Chrisf 0 Report post Posted November 8, 2021 I've got some new struts to install in my '07 335i Msport, I went with the OEM Sachs ones. Unfortunately the struts now have an interval bump stop that prevents the shaft fully extending on its own. I tried quite a few times to compress the spring with an old set of spring compressors, but could never get it down enough to get the shaft through the strut mount. The cheapest strut compressor I can find is https://www.u-buy.co.nz/product/L66SZU-jegs-strut-coil-spring-compressor-1-ton-capacity-spring-size-4-10-hydraulic-foot-pedal-assist-yellow but all I need to do is two struts. I'll probably never need to use it again. All the hire websites only have cheap spring compressors like https://www.tkhire.co.nz/coil-spring-compressor-1460884 Anyone know where to hire a good spring compressor from, or where I use one? I'm in Wellington. Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted November 8, 2021 Probably easier just to take them into a garage which would probably have a mounted one. All the Wellington guys recommend Auto38, im sure he's done plenty. Quote Share this post Link to post Share on other sites
E28E30 339 Report post Posted November 8, 2021 15 minutes ago, Eagle said: Probably easier just to take them into a garage which would probably have a mounted one. All the Wellington guys recommend Auto38, im sure he's done plenty. @Eagle Auto38 is shut down. He moved to Marton. 1 Quote Share this post Link to post Share on other sites
M3AN 4195 Report post Posted November 8, 2021 Or consider your own, something like this? $90. https://www.sulco.co.nz/MACPHERSON-STRUT-SPRING-COMPRESSOR.html Quote Share this post Link to post Share on other sites
Chrisf 0 Report post Posted November 8, 2021 22 minutes ago, M3AN said: Or consider your own, something like this? $90. https://www.sulco.co.nz/MACPHERSON-STRUT-SPRING-COMPRESSOR.html Those are the kind I have tried. Was not able to compress the spring fat enough to assemble the strut. The new strut shaft doesn't extend as far as the old ones. The floor mount ones like https://toolexpressnz.co.nz/products/spring-compressor?variant=37590905028802¤cy=NZD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gclid=Cj0KCQiAsqOMBhDFARIsAFBTN3chQ-P_2KAusuTx4Cq9qzdWUoAAYkyoI30e5H77POxANWMm4H_QenAaAgzxEALw_wcB grab the strut at the bottom instead of the actual spring. With the spring only ones you can only compress the middle section of the spring. Quote Share this post Link to post Share on other sites
adro 1127 Report post Posted November 9, 2021 (edited) I couldn’t be bothered risking my head again with spring compressors and took the front shocks to Lyall Bay service Center along with my new parts and they made them up for me. Was about an hours labour and totally worth it IMO, assuming you have access to another car to transport them to the shop while your car is up on stands. Edited November 9, 2021 by adro 1 Quote Share this post Link to post Share on other sites
Chrisf 0 Report post Posted November 13, 2021 Sounds like taking them to a shop is the way to go. Need to sort out the logistics since nowhere is open on weekends Quote Share this post Link to post Share on other sites
smiddy 76 Report post Posted November 14, 2021 Very dodgy and dangerous indeed! Spring needs a lot of even level pressure to compress enough to get nut on shock shaft. Not possible really with screw type equipment, springs very differcult to compress. Accident waiting to happen, as Adro mentioned. Quote Share this post Link to post Share on other sites
Chrisf 0 Report post Posted November 28, 2021 (edited) Does anyone have any recommendations for mechanics to take my car to in the Wellington area? Added bonus if they do wheel alignments too Edited November 28, 2021 by Chrisf Quote Share this post Link to post Share on other sites
jom 98 Report post Posted November 30, 2021 The shock shop in Porirua have been good in the past. Quote Share this post Link to post Share on other sites
