Eagle 1787 Report post Posted January 15, 2024 Worst case you can try this procedure i came across at some point. I may try it on mine if i get bored one day. https://www.e46fanatics.com/threads/ultimate-engine-flush-process-part-1.1285390/ https://www.e46fanatics.com/threads/ultimate-way-to-clean-the-engine-part-2-combustion-chamber.1285432/ Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 5, 2024 Dropped the rear subframe to replace all the bushings and ball joints and swap to the 330 diff. I decided to paint the diff as well since it looked pretty brown and scabby. Came up very nice. I also installed the front bilsteins and 330 front brakes. 2 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 5, 2024 (edited) Big progress this weekend. First start up. Took today off so that I could have a 4 day weekend this week and get stuck into the compact. Pulled the N42 out. Cleaned up the engine bay a bit Few things fitted while the engine was out. CMP solid steering coupler, clutch hard line, smaller heater valve from the 330. Had to adapt the EVAP purge line from the larger OD pipe on the compact to the smaller OD pipe from the M54. Made a fitting that looks pretty factory and just clips into the original connector. Put in a third pedal. I'm super picky with wiring and hate when it's not tidy so a lot of time was spent making sure everything looked pretty original when wiring in the clutch switch. Power and ground from the brake pedal and the DME wire runs under the dash with the factory loom. I omitted the EWS wire and opted instead to just code out the need to press the clutch to start, it's not needed and tidier. When swapping from a N42 you have to wire in the AC compressor as well since it's part of the engine harness on the N42 and part of the chassis harness on M54 cars. Instead, since I'm deleting SAP which is in the same position as the AC compressor wiring, I just cut and changed the SAP connector to the correct one for the AC. The SAP wiring goes through a relay behind the glovebox so I bypassed it and moved the SAP pin at the DME to the chassis connector for the AC. No new wires needed, a much better solution than running a new harness all the way across the car IMO. My reverse switch was wiring in line with the factory harness while I had the engine out so the only additional wire running into the ECU box is the clutch switch wire, everything else utilizes the factory wiring. New clutch and flywheel on. Gearbox with all detents replaced, new guide tube, pivot pin etc. Started on the first crank. Snapchat-1404950484_1.mp4 Still lots to do. Waiting on some parts to finish rebuilding the rear end. Cooling, AC system, front end etc. Can't wait to drive it. Edited February 6, 2024 by Harper 8 1 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted February 6, 2024 Very cool milestone !! Looking forward to the next updates 👍 3 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted February 6, 2024 Ohh man that's epic! Looks so clean, what an absolute weapon it will be 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 6, 2024 14 minutes ago, Vass said: Ohh man that's epic! Looks so clean, what an absolute weapon it will be Nothing more exciting than a first start up. Everything cleaned up like new, really helps starting with a nice original chassis that hasn't been messed with before. This car had all it's original paint markings on the bolts. Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 11, 2024 A weekend of set backs sadly, to be expected with a big project like this I suppose. Plumbed up the cooling system with all new parts in the cooling stack With the cooling system and belts on I could run the engine for more than a minute or two at a time. Unfortunately became obvious when running the engine a bit longer that it had a rough idle. Bounces between 600-1200rpm and eventually dies. Pulled the intake manifold off in search of a vacuum leak. Pretty much everything on the manifold is brand new and I couldn't find any obvious leaks so reassembled carefully but no change. I've ordered a smoke tester but that's a couple weeks away. Could be a bad MAF but that was working before the swap so a vacuum leak seems more likely. The more disheartening discovery is an MTF drip from the bellhousing on the gearbox. Can only really be coming from the input shaft seal so the gearbox is going to have to come out. The front end is still all disassembled so I think I'd rather just pull the engine and trans out together rather than pull the gearbox underneath the car which is never fun. Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted February 11, 2024 Bummer but hopefully it's something simple. Did you clear adaptations at all? Sometimes it will take a wee while for the DME to adjust to a "new normal" and it will be a bit erratic until the first proper drive. Have you checked codes? I've had a code for "idle control valve stuck open" so could be something like that. What sort of smoke tester did you go for? Recently did a bit of logging and found Long Term Fuel Trims sitting at 8.5% so am looking to get one as well. Have heard good things about the AutoLine Pro range, supposedly comes with free shipping through Amazon so leaning towards that but keen to hear what you've found. Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 11, 2024 16 minutes ago, Vass said: Bummer but hopefully it's something simple. Did you clear adaptations at all? Sometimes it will take a wee while for the DME to adjust to a "new normal" and it will be a bit erratic until the first proper drive. Have you checked codes? I've had a code for "idle control valve stuck open" so could be something like that. What sort of smoke tester did you go for? Recently did a bit of logging and found Long Term Fuel Trims sitting at 8.5% so am looking to get one as well. Have heard good things about the AutoLine Pro range, supposedly comes with free shipping through Amazon so leaning towards that but keen to hear what you've found. Yep cleared all adaptations but I think the idle is too rough to just be the DME relearning fuel trims especially since it stalls and dies after a few minutes. I had codes for bank 1 and 2 lean condition (also suggests vacuum leak) but cleared them and they haven't come back yet. I checked the ICV when I had the manifold off and it's clacking like it should so I think that's alright. I ordered the cheapest AutoLine Pro that I can hook up to my compressor (https://www.amazon.com/gp/product/B06XHRBKTM/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&th=1). Has good reviews and funnily enough their marketing video is on an E46. I'll report back whether it's any good. Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted February 20, 2024 The engines back out sooner than I had hoped.. Fortunately with the front end already off it took <2 hours to get it out. Love how easy the E46 is. Split the gearbox in search of the leak from the bellhousing and as suspected it was the input shaft seal. I replaced it while the box was out the first time since it was weeping but it was leaking a lot of fluid now and the seal wasn't happy. Couldn't see anything wrong with it, so I tried my luck and tapped it in a bit further. No luck. Had to bite the bullet and remove it and get another one ordered. $60 seal, ouch. I could see the slightest imperfection on the lip of the seal once it was out but have a hard time imagining that was causing the drip, hopefully the next one has no issue otherwise I'm out of ideas. Took a bunch of photos but lost them somehow so here it is removed. . In the meantime I've reassembled the rear end. subframe and arms in with all new bushings, ball joints, and bearings, 330 diff, 330 rear brakes, new brake lines all round. 330 cluster rings and manual cluster panel panel added. Technically since this is a coupe it should probably have the grey dial faces but I actually prefer the look of the black ones. The smoke tester arrived, it works good. No complaints except for the smell of the smoke, and it gets everywhere, on your clothes hair, skin etc. I tested with the motor removed and just plugged the purge valve and sucking jet pump but it revealed absolutely zero vacuum leaks. The thing is air tight. Pretty much only leaves a brake booster vacuum leak, bad MAF sensor, or bad O2 sensors, as my rough idle issue. I will have a look at the fuel trims once the motor is back in the car and see what the next step is. Tempted to just order a MAF regardless since it's nice to just rule it out and have a fresh one, I already have O2 sensors on order but they're not due until the end of march. 3 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 4, 2024 (edited) Very productive weekend. New input shaft seal for the gearbox. Was super careful putting this one in, made sure it went in as square as possible and tapped it just barely below flush. Didn't take many photos since I was really trying to get the car driveable for this week. Motor back in, cooling stack in. I installed a new MAF sensor, O2 sensors, fuel pump. But I still had a rough idle. Eventually discovered it was the MAF connector itself. The female pins were quite loose which meant that with the airbox off and the intake tube moving around with the engine the contact was not good. I squeezed the pins tighter and fitted the airbox so everything was solid and the idle was perfect. A quick look at the fuel trims in INPA suggest they are perfect but I'll do a proper log later and see how things look. Front end taking shape Back on the ground, first time seeing the final ride height (will settle a bit) with the new bilstein B8s and eibach springs. Pretty much perfect for what I was looking for seeing as it will be my daily. Cabin filter and new windshield cowl fitted. Unfortunately I'm still missing the front air duct that feeds the airbox. The one of the donor car was broken so I'll have to make a trip to the scrap yard to get one. Interior assembled with a few nice new parts, I'm still repairing the driver seat so I have temporarily fitted the driver bucket seat from the M3. On 1/14/2024 at 2:31 PM, Olaf said: I hope you'll leave the 318 badge on the tailgate! Sorry Olaf, this ones getting a badge. Car got a much needed wash and out for it's first quick test drive. Absolutely stoked with this thing. It's very quick, corner to corner it's not really any slower than the M3. Not quite as much zing as the S54 up top but much smoother and torquier low down. Still a few details to finish it off: - Driver seat - AC re-gas - Air intake scoop - Exhaust hangers, the 325ti has unique hangers which I didn't pony up for resulting in the tail pipes not sitting quite centred - It's too quiet. I like my cars quiet but at idle you wouldn't even know the thing is running. It has a fully stock 325ti exhaust, so I think I'm going to open up the small centre resonator and gut it and see what that sounds like. - Z4 FCABs - Alignment - Tyres, the Chinese ones on it are not up to scratch for the B30 torque - Custom plate I think, this one is a keeper I love it too much already. Edited March 4, 2024 by Harper 8 Quote Share this post Link to post Share on other sites
Vass 1082 Report post Posted March 4, 2024 Ahh man, well done! What a wee weapon. Looks so good in white, and the ride height looks absolutely bang on. Keen to hear how you go with the exhaust, looking to add a bit of sound to mine at some point as well. Was just clearing out the garage yesterday and stumbled upon a spare air intake scoop thingy. Was gonna go in the bin but happy to send it your way to save the scrap yard trip. Also have a few spare steering wheel button panels if you wanted cruise & media controls. Where'd you get those shifter & handbrake boots from? Hardly see any RHD ones around, or was it a DIY effort? 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 4, 2024 7 minutes ago, Vass said: Looks so good in white, and the ride height looks absolutely bang on. Super happy with the suspension. Just the right amount of firm but very compliant and comfortable. Looking forward to seeing what difference the FCABs make. 8 minutes ago, Vass said: Keen to hear how you go with the exhaust, looking to add a bit of sound to mine at some point as well. I still have the rear section from the donor 330 so I'll cut into that one and see how easy or difficult it is. I really only want it to be maybe 10% louder, just enough to know that it's something special but I still want it to sound stock. Hopefully gutting the resonator gets me what I'm looking for but will report back. 11 minutes ago, Vass said: Was just clearing out the garage yesterday and stumbled upon a spare air intake scoop thingy. Was gonna go in the bin but happy to send it your way to save the scrap yard trip. Also have a few spare steering wheel button panels if you wanted cruise & media controls. You're a legend mate, I'll gladly take it. Happy to pay for shipping plus some. The ones I've come across so far at the junk yard are usually damaged in some way. I actually like the look of the blank steering wheel panel but losing out on cruise control is a bummer. Maybe one day I'll fit a Z3 CC stalk. 12 minutes ago, Vass said: Where'd you get those shifter & handbrake boots from? Hardly see any RHD ones around, or was it a DIY effort? Cobywheel. Reasonably priced and they use genuine grey 9002 alcantara to match the bolsters. I've seen the wheels and some other bits done by coby and they've been average quality but the boots are really good in my experience. They just copy the pattern from the genuine bits so fit like OE. I just removed the old leather and glued them onto the frames with some contact adhesive. 1 Quote Share this post Link to post Share on other sites
Cement 913 Report post Posted March 4, 2024 Looking super haaaaawt !! Must be awesome to have it driving Is the donor car heading to the wreckers once done with ? I need to hack at one as per my thread: 1 Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted March 4, 2024 8 hours ago, Harper said: Very productive weekend. New input shaft seal for the gearbox. Was super careful putting this one in, made sure it went in as square as possible and tapped it just barely below flush. Didn't take many photos since I was really trying to get the car driveable for this week. Motor back in, cooling stack in. I installed a new MAF sensor, O2 sensors, fuel pump. But I still had a rough idle. Eventually discovered it was the MAF connector itself. The female pins were quite loose which meant that with the airbox off and the intake tube moving around with the engine the contact was not good. I squeezed the pins tighter and fitted the airbox so everything was solid and the idle was perfect. A quick look at the fuel trims in INPA suggest they are perfect but I'll do a proper log later and see how things look. Front end taking shape Back on the ground, first time seeing the final ride height (will settle a bit) with the new bilstein B8s and eibach springs. Pretty much perfect for what I was looking for seeing as it will be my daily. Cabin filter and new windshield cowl fitted. Unfortunately I'm still missing the front air duct that feeds the airbox. The one of the donor car was broken so I'll have to make a trip to the scrap yard to get one. Interior assembled with a few nice new parts, I'm still repairing the driver seat so I have temporarily fitted the driver bucket seat from the M3. Sorry Olaf, this ones getting a badge. Car got a much needed wash and out for it's first quick test drive. Absolutely stoked with this thing. It's very quick, corner to corner it's not really any slower than the M3. Not quite as much zing as the S54 up top but much smoother and torquier low down. Still a few details to finish it off: - Driver seat - AC re-gas - Air intake scoop - Exhaust hangers, the 325ti has unique hangers which I didn't pony up for resulting in the tail pipes not sitting quite centred - It's too quiet. I like my cars quiet but at idle you wouldn't even know the thing is running. It has a fully stock 325ti exhaust, so I think I'm going to open up the small centre resonator and gut it and see what that sounds like. - Z4 FCABs - Alignment - Tyres, the Chinese ones on it are not up to scratch for the B30 torque - Custom plate I think, this one is a keeper I love it too much already. This is a wicked little build dude. Been watching with anticipation! Can sort your ac regas if ya need 1 Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted March 4, 2024 Hard to imagine ever seeing one in NZ that would beat this. The wheels, msport kit and alpine white really make it, somehow the head lights look great now haha. 2 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 4, 2024 2 hours ago, Cement said: Is the donor car heading to the wreckers once done with ? I need to hack at one as per my thread Unfortunately long gone, or I'd let you have at it. 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 4, 2024 1 hour ago, BMTHUG said: This is a wicked little build dude. Been watching with anticipation! Can sort your ac regas if ya need Thank you bro, if you weren't on the other side of Auckland I'd be there. I'm sure I'll get to have a look around your E30 at some point. Fortunately my local shop is pretty good and I'll get them to sort the alignment at the same time. 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 4, 2024 54 minutes ago, Eagle said: Hard to imagine ever seeing one in NZ that would beat this. The wheels, msport kit and alpine white really make it, somehow the head lights look great now haha. The biggest compliment. So nice when the vision finally comes together. Quote Share this post Link to post Share on other sites
BMTHUG 1112 Report post Posted March 4, 2024 45 minutes ago, Harper said: Thank you bro, if you weren't on the other side of Auckland I'd be there. I'm sure I'll get to have a look around your E30 at some point. Fortunately my local shop is pretty good and I'll get them to sort the alignment at the same time. Ahh so you're South I'm guessing? Yeab man. I have been watching this progress intently and it's so good watching it come to fruition! Glad you got a good local shop man! Definitely have to catch up for a looksie at each other's cars! 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted March 24, 2024 Original seat back in. Bolsters swapped out with the ones off the donor since they were pretty worn. E46 interior never gets old It's on daily driver duty now 8 Quote Share this post Link to post Share on other sites
M3AN 4191 Report post Posted April 2, 2024 (edited) Having watched the build from afar, I am not surprised this gives me a semi. Props for a job very well done Mr. Harper. 👌 Edited April 2, 2024 by M3AN sp 1 Quote Share this post Link to post Share on other sites
Harper 615 Report post Posted June 1, 2024 (edited) I've done about 5,000km since the motor swap and this thing has been almost perfect. Just visually keeping an eye on the dipstick, I can't really see any drop in level so oil burning so far has been negligible. It has developed a slight weep from the upper radiator hose, I've ordered one to replace asap, along with a bit of a leak from what I think is the selector shaft seal on the gearbox. Other than that it's been behaving pretty much exactly as I wanted out of a daily driver. I ended up taking it to an exhaust shop and had the resonator removed. I just wanted slightly more noise out of it but didn't want to go to an aftermarket setup which is almost always too loud. Not the prettiest thing in the world but it has made the car sound exactly as I wanted it. Still sounds very stock just slightly spicier. Previously it sounded pretty pedestrian with the fully standard 325ti exhaust system. Next up is getting it WOF'd, we'll see if it passes without a cert. Edited June 1, 2024 by Harper 3 Quote Share this post Link to post Share on other sites
Danch 51 Report post Posted June 1, 2024 I saw this listing you may be interested in: BMW E46 Compact AC Schnitzer Exhaust https://www.trademe.co.nz/4739981637 Quote Share this post Link to post Share on other sites
Eagle 1787 Report post Posted June 1, 2024 14 hours ago, Harper said: Next up is getting it WOF'd, we'll see if it passes without a cert. Are you planning to go to a certain place? 7 hours ago, Danch said: I saw this listing you may be interested in: BMW E46 Compact AC Schnitzer Exhaust https://www.trademe.co.nz/4739981637 Single inlet probably not worth the hassle Quote Share this post Link to post Share on other sites
