Guest Andrew
The Bimmersport Dyno Thread
Haha nice mate, have a few ponies out of that 3L
Must pm me your mods?
only has carbon plenum, alpha n chips, E46 M3 crank pulley, 283* BMW motorsport cams, 8.5Lb alloy flywheel and home made exhaust with high flow metal cats
Carbon intake of a s54? Is the e46 m3 crank pulley slightly bigger than the e36?
Im after some high flow cats but they are so expensive
carbon plenum made for S50, and the E46 M3 crank pulley is smaller, so it underdrives everything
Motorsport cams as in M cams?
283* is surely heaps more than a normal S50 cam.
It's awesome power - how many rpm is that at?
standard M3 cams are 264* I believe, my cams are a BMW part, from M division racing parts catalogue, I got them second hand, maximum power is at ~ 8000rpm, my limiter is currently at 8100rpm
I wasn't sure you could play with the cams on Vanos equiped motors, i guess if it's a BMW part, what was the approx price on the shaft if you don't mind me asking?
Pressy
http://www.google.co.nz/url?sa=t&sourc...C0ik7tW5DBDI5QA
And
http://store.vacmotorsports.com/schrick---...sets-p1355.aspx
has anyone else read the power figures and thought mmm thats not a bmw haha i only take notice of the bmws with bmw engines lol good power figures though
thinking of supercharger plan for the m20b25 at some point or a 3.5 conversion
M54B30 In a E30 coupe
700 nm 517 ft.lbs
270bhp 200kw
What do you think has been done to it?
Edited by Garett
Pretty hard to believe it has 700nm but only 270hp. Turbo diesel? :P
That torque reading would be the tractive effort no doubt.
Can't be a diesel, note the peak RPMs
That's torque reading at wheels, which is multiplied depending on gear and diff ratio
Pretty hard to believe it has 700nm but only 270hp. :P
That's what i thought until i got told that the diff ratio was to blame.
i think the top speed was around 220km
Seems I need to use stronger sarcasm.
Anyway, reminds me of that fella who swears black an' blue his NA 20b makes 690 odd nm. lol chassis dynos.
Oh so at 100 in 5th it's doing around 4000rpm, f**k that.
correct torque is divide by the diff ratio so if it makes 700nm 3.9 diff = 179.48nm motor as long as the run was doing with a 1-1 drive ratio as for power the TCF factor should be between .98-1.00.
i did a rb25 on monday 15psi made 367kw wheel and 360nm motor im sure everyone gets the picture
2.8L M20, 14.5:1 compression with custom JE pistons, extensively modified head, custom grind cam, triple webers, E85....this is wheel kw, not corrected to flywheel-
That's insane, such an amazing sound on the dyno! :wub:
