearing. The other thing of note is the condition of the oil at the standard change intervals has been fine at 24,000 km. Still within spec but I'd only do this if the car is being used daily with decent amount of run time. Quote Share this post Link to post Share on other sites
M3AN 4155 Report post Posted September 23, 2015 VANOS hub failure isn't mentioned above (that I saw). Replace with upgraded unit when you do the bolts, solenoids and seals. If VANOS hasn't been completely overhauled (with receipts etc) take $2k off the price. Quote Share this post Link to post Share on other sites
