_ethrty-Andy_ 2136 Report post Posted May 16, 2016 (edited) So odd question.. but there must be a reason that wall insulation is different to roof, or is it all just marketing? i have a bale left over from renovations and am thinking i might use it in the garage now we are coming in to winter. particularly concerned if there is any added fire risk. edit: it is a versalite garage or whatever they are called, the kit set type. cheers Andy Edited May 16, 2016 by _Ethrty-Andy_ Quote Share this post Link to post Share on other sites
richard 384 Report post Posted May 16, 2016 you can use wall batts in the ceiling but not ceiling batts in the walls different R ratings, I can't see a fire risk. Quote Share this post Link to post Share on other sites
aja540i 1908 Report post Posted May 16, 2016 Roof insulation usually has a higher R rating, wall insulation has to fit in a 90mm cavity, roof insulation can be thicker, otherwise its the same. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted May 16, 2016 great thanks guys!! Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 16, 2016 Its the same - just a different shape. Check r ratings too Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 16, 2016 you can use wall batts in the ceiling but not ceiling batts in the walls different R ratings, I can't see a fire risk. Other way round mate. 1 Quote Share this post Link to post Share on other sites
westy 614 Report post Posted May 16, 2016 Oh yeah they're different sizing too for different framing spacings. Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 16, 2016 Throw them in Andy. No issues with fire rating. Wall insulation is generally 90mm and have a lower 'R' value than ceiling which is significantly thicker. Quote Share this post Link to post Share on other sites
allan 295 Report post Posted May 16, 2016 Need a bit more info Andy are they wall batts or ceiling should say on the wrapping? If wall batts should be no problem if ceiling might be wrong size and need to be cut plus protrude out passed the stud edge and course some problem if you are going to line that area later. The reason is the wall batts are generally sized to fit the stud spacing most homes are either 600 or 400 centres . The last time I fitted these the wall batt rating was 2.8 and ceiling 3.2 or greater I believe and at 2.8 one could start to feel some resistance the gib sheet was being fitted. To get the max out of the batts and your time in fitting them they need to be fitted neatly not compressed or loose in the spaces. Also does the garage have building paper or not? Quote Share this post Link to post Share on other sites
kiwi535 538 Report post Posted May 16, 2016 (edited) you need to ensur the insulation wont get wet from consensation,Of course that will apply to the walls and the roof of your versatile garage.as others have said wall batts are up to 90 mm thick,ceiling can be 150 mm thick,and cut to different widths Edited May 16, 2016 by kiwi535 Quote Share this post Link to post Share on other sites
MattA 165 Report post Posted May 16, 2016 Just be mindful insulating around light fittings if you have a ceiling and recessed lights. Some info here, will be the same if you're using other brands. http://www.pinkbatts.co.nz/installing-insulation/installation-instructions/ Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2136 Report post Posted May 17, 2016 its just a tin shed and i have a bag of insulation. dont really need to over complicate the whole thing! 1 Quote Share this post Link to post Share on other sites
3 SERIES 93 Report post Posted May 17, 2016 You should really be looking at doing an H1 calculation and submit this to the HCC for approval. You'll probably get away with doing the schedule method in this case. Let us know how you get on. 2 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 18, 2016 its just a tin shed and i have a bag of insulation. dont really need to over complicate the whole thing! Well you will definitely need a council permit then Quote Share this post Link to post Share on other sites
jom 98 Report post Posted May 18, 2016 Need a bit more info Andy are they wall batts or ceiling should say on the wrapping? If wall batts should be no problem if ceiling might be wrong size and need to be cut plus protrude out passed the stud edge and course some problem if you are going to line that area later. The reason is the wall batts are generally sized to fit the stud spacing most homes are either 600 or 400 centres . The last time I fitted these the wall batt rating was 2.8 and ceiling 3.2 or greater I believe and at 2.8 one could start to feel some resistance the gib sheet was being fitted. To get the max out of the batts and your time in fitting them they need to be fitted neatly not compressed or loose in the spaces. Also does the garage have building paper or not? Love "ceiling might be wrong size". Just resize your roof then. :-) Seriously, with a vapour barrier, any insulation is going to be an improvement.... Quote Share this post Link to post Share on other sites
