SmackJackTheCrackerMan 54 Report post Posted October 29, 2020 Since I picked up the car last week I’ve had a good ol’ steering wheel wobble. I assumed it was that the new tires had not been balanced properly, but I’ve had all 4 wheel & tires balanced again today (only slightly off) This has helped some what but anything over 80kh it’s still there. what would be then next port of call? wheel bearings? What is the best way to check? Quote Share this post Link to post Share on other sites
aja540i 1925 Report post Posted October 29, 2020 Are the rims nice and round? They can be balanced and out of round if they have smacked a pothole etc, some tyre places will look for it but some don't... Quote Share this post Link to post Share on other sites
Jacko 2302 Report post Posted October 29, 2020 After market wheels that are missing hubcentric rings? Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted October 29, 2020 my money is on thrust arm bushes, if its doing it at 80kmh while cruising and not related to braking (in which case it would be warped rotors or similar) Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted October 29, 2020 Fit front wheels to back and back wheels to front and see if it changes. If it does then its something to do with the wheels. Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted October 29, 2020 15 hours ago, Jacko said: After market wheels that are missing hubcentric rings? I will try this first, should be easy enough to grab some locally, hopefully Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted October 29, 2020 26 minutes ago, NZ00Z3 said: Fit front wheels to back and back wheels to front and see if it changes. If it does then its something to do with the wheels. Might be an issue as the rear wheel are so much wider than the fronts. Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted October 29, 2020 14 hours ago, qube said: my money is on thrust arm bushes, if its doing it at 80kmh while cruising and not related to braking (in which case it would be warped rotors or similar) I suppose it's a case of jacking the car up and giving everything a good shake! See if anything is loose that shouldn't be. Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted October 30, 2020 On 10/29/2020 at 6:45 PM, qube said: my money is on thrust arm bushes, if its doing it at 80kmh while cruising and not related to braking (in which case it would be warped rotors or similar) This, ive had 4 euros with 80-100kmh steering wheel shake and its been thrust bushes / lower control arm every time usually around 100-120,000km on the bushes. Alot of force transfers through them, you wont feel it by hand, I didnt notice using a mid size pry bar but changed them anyway. Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted October 31, 2020 19 hours ago, andrewm said: This, ive had 4 euros with 80-100kmh steering wheel shake and its been thrust bushes / lower control arm every time usually around 100-120,000km on the bushes. Alot of force transfers through them, you wont feel it by hand, I didnt notice using a mid size pry bar but changed them anyway. Thanks Andrew! Think I’ll give this a go. is this what I should be replacing? https://www.fcpeuro.com/products/bmw-suspension-control-arm-bushing-33326775552 I’ve also ordered some hub centric rings as apparently the wheels are designed for a 5 series so has a slightly larger centre bore. Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted October 31, 2020 (edited) Front bushings. You may be off replacing the whole arm long term though. If the ball joint fails on your new bushings then you are going to be buying a whole new arm. https://www.fcpeuro.com/products/bmw-control-arm-bushing-kit-e81-e90-e65-e66-meyle-31120304308my https://www.fcpeuro.com/products/bmw-control-arm-assembly-front-left-front-31126769797my https://www.fcpeuro.com/products/bmw-control-arm-front-right-front-e88-e89-e90-e91-31126769798my If you running without required hub rings then thats likely your issue Edited October 31, 2020 by Eagle wrong car Quote Share this post Link to post Share on other sites
SmackJackTheCrackerMan 54 Report post Posted November 2, 2020 On 10/31/2020 at 8:46 PM, Eagle said: Front bushings. You may be off replacing the whole arm long term though. If the ball joint fails on your new bushings then you are going to be buying a whole new arm. https://www.fcpeuro.com/products/bmw-control-arm-bushing-kit-e81-e90-e65-e66-meyle-31120304308my https://www.fcpeuro.com/products/bmw-control-arm-assembly-front-left-front-31126769797my https://www.fcpeuro.com/products/bmw-control-arm-front-right-front-e88-e89-e90-e91-31126769798my If you running without required hub rings then thats likely your issue Correct. I got the hub rings today 74x72.6 and it’s like a different car. No more wobble at all. Thanks. Quote Share this post Link to post Share on other sites
