Deano1968 41 Report post Posted July 17, 2018 Hi. The previous owner of my 325i E30 fitted extractors. When I take left hand corners hard, the extractors hit the bottom steering knuckle. It may hit in other places but it is very hard to see. I can however see where the aluminium steering knuckle has been rubbing on the extractors. I have checked the motor mounts and they seem fine. Can someone provide some advice on the best way to fix this problem (slowing down is not an option). The car is fitted with the factory steering rack and I do not want to change it at this stage. Cheers. Dean. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 18, 2018 bash the headers or fit some washers under the engine mount on that side Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 18, 2018 Thanks Brent. Was hoping someone could put me onto replacement knuckles with a smaller OD. Quote Share this post Link to post Share on other sites
BM WORLD 1295 Report post Posted July 18, 2018 40 minutes ago, Deano1968 said: Thanks Brent. Was hoping someone could put me onto replacement knuckles with a smaller OD. yea another option , some later cars have smaller ones , come check some out if you like here Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted July 18, 2018 http://www.e30zone.net/e30zonewiki/index.php/Corsa_Steering_Linkage Holden Astra part, super cheep Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 18, 2018 Thanks Sam. Any idea what year or any particular model? Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted July 18, 2018 believe 90's era, 3rd/4th gen and all models Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted July 18, 2018 I have a modified knuckle and will post a pic tomorrow. Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 18, 2018 Thanks Sam and Geoff. Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted July 19, 2018 3 hours ago, Deano1968 said: Thanks Sam and Geoff. Or look up _BRS_ e30 part 2 build on another setup Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted July 19, 2018 Will the astra trick work on an e46 aswell? Quote Share this post Link to post Share on other sites
Ace Of Spades 51 Report post Posted July 19, 2018 (edited) Yeah, couple of UK guys have done it, Just check your lengths and measurements Best is two UJ's from summit racing with a small piece of 1/2 bar in between.. ( Plenty of clearance) Edited July 19, 2018 by Ace Of Spades Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 19, 2018 Cheers for that. I will look into it. Quote Share this post Link to post Share on other sites
GorGasm 563 Report post Posted July 19, 2018 Bash the headers, did it on my E55 with the same problem. Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted July 19, 2018 +1 to Brent’s idea of lifting exhaust side engine mount slightly. Easy job Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 19, 2018 Can't bring myself to hitting the extractors. I'd have to remove them to do that anyway which I want to avoid. Think I may replace the engine mounts. They're original items and may be contributing to the engine movement, and will then replace the steering knuckles with something smaller. Seems to be the tidiest, although not the least expensive, way to fix the problem. Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted July 20, 2018 Do you need to get the modified steering knuckle LVVTA certified as a modification? Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 21, 2018 That's a good question, which I don't know the answer to. I'll most likely change it, and see if they notice it for the WOF. I'm thinking that if I use factory made knuckles (from whichever car) without grinding or bashing anything then they should be safe. This could be one of those questions that you don't really want to know the answer to. Quote Share this post Link to post Share on other sites
FIAT 131R 223 Report post Posted July 29, 2018 Here is the pic of the modified steering knuckle with a normal size knuckle beside it. The gain is 25mm clearance overall. 1 Quote Share this post Link to post Share on other sites
Deano1968 41 Report post Posted July 29, 2018 Thanks Geoff. Unfortunately that won't fix my problem. On my car the bottom aluminium knuckle is hitting the extractors (when taking left hand bends hard). When I get some time in the next few weeks I'll head up to Brent's to sort through his stock to see what I can adapt. I'll let everyone know what I find. Cheers. Quote Share this post Link to post Share on other sites
