Jacko
The 130i Thread
There are not a lot of well sorted ones worth a premium.
Many have fallen into that typical Kiwi 3rd/4th owner neglect stage like all BMW's reach.
I play a game with AMG's.  How many owners has it had going by it's visual condition and the type of driver.  Guessed 10 as a joke for a absolutely clapped E55 AMG the other day.  I was wrong.  It was 14 owners...
  • Haha 2
  On 1/23/2025 at 9:42 AM, Jacko said:
Could be a good buy.  Doesn't even mention the brakes.
Just as shabby as my manual one.
Must have been a good buy, it's sold.
  On 1/24/2025 at 5:48 AM, BreakMyWindow said:
Yep I bought it.
Any other goodies? I was tempted to go have a poke around this weekend, and then come up with an argument for the missus about why 4 is the right number of cars. Looked like a good bargain, the brakes on mine cost over 50% of the asking price of that....
In terms of goodies just a ticky top end and in desperate need of a clean up and service. Has new RE003’s on it. Hopefully will visit Hampton Downs with in about a month.
  • Like 3
Nice one. Thought about getting better brakes for mine after the track day last week. Might start with just pads and new fluid.
Make sure you chase what ever the recommended tyre pressure is for those RE003s. Seen them cook and start destroying the outter edges at the track.
Just a random question, there was a silver 130i with manual box on sale in Auckland with lots of mods on sale years ago. I think the car never got sold. Is the owner here? Just curious whether you sold the car eventually.
Half the dash is missing.  It has broken plastic behind the rear right wheel.  A broken quarter window.  Auction writing on the windscreen.  Def stolen and recovered or attempted to steal it.
Evening people. I changed out my leaking steering rack a few weeks ago. Since then, neither the horn or the paddle shifts are working. No dash errors so I’m thinking I may have dislodged an earth wire somewhere. Any thoughts anyone? Cheers.
Have you checked all the fuses?  The only grounds around there are the main engine to body grounds.  There would be much more wrong if they were disconnected.
I can't think of anything that would have that effect in the area you were working on.
When getting the rack out, the steering column seemed to come out a long way so thought maybe I’d dislodged an earth under the dash somewhere. Fuse check will happen tomorrow. They’re such a bugger to get at…..
Anyone have an old idrive screen unit they want to get rid of? Doesn’t have to be working, I only need the front part of the lcd casing in good condition, which attaches to the motor drive mechanism to resurrect my one again.
Anyone have a copy of what fuses run what for our 130's? Been searching but can't seem to find one of those or a wiring diagram. Very elusive to my searching fingers unless I'm getting something completely wrong. It might turn out I'll have to check every single one of those fuses that are in such a mongrel place....
The junction box (fuse box behind glovebox) changes between prefacelift and facelift variants. A white plastic junction box is prefacelift while the gray is facelift.
Assuming your vehicle is prefacelift (2006) this should be relevant for your vehicle:
A4010a is the JBE (junction box electronics) with two large plugs on the front, at the bottom of the junction box.
Given the symptoms I'd suggest ensuring the plugs on both the car and steering-wheel side of the clock spring (A72 steering column switch center) are seated fully and check continuity across the clock spring.
Where can I find detailed diagrams like these? I would like to add cruise control to a 130i so I want to find the wires that might make that happen.
Those are from ISTA/D, there are a few websites that offer cut-down functionality, e.g. https://bmwteka.com/wds/en/e87/6fe27cdd
For retrofitting cruise control you won't need any extra wiring, only the correct (E87 specific due to rear wiper) steering column switch centre, the lower plastic cover (though I guess you could try modify the existing one), and appropriate coding.
I don't want to buy any switch. I hope that if I find the wire to turn it on (one switch I install on the dash) and the wire to set (another switch I install on the dash), I can get it to work. I don't need any other functions.
What is the 'appropriate coding' you are referring to?
Edited by topnotchrally
Thats not how cars work, since like 1998, pretty much everything in an E87 is on CANbus. Youll need coding to tell it it has cruise control hardware etc.
I doubt the switches are on CAN bus so my plan should still work.  Who/how would I get this coding done?
