ScottyDontNZ 7 Report post Posted December 16, 2019 Is it possible? I would say the swirl marks are moderate and cover the entire car. I don't own a polisher/buffer and don't really want to buy one at this stage. What products would you recommend? Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted December 16, 2019 talk to @Autoglym, he's yer man for quality grooming products and techniques down here in Welly Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted December 17, 2019 It's possible, but I would just buy the polisher. https://www.supercheapauto.co.nz/p/toolpro-toolpro-dual-action-polisher-240v-720w-150mm/581559.html https://www.supercheapauto.co.nz/p/meguiars-meguiars-ultimate-compound---450ml/214309.html?cgid=SCN8005310 1 Quote Share this post Link to post Share on other sites
Palazzo 533 Report post Posted December 17, 2019 Buy a polisher. It will remove marks you’ll most likely never move by hand. Quote Share this post Link to post Share on other sites
kwhelan 243 Report post Posted December 17, 2019 can you substitute an angle grinder, battery drill or whatever with foam pads or a wool sleeve or microfibre pads etc. Whats the difference over a proper polisher specifically, is it rpms related? Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted December 17, 2019 Mostly but it depends on what polisher you are referring to? Majority of people use a dual action over rotary action for paint safety. Angle grinders have no speed control, run high rpm and use different disc sizes to most commonly available polishing pads. Ive seen drills used for very small or hard to reach areas. Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted December 17, 2019 Yes you can,but its not recommended, its probably less than 1/5th the speed of machine finishing. ive hand polished and entire car from 2000 grit sanded paint finish to show car shine, it was a character building test when i started a student job buffing vehicles. In terms of easy to get products i would recommend meguiars ultimate compound, a couple of foam applicators and a huge pile of microfibers. 6-8 hours will give you a significant improvement but wont be perfect. Quote Share this post Link to post Share on other sites
ScottyDontNZ 7 Report post Posted December 17, 2019 Is that 6 - 8 hours by hand or machine? Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted December 17, 2019 By hand as long as you have some endurance ha, get ready for the deep shoulder burn. Tight circles as if your hand was a buffer. Do a small area like wing mirror first to see how it turns out, or just borrow a buffer. Quote Share this post Link to post Share on other sites
ScottyDontNZ 7 Report post Posted December 17, 2019 I have put out a call in the Wellington region for a buffer on Facebook and here but no response. If anyone in Wellington is willing to lend one out let me know Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted December 17, 2019 Buy the meguiars ultimate compound you would use it on a buffer too, ( will almost certainly be on special at repco or supercheap now or boxing day) you will need to do small areas by hand anyway unless you also get a small buffer. I recommend you wash, clay bar, then begin polishing - plenty of videos on youtube. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted December 17, 2019 I've used a Bosch foam pad on my Bosch blue random orbital sander, with good results. (random orbital = dual action). However, care must be taken! Easy to burn paint or thin through on creases or swage lines. Also masking up trim etc is bloody time consuming. A dedicated polisher will be a little easier to use than my pad-on-sander. Quote Share this post Link to post Share on other sites
ScottyDontNZ 7 Report post Posted December 17, 2019 I'm understanding now why it's so expensive to get it done professionally! One PLACE (RestorFX) quoted me $1000+GST! To be fair, they are the only business that even bothered to reply. Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted December 17, 2019 Do you keep your car waxed? It wont remove any swirls but a good wax has fillers that will hide a lot of them. 1 Quote Share this post Link to post Share on other sites
Autoglym 255 Report post Posted December 17, 2019 Yes, you can do it by hand, what colour is the car?? I have a couple of products that are relatively easy to use, give me a call 0212633724 Regards Barry 1 Quote Share this post Link to post Share on other sites
