gjm 3300 Report post Posted November 3, 2020 (edited) The evergreen topic of "should I buy tools to compress suspension springs" has reared its head again. Every time I look, it seems there's another 'solution'. Anyone seen these before? I've never seen a suspension spring tool which actually shows use of power tools before! https://www.lislecorp.com/specialty-tools/strut-tool Edited November 3, 2020 by gjm Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted November 3, 2020 Or this... http://tetools.com/catalogue/detail.php?item=6915 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted November 3, 2020 I bought the repco ones and thought they were better than the supercheap ones at around the same price 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted November 3, 2020 Arh, spring compressors. I tried them once. Now I take the struts to Goodyear, they have a hydraulic tool in a cage that does both struts in less than 15 minutes. Costs me $50 and I get to keep my fingers and face just the way I like them. 2 Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted November 3, 2020 (edited) 2 hours ago, 3pedals said: both of the images above scare me , neither is safe and well engineered This one is - note the locking pins and NEVER use an impact driver to wind them - always do it manually and - P.S i think you should change your handle to 'Dangermouse' ? I'd never use a power tool with stuff like this. It's worrying that a manufacturer/supplier appears to suggest it! The second one looks like a 'discount' version of a proper solution. While it might be possible to do something sensible along those lines, that one looks perfect for anyone with a discount life. Somewhere in the container I have a set similar to this: Finding it is proving more difficult at the moment! And Dangermouse was awesome! ? Edited November 3, 2020 by gjm Quote Share this post Link to post Share on other sites
Sammo 2616 Report post Posted November 3, 2020 3 hours ago, 3pedals said: both of the images above scare me , neither is safe and well engineered This one is - note the locking pins and NEVER use an impact driver to wind them - always do it manually and - P.S i think you should change your handle to 'Dangermouse' Yeah, I have this style - seem to do the job well enough and the pins give some security. Still make sure to point them away and take my time compressing / uncompressing. Lucky only the fronts are mcpherson struts and don't seem to be under a huge amount of pressure. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted November 3, 2020 I've got a few different types but depends on the car. I use the traditional 2 twin hook ones the most as they offer best clearance around strut hats. Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted November 6, 2020 The set in the second post are for a specific style of suspension; double wishbone, where the compressor is inserted in the middle of the spring to compress it. I have the set like 3Pedals shows, with the locking pin. Have done a few struts with them now, including using an impact gun on them, with no issues. Just make sure to keep the thread well lubricated and dont go full monkey on it. Quote Share this post Link to post Share on other sites
