Gaz 1077 Report post Posted November 17, 2017 So I've had this for almost 2 years now so thought it was time to throw up some photos. This is how it was when I first got it Had to ditch those wheels first up so ran some bottle caps before picking up so BBS Rs 039 and 040 off a 4 stud skyline so had them redrilled and then plasticdipped them for some fun and dropped it on some super lows. Then headed up to megameet 16 with a couple of mates Not much happened in the first half of the year except ditching the horribly loud muffler and fitting something more sane. Picked up a tech 2 kit and aplina boot spoiler for it so painted and fitted those in time for megameet this year. Next step is coilovers as I managed to blow a shock on the trip to megameet and find a solution to fitting some tech 2 sides. I have a set for a couple but the lower sill cover is very different on the verts. And hopefully widen the RS' but also have a baby on the way next so will see how that all goes Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted November 17, 2017 hehe those wheels it came with were priceless 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted November 17, 2017 And it has something like 20mm BMW centres on them too! Hahaha 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted November 17, 2017 To be fair to the previous owner he spent some money on it for sure but it's not to everyone's tastes ? Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 4, 2020 Over two years since I last updated this, wow... Yellowspeed coilovers have been fitted, I did buy some brand new genuine lower sill covers. Just need to get them painted and fitted. I've started a manual conversion on it just need to put the gearbox back in and bolt the driveshaft up. Fixed rocker cover gasket leak and painted the cover while it was off. And during lockdown, had enough time to get these all finished! Happy how these came out, just need some tyre valves and we are are away. Final specs are 16x9 et0 and 16x9.5 et6. Bit more aggressive than i intended but should still look alright 5 1 Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted May 4, 2020 7 hours ago, Gaz said: Over two years since I last updated this, wow... Yellowspeed coilovers have been fitted, I did buy some brand new genuine lower sill covers. Just need to get them painted and fitted. I've started a manual conversion on it just need to put the gearbox back in and bolt the driveshaft up. Fixed rocker cover gasket leak and painted the cover while it was off. And during lockdown, had enough time to get these all finished! Happy how these came out, just need some tyre valves and we are are away. Final specs are 16x9 et0 and 16x9.5 et6. Bit more aggressive than i intended but should still look alright Looking forward to pics on the new coils and rims! Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 4, 2020 Thanks mate, once I find a new job then it'll be all go! Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted May 4, 2020 Has the dealership closed down Gareth ? Quote Share this post Link to post Share on other sites
Mikan 173 Report post Posted May 4, 2020 Looks great - those wheels are gorgeous! 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted May 4, 2020 1 hour ago, B.M.W Ltd said: Has the dealership closed down Gareth ? No it's still kicking. I left at the start of the year to pursue something else, unfortunately that hasn't worked out due to the current situation so currently jobless. Thankfully the Mrs is still bringing home a fulltime wage but won't be for too much longer as she goes on maternity leave at the end of June 2 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted August 31, 2020 Got a new job and just got through the first month. Spent some well needed money on some maintenance. New cambelt and water pump, went to start it and it wouldn't start...great...rechecked everything and seemed ok. Borrowed a crank angle sensor off a mate and started first time. Must have damaged it when disconnected it. The annoying slight miss at idle has now gone which is great. Picked up a remus muffler of Facebook for cheap, it's off an e36 323 I think, which should tidy up the rear nicely. Hopefully won't need too much modification to fit, the e30 has already been converted to a single pipe back from the middle cat. Looks like it'll clean up ok Sadly the next thing will be to sort some more rust. The battery leaked while it was parked up and the battery tray and firewall has rust in it. 1 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted October 15, 2020 On 8/31/2020 at 9:46 PM, Gaz said: Got a new job and just got through the first month. Spent some well needed money on some maintenance. New cambelt and water pump, went to start it and it wouldn't start...great...rechecked everything and seemed ok. Borrowed a crank angle sensor off a mate and started first time. Must have damaged it when disconnected it. The annoying slight miss at idle has now gone which is great. Picked up a remus muffler of Facebook for cheap, it's off an e36 323 I think, which should tidy up the rear nicely. Hopefully won't need too much modification to fit, the e30 has already been converted to a single pipe back from the middle cat. Looks like it'll clean up ok Sadly the next thing will be to sort some more rust. The battery leaked while it was parked up and the battery tray and firewall has rust in it. Hopefully we can get pics of our verts together at the next mega meet brother 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted October 15, 2020 Would good to get them together man. Will see how house renos go as to whether I can make the trip up again 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted August 18, 2023 Anyone interested in buying this send me a message. Potentially looking at selling due to its lack of use.. looking for $25k 1 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted September 14, 2023 Sell me your wheels man lol Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted February 16, 2024 Free listing on trademe today so whacked it up https://www.trademe.co.nz/4568870502 1 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted February 19, 2024 On 2/17/2024 at 9:38 AM, Gaz said: Free listing on trademe today so whacked it up https://www.trademe.co.nz/4568870502 No bro! The vert dream is the best dream but good luck with the sale. I thoroughly loved your car so much all those years ago but I understand that life happens my guy 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted February 20, 2024 Cheers mate, Haven't driven it in so long and prefer to have something that I can drive and have fun. 1 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted February 20, 2024 20 hours ago, Gaz said: Cheers mate, Haven't driven it in so long and prefer to have something that I can drive and have fun. that's fair enough bro! Quote Share this post Link to post Share on other sites
