zero 1162 Report post Posted May 28, 2018 7 hours ago, BM WORLD said: all easy stuff to change , should have towed the car to my work could have sorted it really quickly I would have done this, but at the time we didn't know where the fault lied. If I cant get it going can you come to me? Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 28, 2018 21 hours ago, Gabe79 said: If the ews is still good we can code you a new key (or just a transponder) easy. Edit: even if your ews is dead, get a used one and we can code a new vin to it easy too. Edit2: this can even be used as a diagnostic step. Coding keys is cheap, like $5 for a transponder. We can code a key and you can test it to see if your car starts. That’ll answer your question. Same for ews, but I don’t know how much a used ews would cost you. Do you have the ability to tell whether the ews is stuffed or not? Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted May 28, 2018 28 minutes ago, zero said: Do you have the ability to tell whether the ews is stuffed or not? I can tell if your key reads correctly, and I can tell if your EWS can be read correctly from the chip itself. I won't be able to tell if a connector is broken (like physical damage) but I'd say that's less likely. Put it this way, if you send me your EWS+keys, I can tell you if your EWS can be read, if your key can be read, and I can send you a programmed transponder (assuming I have one, I have to look...) to try it out with if the issue is your key.) If you want to bring these to me during the day in Stanmore Bay I can tell these things in 10-15 minutes for you. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 28, 2018 8 minutes ago, Gabe79 said: I can tell if your key reads correctly, and I can tell if your EWS can be read correctly from the chip itself. I won't be able to tell if a connector is broken (like physical damage) but I'd say that's less likely. Put it this way, if you send me your EWS+keys, I can tell you if your EWS can be read, if your key can be read, and I can send you a programmed transponder (assuming I have one, I have to look...) to try it out with if the issue is your key.) If you want to bring these to me during the day in Stanmore Bay I can tell these things in 10-15 minutes for you. Thanks, I will try and get transport to come see you. Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 28, 2018 Have you tried disconnecting the battery to reboot the system? I have found this fix this same (no crank) issue on multiple different brand vehicles with AA callouts. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 28, 2018 1 hour ago, hotwire said: Have you tried disconnecting the battery to reboot the system? I have found this fix this same (no crank) issue on multiple different brand vehicles with AA callouts. Yea, I did try that. I also tried swapping batteries. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted May 29, 2018 19 hours ago, zero said: Thanks. Can you tell me which wires those are, and I will try that? Edit; I have the ews out, and there are no physical signs of damage to it. I have exposed the ignition wires - there are six larger gauge wires on the back of the barrel, and two very small ones that click via a mini connector onto the keyring surround. At the EWS plug, short the two largest wires with the 30 amp fuse, one is from the ignition switch and the other goes to the starter solenoid. The E46 wiring diagram I looked at had them at terminals 1 and 3. Turn the key and see if the starter cranks Possible results: - Car cranks = problem with the EWS, it could be one of the "required signals" on being present (something other than the EWS) or the EWS itself - Car does not crank = problem somewhere else. Suggest you get a wiring diagram for your car and a good multi-meter for fault finding. Also get access to a good scanner like INPA that can read the EWS error codes. Most scanners only read the engine codes 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 31, 2018 FIXED! So @Gabe79 scanned the ews and the key, and it turns out the key was faulty. Weirdly it had no transponder chip in it so thats a bit of a mystery. So a bit of coding later and the car fires up. Big thanks to Gabe, and everyone else who gave advice. I've learnt my lesson and am getting spare keys cut for all my cars at the locksmith today. 6 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted May 31, 2018 No transponder chip in the key means it fell out...normally by someone replacing the battery. No transponder chip in the key does not take one or two days for a failure to start to occur. It is immediate. I would say wifey tried fitting new batteries or she dropped the key and it broke open loosing the chip 1 Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted May 31, 2018 28 minutes ago, *Glenn* said: No transponder chip in the key means it fell out...normally by someone replacing the battery. No transponder chip in the key does not take one or two days for a failure to start to occur. It is immediate. I would say wifey tried fitting new batteries or she dropped the key and it broke open loosing the chip Check the bottom of her handbag (if you dare) 2 Quote Share this post Link to post Share on other sites
M3AN 4160 Report post Posted May 31, 2018 1 hour ago, *Glenn* said: No transponder chip in the key means it fell out...normally by someone replacing the battery. No transponder chip in the key does not take one or two days for a failure to start to occur. It is immediate. I would say wifey tried fitting new batteries or she dropped the key and it broke open loosing the chip That's exactly what I was thinking. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 31, 2018 4 hours ago, *Glenn* said: No transponder chip in the key means it fell out...normally by someone replacing the battery. No transponder chip in the key does not take one or two days for a failure to start to occur. It is immediate. I would say wifey tried fitting new batteries or she dropped the key and it broke open loosing the chip I did ask her if she dropped the key and she said no, but I suspect otherwise. Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 31, 2018 4 hours ago, aja540i said: Check the bottom of her handbag (if you dare) I try to avoid 'the tardis'. 3 2 Quote Share this post Link to post Share on other sites
hotwire 352 Report post Posted May 31, 2018 6 hours ago, *Glenn* said: No transponder chip in the key means it fell out...normally by someone replacing the battery. No transponder chip in the key does not take one or two days for a failure to start to occur. It is immediate. I would say wifey tried fitting new batteries or she dropped the key and it broke open loosing the chip No chip in the key, Yup, can think of that scenario a couple of times on AA call outs. Both times checking the key & confirming no output. Question owner - no haven't had the key apart since last start. One found in a handbag (woman), the other on the floor of the ute (guy) Have been others with dodgy/broken keys where the chips have fallen into oblivion. 1 Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted May 31, 2018 only the older type key has the seperate chip sitting in it not the later diamond type RF keys , chip is part of the circuit board etc , no screws to open up that type 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted May 31, 2018 Obviously so very pleased Nathan's car is running again. ? Could I have some suggestions for the problems we have? Pretty please? ? 1 Quote Share this post Link to post Share on other sites
Gabe79 410 Report post Posted June 1, 2018 21 minutes ago, gjm said: Obviously so very pleased Nathan's car is running again. ? Could I have some suggestions for the problems we have? Pretty please? ? If it was key/EWS related I'd be all over that... sorry. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 1, 2018 3 minutes ago, Gabe79 said: If it was key/EWS related I'd be all over that... sorry. The fact that it does crank spoils that solution! Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted June 1, 2018 3 hours ago, gjm said: The fact that it does crank spoils that solution! Are you sure? my e36 had an issue after i changed the door handle, the new one was from an ews car, and if i didn't unlock the door with the key it would crank over until the battery died but wouldn't fire, if i unlocked the drivers door with the key or reached into the door and flicked a little switch on the handle housing it fired up straight away. 1 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted June 1, 2018 1 hour ago, aja540i said: Are you sure? my e36 had an issue after i changed the door handle, the new one was from an ews car, and if i didn't unlock the door with the key it would crank over until the battery died but wouldn't fire, if i unlocked the drivers door with the key or reached into the door and flicked a little switch on the handle housing it fired up straight away. I'll go through the process and see if it helps. ? Quote Share this post Link to post Share on other sites
