HaNs 226 Report post Posted February 18, 2017 1 hour ago, _ethrty-Andy_ said: what are you doing for CCV system or have you deleted etc? Not sure yet. Quote Share this post Link to post Share on other sites
M3AN 4191 Report post Posted February 19, 2017 Sexy. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 21, 2017 First Drive went. Need to re balance them as need be able to adjust idle better. Also removed a few extra emission systems and brackets for more room to work 4 Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted February 21, 2017 What engine electronics are you using with the ITBs? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted February 21, 2017 1 hour ago, turbolizard said: What engine electronics are you using with the ITBs? Factory ms41 for now. Hence the maf. Uses factory tps also. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted May 31, 2017 Power gains from just ITb's and exhaust, next up tuning Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 15, 2017 Good day at Taupo on the weekend for a shakedown 6 Quote Share this post Link to post Share on other sites
turbolizard 38 Report post Posted June 15, 2017 Car is looking really good. What was the Taupo event? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 15, 2017 10 minutes ago, turbolizard said: Car is looking really good. What was the Taupo event? Just a private track day Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 24, 2017 Dual sprints at Taupo today. Good fun. Cold and slippery. Need some driver training to go faster and loose some weight from the car (and myself lol) Think I may incest in a nibbler and trim underside of bonnet, boot lid and rear 1/2 panels. Also a few bits of interior deadning to go Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 24, 2017 Car looks great Hans. Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted June 29, 2017 Trying some thicket oil to shut up the top end 1 Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 5, 2017 Oil sorted the top end noise. Did 135km of track work today at Taupo. Best was 1.23.22. Optimal was 1.22.09. Racechrono linked to a go pro, just need a dash mount my tablet. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 5, 2017 Sounds awesome. What output is this 328i achieving on the dyno? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 5, 2017 8 minutes ago, Michael. said: Sounds awesome. What output is this 328i achieving on the dyno? High 13x kw. Want to go to a link ecu next year 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 5, 2017 15 minutes ago, HaNs said: High 13x kw. Want to go to a link ecu next year How much more kw do you think you will be able to achieve by going to the link ecu? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 5, 2017 9 hours ago, zero said: How much more kw do you think you will be able to achieve by going to the link ecu? 150 should be possible. It's a cost vs gains thing 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted July 6, 2017 That's pretty decent, would make for a fun driving package where you can use ALL the power & get the most out of it. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted July 6, 2017 Looks like a real nicely sorted car! Good work on the ITB set up and nice power gain Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 6, 2017 31 minutes ago, Michael. said: That's pretty decent, would make for a fun driving package where you can use ALL the power & get the most out of it. I want a s54 but big $ Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted July 6, 2017 On 6/24/2017 at 5:19 PM, HaNs said: Think I may incest Thought I should point it out Have you considered getting some upgraded cams? I may have an option for you that will have a decent kw/$ return Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 6, 2017 8 minutes ago, thorburn said: Thought I should point it out Have you considered getting some upgraded cams? I may have an option for you that will have a decent kw/$ return Yeh I have. But to make full use of them if want a link ecu. But if I went to the efforts of cams id just build 3.0 and drop it in Quote Share this post Link to post Share on other sites
BatMansWilly 74 Report post Posted July 6, 2017 22 minutes ago, HaNs said: Yeh I have. But to make full use of them if want a link ecu. But if I went to the efforts of cams id just build 3.0 and drop it in What model of Link ECU would you put in? Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted July 6, 2017 27 minutes ago, BatMansWilly said: What model of Link ECU would you put in? Xtreme But do I just go buy a s54? 1 Quote Share this post Link to post Share on other sites
