LsBeema 472 Report post Posted July 2, 2021 7 hours ago, Palazzo said: 3000mm driveshaft hoop, that’s a big hoop…..taking the roof off? Contact area homs...so silly reason that he showed me. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted July 3, 2021 (edited) 4 hrs full removal and fit crossmember back. Milwakee, hoists and me customising 95% of conversion needed for quick removal...oh yea...and strenght too😁😁 Edited July 3, 2021 by LsBeema 2 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted July 12, 2021 (edited) Locking ring added to rear spring, so 8- 10 mm height added🙄.all temporary. Fuel reg relocated for cold inducted air box...soo looking forward to the design of that, dont know whether itll duct from underneath, relocate horns to right, or from kidneys. Shifted filter. Enough clearance. Have a stainless shield. After fuel sector done with P clips fitted, then to heat shields. Will modify headers to lift exhaust by 15 -20 mm...WHAT A STAGE GUYS...!!! Perfecting...well trying to...final completion of this project for the cert. 🤗🤗😎😎 Edited July 12, 2021 by LsBeema 1 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted August 7, 2021 Awesome progress, I'm jealous how fast you're getting things done !! You'll be on the streets for summer time, I'll be sweating in the garage still hah. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 14, 2021 On 8/8/2021 at 10:01 AM, Cement said: Awesome progress, I'm jealous how fast you're getting things done !! You'll be on the streets for summer time, I'll be sweating in the garage still hah. Thanks man...but im moving slow. Time poor i tel ya!! Annnyway...at least you'll have heaps of time during the festive to smash. Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 14, 2021 (edited) Part 2 with the headers..Finally got them raised!! 2 driveshaft loop...man my fabricating got to nek level with this project😍😍YOU'LL NEVER KNOW YOUR CAPABILITIES AND WHAT POTENTIAL IS IN YOU UNTIL YOU TRUST YOURSELF AND JUST DO IT!!! New gearbox mount for exhaust clearances Headers wrap Will add more gussets. New list. Edited August 14, 2021 by LsBeema 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 18, 2021 (edited) First time rapping...50cent aint gor jack..😎 Not allowed to work...😤😤😤...annnnnnyway...safety first. Polished mee sword eventually with some free time at home.. Edited August 18, 2021 by LsBeema Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted August 21, 2021 On 8/18/2021 at 8:27 PM, LsBeema said: Polished mee sword eventually with some free time at home Oh man I'm glad there was a picture of an actual sword when I scrolled down a little further 😅 2 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 25, 2021 (edited) Went in for 5hrs, fitted headers, loved it, engine and box in, finalising alot, tight fit with header wrap and heat shields, brought the car home. Towed. Ecu down south with programmer for ecu light and fans fault. 😤. Finally time to put the epoxy coat on the coffee table. With some glow in the dark pigment for the cracks. Want to do a river ... Edited August 25, 2021 by LsBeema Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted August 26, 2021 I have found the issue with header wrap is it gets the manifold super hot changing the metals corrosion resistance, it's also a problem if a weld cracks, makes it quite hard to find the leak. Ceramic powder coating and some appropriate head shields are often more practical. 1 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 26, 2021 1 hour ago, Michael. said: I have found the issue with header wrap is it gets the manifold super hot changing the metals corrosion resistance, it's also a problem if a weld cracks, makes it quite hard to find the leak. Ceramic powder coating and some appropriate head shields are often more practical. Yea man...fully understand...cash homs...most of it going to the house deposit🙄 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted August 26, 2021 Did the cert man want them wrapped? Or just any type of heat shielding? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted August 27, 2021 18 hours ago, Gaz said: Did the cert man want them wrapped? Or just any type of heat shielding? Wrapped homs. For the steering shaft mainly. I'd weld some mounting points and fit some shields later. Or maybe coat them. This is only to get the cert. 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted September 1, 2021 (edited) Assembling the front. Relocated the relocated FPR again for a bigger airbox. Working on the floor...nahhh man. Not for me ay. Miss the hoist. Annnyway...better than not being able to working and enjoying this Beast. Stealth se Gad.....sleepers se moer😎😎 SA lingo... PURPOSE..!!.who cares about hiding.... As long as we dont pose ay...like a wanna be boy racers🤣🤣 Edited September 1, 2021 by LsBeema 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted September 3, 2021 (edited) Hard without a workshop man...eish🙄🙄🤯🤯 Hammers and some wood to panel and shape..🤓..annyway.. Edited September 3, 2021 by LsBeema 1 Quote Share this post Link to post Share on other sites
M3AN 4162 Report post Posted September 3, 2021 I thought a hammer and some wood were the only tools a real man needed anyway. 😉 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted September 7, 2021 On 9/3/2021 at 8:11 PM, M3AN said: I thought a hammer and some wood were the only tools a real man needed anyway. 😉 Trur brru...sounding pansy ay..😔all you need is a hammer and some Wood🤣🤣 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted October 2, 2021 (edited) Edited October 2, 2021 by LsBeema Quote Share this post Link to post Share on other sites
thorburn 123 Report post Posted October 3, 2021 Any reason for not going with a round driveshaft hoop? Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted October 8, 2021 (edited) On 10/3/2021 at 8:31 PM, thorburn said: Any reason for not going with a round driveshaft hoop? From an Engineering/strenght spec..im sure a circular design would confine a loose driveshaft much better.. But Picasso was also questioned..."WHY"... I just did it my way...cos why must one follow... also to make it look more factory brru.😎 Edited October 9, 2021 by LsBeema Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted October 9, 2021 (edited) Will make another one with a clear acrylic lid after I lower the radiator...Cert first!! Will Sharpen up on that wiring..clear top too Edited October 9, 2021 by LsBeema 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted October 14, 2021 Worked til 11 last night. Modifying exhaust to quiten and completing...again 6am till 8am to go for re inspection... 3 Quote Share this post Link to post Share on other sites
Palazzo 529 Report post Posted October 14, 2021 Well done, great work. 1 Quote Share this post Link to post Share on other sites
M3AN 4162 Report post Posted October 14, 2021 (edited) Fancy new LVV tag that is! Mine's a boring metal plate. Probably why cert costs have gone up so much. Edited October 14, 2021 by M3AN 1 Quote Share this post Link to post Share on other sites
LsBeema 472 Report post Posted October 14, 2021 (edited) Old ones Might go on today..😅😅 Edited October 14, 2021 by LsBeema Quote Share this post Link to post Share on other sites
