GBSiena 1 Report post Posted July 25, 2023 I have TWO ( I know, I know ) F10 535D’s The first, FROG, is a 2010 with 245 kms ; we purchased this with 150km on it, we’ve had it about 4-5 years . It was remapped about 1 year into ownership. Pre re-map mileage was approx 6.4 l/100km on my regular commute ( 35 minutes, mostly open road); post map long term mileaage ( more than a year between re-sets ) is dependably 7.2 l/100km The second, GECKO, is a recent arrival – a 2011 that’s delivering 8 l /100ml and has NOT been remapped I am unsure why the base economy between the 2 cars, same model, 1 year apart, varies from FROG’s pre-remap of mid 6’s to GECKO’s not remapped 8. Almost exclusively the same driver ( me ) and same routes Any ideas ? Garry 1 Quote Share this post Link to post Share on other sites
paulo 81 Report post Posted July 25, 2023 1 hour ago, GBSiena said: I have TWO ( I know, I know ) F10 535D’s The first, FROG, is a 2010 with 245 kms ; we purchased this with 150km on it, we’ve had it about 4-5 years . It was remapped about 1 year into ownership. Pre re-map mileage was approx 6.4 l/100km on my regular commute ( 35 minutes, mostly open road); post map long term mileaage ( more than a year between re-sets ) is dependably 7.2 l/100km The second, GECKO, is a recent arrival – a 2011 that’s delivering 8 l /100ml and has NOT been remapped I am unsure why the base economy between the 2 cars, same model, 1 year apart, varies from FROG’s pre-remap of mid 6’s to GECKO’s not remapped 8. Almost exclusively the same driver ( me ) and same routes Any ideas ? Garry Maybe check coolant temperature is getting hot enough to allow better efficiency, and that it is also allowing the DPF to do the required occasional burn-off? (needs to get to over 88 degrees I think). I have an earlier e60 Diesel and it has had 2 x faulty thermostats over 80,00km and that resulted in worsening fuel economy until fixed. You will need to access the hidden dash menu to get readout of coolant temp or a scanner with real-time data readings. 1 Quote Share this post Link to post Share on other sites
aja540i 1909 Report post Posted July 25, 2023 Same size wheels and tyres? Quote Share this post Link to post Share on other sites
GorGasm 563 Report post Posted July 25, 2023 Yep thermostat is definitely something to check. Quote Share this post Link to post Share on other sites
TonyT 48 Report post Posted July 26, 2023 Different flow rates through the DPFs perhaps? ie. the 2011 one more clogged than the 2010. Quote Share this post Link to post Share on other sites
Olaf 3405 Report post Posted August 29, 2023 In diesellandia as I am with my F25 X3 30D, I use Penrite diesel fuel biocide treatment, it kills the diesel bug and keeps your fuel lines and injectors clean. I can’t remember the actual concentration, about 30ml each time I fill up is a scratch over the recommended running dose. On the side of the container are instructions for quantities for treating deep clean and also infestations. Wouldn’t hurt to try a good dose of that through yours. I certainly noticed a difference on mine when I first treated it. have you established with a scanner when the last DPF Regen was? I’d guess you’re getting it up to temp and sustained temp with a fully charged battery for it to kickoff when required. If there’s anything preventing the regen in terms of operating state prerequisites, you might need to get that taken care of. Also, check for recall - there’s a recall globally for n57 - something to do with coolant and DPF, I forget the details. Continental have the parts to do mine on back order. HTH 1 Quote Share this post Link to post Share on other sites
Spinner99 60 Report post Posted August 31, 2023 On 8/29/2023 at 5:52 PM, Olaf said: In diesellandia as I am with my F25 X3 30D, I use Penrite diesel fuel biocide treatment, it kills the diesel bug and keeps your fuel lines and injectors clean. As an alternative to the biocide, have you seen one of these before? https://dieselsolutions.co.nz/product/de-bug-l140/ Quote Share this post Link to post Share on other sites
Olaf 3405 Report post Posted August 31, 2023 Interesting. how often do you need to change the cartridge, and how much does that cost? Also, isn't working pressure of 40psi far lower than the N57B30O1? Quote Share this post Link to post Share on other sites
Spinner99 60 Report post Posted September 1, 2023 11 hours ago, Olaf said: Interesting. how often do you need to change the cartridge, and how much does that cost? Also, isn't working pressure of 40psi far lower than the N57B30O1? My understanding is there is no cartridge replace, it's a fit and forget device. There are no filters in it, no moving parts. The diesel flows through magnets which destroy the "bug" on the way through. I think the idea is it goes in your fuel line before any other filters, injectors etc so as to prevent said bug clogging your fuel filters etc. Re the fuel pressure question, great question, i have no idea sorry Quote Share this post Link to post Share on other sites
KwS 2443 Report post Posted September 1, 2023 2 hours ago, Spinner99 said: My understanding is there is no cartridge replace, it's a fit and forget device. There are no filters in it, no moving parts. The diesel flows through magnets which destroy the "bug" on the way through. I think the idea is it goes in your fuel line before any other filters, injectors etc so as to prevent said bug clogging your fuel filters etc. Re the fuel pressure question, great question, i have no idea sorry Just use the tried and true biocides like Olaf mentioned. Magnets dont kill bugs. Thats like the old Peter Brock box of magic and wizardry. 1 Quote Share this post Link to post Share on other sites
E30 325i Rag-Top 3010 Report post Posted September 2, 2023 Could be something has gone off the boil - injectors, turbos, fuel pump pressure. However, I would give the car a nice long hot run (not just cruising down the motorway) with a dose of injector cleaner in the tank, to give everything a good clear out. Probably do filters first -air cleaner and fuel fuel being the key two. See what it’s like after than then if no improvement, start checking things like the injectors and turbos. Quote Share this post Link to post Share on other sites
