Herbmiester 947 Report post Posted June 28, 2019 So the floors on my E36 coupe are wet, quite wet. The car has a sunroof is that the likely culprit? What else do I need to check? Quote Share this post Link to post Share on other sites
str8_6 278 Report post Posted June 28, 2019 Make sure the side vent windows are closing tightly (they can be adjusted). Mine leaked and used to soak the seatbelt and carpet. Also clear sunroof drains. Not sure if the vapor barriers cause leaking in this model but that could be another cause. 1 Quote Share this post Link to post Share on other sites
bga 110 Report post Posted June 28, 2019 i had wet carpets - passenger side - it was the airconditioning unit that had a leak 1 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 30, 2019 Ok I think I found the problem or at least one of the problems. The cowling scuttle was full of decomposed leaves and dirt. Its a complete bitch of a job to fix as there is just no room to work. Quote Share this post Link to post Share on other sites
325_driver 422 Report post Posted June 30, 2019 17 minutes ago, Herbmiester said: Ok I think I found the problem or at least one of the problems. The cowling scuttle was full of decomposed leaves and dirt. Its a complete bitch of a job to fix as there is just no room to work. +1 to that, same thing on alot of my BMW's leaves in trim etc always seem to cause leaks Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted June 30, 2019 One of @dirtydoogle old BMWs had leaves and crap so old in the drain holes it was compost Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 30, 2019 That's exactly what I am removing , black compost. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted June 30, 2019 1 hour ago, Herbmiester said: Ok I think I found the problem or at least one of the problems. The cowling scuttle was full of decomposed leaves and dirt. Its a complete bitch of a job to fix as there is just no room to work. put your scone-grabbers to work! Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted June 30, 2019 I have dried it out with sun and hair dryer and now tying vacuum. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted June 30, 2019 Yeah they leak everywhere, not uncommon for leaks to go under windscreen either 1 Quote Share this post Link to post Share on other sites
Blackie 510 Report post Posted July 6, 2019 Did you buy this car from Kapiti by any chance? Its red right? Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 13, 2019 On 7/7/2019 at 11:07 AM, Blackie said: Did you buy this car from Kapiti by any chance? Its red right? I bought it from Wainuiomata. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted July 15, 2019 Ahh I see your problem. 2 Quote Share this post Link to post Share on other sites
