alisterh 26 Report post Posted October 31, 2016 (edited) Hi, A few people have asked my how I did my swap so I thought I should clear some myths and put it in a permanent place. The reason I chose this swap its cheap, easy and the drive train is already capable. The e30 is my Girlfriends daily so I wanted it off the road as little as possible. The e30 had a very ticky m40 and was on its last legs, the donor car was a 1995 318ti but any m42 car will be fine but a non ews model would be ideal. Below is the list of parts from each car used. e36 318ti m42 e30 m40 e30 m42 Engine Engine arms Exhaust Manifold DME Engine mounts Engine loom (x20) Upper and lower Oil pans 1994 DME (no ews) Gearbox/clutch/driveshaft etc. Power steering pump Fan and fan clutch Alternator Throttle cable with part No. 13541288013 dip stick (needs bending) Brown Temp sensor (swap with black temp sensor on m42) Starter motor As you can see all the parts except the exhaust manifold are from the E30 or the donor 318ti. I sourced the exhaust manifold from e30zone in the UK and was $250 delivered. The only custom parts were the coil bracket (soon to be COP), the exhaust manifold to existing exhaust and the c101-x20 adapter. I treated the c101 to x20 adapter just like an m50 swap, below is my adapter table Pin No. C101 Colour Pin No. X20 Colour 1 Charge light Blue 25 Blue 2 Static oil level Green/Yellow 1 Blue/White 3 4 Temp Guage Brown/Purple 12 Brown/Yellow 5 Oil Pressure Light Brown/Green 23 Brown/Grey 6 Oxygen Sensor relay Green/White 22 Green/White 7 Switched power Green 21 Green/White 8 Fuel rate input White/Black 24 White/Black 9 Engine Speed imput Black 20 Black 10 Dynamic Oil Level Blue 2 Blue/Yellow 11 Reset Service Lights White/Green 19 White/Green 12 Check engine light Grey(brown) 8 Grey 13 Fuel pump relay Green/Purple 13 Green/Purple 14 Speed signal for ecu Black/White 14 Black/White 15 Unloader relay Black/Green 15 Black/Green 16 Diagnostic White/Black 17 White/Purple 17 18 Start Black/Yellow 18 Black Yellow 19 20 Overall it was a very easy swap, this was my first time pulling an engine and was completed by me and a friend in a long weekend. Hope this helps others in the future. Cheers Edited October 31, 2016 by alisterh 4 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted October 31, 2016 Cool. I really like the m42 engines. Quote Share this post Link to post Share on other sites
NZ300E 44 Report post Posted October 31, 2016 Sounds like a great repower without breaking the bank. When you say cheap, what do you mean.....all up......2....5.....10k.....not including labour of course because it was a diy job. Curious to see if it might be an option for my car. Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted October 31, 2016 36 minutes ago, NZ300E said: Sounds like a great repower without breaking the bank. When you say cheap, what do you mean.....all up......2....5.....10k.....not including labour of course because it was a diy job. Curious to see if it might be an option for my car. Under 2K, donor car was $550, exhaust manifold was $250, custom exhaust work was $280, 1994 ECU was $80, c101 adapter was made from loom cuts from zebra car parts $20. I also spend $500 on preventative maintenance water pump, vacuum lines, oil, filter, coolant etc. It looks like your car is 320i though so some of the m40 parts you would need to find as well. Quote Share this post Link to post Share on other sites
NZ300E 44 Report post Posted October 31, 2016 Cheers for that. Got me thinking. Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted March 13, 2017 (edited) The car is now certified which ended up dragging out a lot longer than I expected mostly due to small issues unrelated to the swap. Also did a coil on plug conversion which really cleans up the engine bay. Overall the car feels great, way more e30s should of come to NZ with this engine car feels so light and loves to rev. Next up is a bit of a Hartge tribute (body kit and wheels) Edit: Also forgot to mention that driveshaft loops weren't required due to unmodified driveshaft and less than 50% power increase. Edited March 13, 2017 by alisterh 2 Quote Share this post Link to post Share on other sites
agent75 37 Report post Posted March 13, 2017 I am very seriously keen on doing this swap. I take my E30 to the track and love the 4 cylinder weight and feel, but struggle with the bad case of asthma my m40 has. hmmmmmmmm. Thanks for posting this Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted June 30, 2017 I'm now looking at doing this swap on my E30, did you swap over the engine loom and ecu aswell? I'm picking up a 1995 ti with everything I'll need. Where abouts are you located? Im keen to find out how it all went. I'm swapping out the old and blown M40 Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted July 1, 2017 Yeah you need to use the 318ti engine loom and you will need to find a pre 1995 ecu or buy a ews delete chip. I'm located in Auckland. The swap has gone well, the car is daily driven by my girlfriend and has never let her down. Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted July 1, 2017 8 hours ago, alisterh said: Yeah you need to use the 318ti engine loom and you will need to find a pre 1995 ecu or buy a ews delete chip. I'm located in Auckland. The swap has gone well, the car is daily driven by my girlfriend and has never let her down. Sweet so I'm getting a semi complete 1995 318ti body(everything except engine and wiring and ecu gone) from Christchurch and once I get it back here to Nelson I'll get it all installed into my e30, I'll most likely make an exhaust manifold from the ti one. Can I just find an earlier ti ecu and it will work? Or is there still more work involved? I'm very keen as I've been trying to research this so much and really glad I've found someone who has put it into writing which is going to help no end! Im looking forward to having a little pocket rocket e30 ?? Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted July 1, 2017 They ecu you need is plug and play but it's probably just easier to buy a chip from eBay for less than $40. I have heard from a few people that a m44 manifold bolts on and clears the steering linkage without modification so that may be an easier option. Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted July 4, 2017 I see those chips on eBay. Once I get the m42 to mine I'll have to collect up the last bits I need for the swap as it doesn't have an alternator and starter motor or even the power steering pump with it but I I can get m44 parts in Nelson fairly easily so should be able to make something work. What did you do for radiator hoses? Use the m40 ones? Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted July 4, 2017 I ended up using a mix of e30 m40 hoses and the 318ti hoses. I cant remember exactly but some required trimming. Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted August 19, 2017 I've now got myself the m42 out of the ti I bought, with everything ready to do the swap. The ti I got everything from is an auto 01-1995 and i don't think it's got ews. The key reader isn't plugged in and key is the older style key. This is my first engine swap, the wiring that you did what are the ones that are crossed out in the table? Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted August 19, 2017 From memory the ones crossed out are only required if you have a overhead check panel, usually only found in 6 cylinder cars. Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted September 2, 2017 I've now got the m42 in the e30 ready to finish up tomorrow/today. How did you send your dipstick tube? I can't see how I can make it work. Using the e36 one also there was two connectors on the ecu end of the m40 loom a black and white one. Are they significant to anything? Quote Share this post Link to post Share on other sites
alisterh 26 Report post Posted September 3, 2017 Here is where my dip stick tube ended up, was just a bit of trial and error really. From memory I don't remember worrying about those black and white plugs. 1 Quote Share this post Link to post Share on other sites
will 169 Report post Posted September 3, 2017 Black and white plugs are for A/C leave them unconnected unless you have A/C. EWS is simple to wire in so dont worry if it does have it. Quote Share this post Link to post Share on other sites
HEQ841E34 0 Report post Posted September 4, 2017 I gave my dipstick tube a good bending. Will most likely need some more tweaking. Mine has a/c but not sure if I will bother trying to fit it back up to the m42 as belts are different etc. now I just need to get a top hose sorted and make up an exhaust manifold that'll work. And tidy up th wiring side. Quote Share this post Link to post Share on other sites
e30seattle 0 Report post Posted December 5, 2018 Stumbled upon this forum looking for more information on ews. I have a 1984 e30 318i and it had an m10 in it as you probably know which blew so I needed a cheap "quick" swap. So doing my research I decided to go with m42 out of an 1995 e36. I got it all installed had a custom wiring harness made and got it all hooked up and it cranks over but wont start. boiled it down to the ews and was just wondering if i could get the dme out of an e30 m42 or should i get a earlier <1995 e36 ecu? any help would be greatly appreciated. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted December 5, 2018 For what it's worth it have a 94 date stamp ecu with EWS You can have it removed Quote Share this post Link to post Share on other sites
e30seattle 0 Report post Posted December 12, 2018 I put in the 1994 ecu into my e30 and still nothing. No fuel no spark. Could this be because I am using an e30 m42 wiring loom instead of a e36 m42 wiring loom? But the motor is out of an e36. Quote Share this post Link to post Share on other sites
eliongater 718 Report post Posted December 12, 2018 That sounds like EWS? Post a picture/the number on the ECU? Quote Share this post Link to post Share on other sites
Tuonome 0 Report post Posted September 5, 2022 Hi I bought an e36 318ti for a donor for my 1989 316i e30, I have stripped the e36 ti and I was wondering if the m42 engine from the e36 goes onto the e30 subframe? Or do I use the e36 ti subframe? Quote Share this post Link to post Share on other sites
nick496 273 Report post Posted September 5, 2022 Pretty sure it's just the engine mounts from your old m40 go onto the m42. No subframe swapping required. Not that you can easily swap the front subframes. 1 Quote Share this post Link to post Share on other sites
