e30ftw 435 Report post Posted January 23, 2010 Made the adapter loom tonight. Wiring for dummies style. To the left is the m20 fuse box plug Engine side (So will plug into the e30 fusebox). To the right is the m50 Body side fusebox plug. So the m50 engine loom will plug into that end. I also labeled each wire cos it makes life so much easier rather than gazing at the pin d*ck sized numbers on the plugs every time. Soooome heat shrink I stole of my old man.. Then joined up all the wires as per the wiring diagram I got of Troy, which he has used 3x with success so I trust it.. My lame soldering Lol. And woop here is my wiring adapter A couple wires left out, will cut them off behind the pins on the plugs, But will confirm all are uneeded before I do so anyhow, Then I'll tape the wires up.. Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 23, 2010 PM sent Quote Share this post Link to post Share on other sites
tire 10 Report post Posted January 23, 2010 nice one John. interested to see how this one turns out.. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 23, 2010 Looms all sat in now, Joined where it needs to be etc.. Gave it some power...... And it's ALIVE I got no gas Quote Share this post Link to post Share on other sites
antil33t 90 Report post Posted January 23, 2010 at least your service indicator works... mine Half works. it will do Inspection/oil change.. but the LED's don't light up Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 23, 2010 (edited) Haha gutted. Central locking works power windows all work Brake lights are working, Park lights are working Indicators are going Sooo, so far everything is pretty sweet the only problem I have come across is the Wipers are only working on 1 speed? Edited January 23, 2010 by e30ftw Quote Share this post Link to post Share on other sites
kingkarl 136 Report post Posted January 23, 2010 Wow, looks like a whole new car with that paint job. It's a much nicer colour too. N/A 24v FL e30 awesomeness. Did you end up selling the old engine? Feel free to ignore this question if you want, but how did court go? When are you back behind the wheel again (legally)? Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 23, 2010 Wow, looks like a whole new car with that paint job. It's a much nicer colour too. N/A 24v FL e30 awesomeness. Did you end up selling the old engine? Feel free to ignore this question if you want, but how did court go? When are you back behind the wheel again (legally)? Yeah I sold the engine and turbo setup. I figured it wouldn't be a good idea for me to keep it. Will ignore cos I don't want my thread to go down hill lol. But yes looking forward to a nice e30 m50 Still condemplating whether I want to try drop the motor in with the gearbox on it or not. I DO want to because I can see the startermotor being a real B*itch getting it on once the motor is in, then lifting the gearbox in place.. But then I don't want to because it's such a mission doing m20's on the insane angle, looks like m50 will be even more of a mission and I don't wanna bang up the front bit with the sump like I usually have Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted January 24, 2010 harder to get the engine into place with the gearbox attached/more weight on your hoist/more of an angle getting it into the car vs. having one hell of a fun time putting the gearbox and starter on with the engine in. either way its a pita but ill be dropping it in all bolted up and ready to go. have heard you may have to take off the belts/pullys though, but it can be done without dissassembly (know a guy in the states who did it, picture evidence) Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted January 24, 2010 (edited) I DO want to because I can see the startermotor being a real B*itch getting it on once the motor is in, then lifting the gearbox in place.. With a few bros helping and a good hoist you should be ok. Edited January 24, 2010 by Mark247 Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 24, 2010 Everyone I have done has been with the gearbox on. Bit of a tight squeeze, but get the car up nice and high, get some angle on the engine and drop it in, you will need a few people to help you probally. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 24, 2010 you have to do suspension anyway if i was you i would just go from under get her up high as you can drop the cross member, bolt it all up on the floor then slide it all under and up hence no paint damage. can you send me the loom diagram you used dude so i can have a look against mine!. Quote Share this post Link to post Share on other sites
flake 0 Report post Posted January 24, 2010 when i put mine in i had the hoist on the factory lifting point and an endless chain hooked onto a tab on the block at the back. that way i didn't have to jack the car up and i could get the right angle and pivot the engine and gearbox in piece of p*ss. roll the car back and forth as you need to to get it in. i took off the power steering pulley as i couldn't get it to clear. took me an hour 20minutes-ish by myself. it'll be much quicker and easier if you have some mates helping out. good luck Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 24, 2010 (edited) you have to do suspension anyway if i was you i would just go from under get her up high as you can drop the cross member, bolt it all up on the floor then slide it all under and up hence no paint damage. can you send me the loom diagram you used dude so i can have a look against mine!.I'll post it here so everyone can see it. I only used troys cos the one you gave me said the very first pin to join up (oil level or somesh*t) wasn't even there and troy said its on e34's I think, so your one was for a e34 loom. when i put mine in i had the hoist on the factory lifting point and an endless chain hooked onto a tab on the block at the back. that way i didn't have to jack the car up and i could get the right angle and pivot the engine and gearbox in piece of p*ss. roll the car back and forth as you need to to get it in. i took off the power steering pulley as i couldn't get it to clear. took me an hour 20minutes-ish by myself. it'll be much quicker and easier if you have some mates helping out. good luck Oh sweet, I'll join up the gearbox and give it a shot then. Not sure If I could get the entire car high enough to lift the motor and subframe from underneath, that would be a mean idea though. Edited January 24, 2010 by e30ftw Quote Share this post Link to post Share on other sites
turboprop 0 Report post Posted January 24, 2010 you have to do suspension anyway if i was you i would just go from under get her up high as you can drop the cross member, bolt it all up on the floor then slide it all under and up hence no paint damage. can you send me the loom diagram you used dude so i can have a look against mine!.diagram ive been using.... just watch out for the abs wire if your car has abs. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 24, 2010 (edited) Yeah, i snipped that red ABS wire. And the ones in red, snipped all those too. Edited January 24, 2010 by e30ftw Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted January 24, 2010 Sounds like an awesome project! Will have to wait for 56k to reset itself so I can see the pics. Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 24, 2010 Body wiring side of things is done now, so gotta put everything back in now. funnn. Custom Flame tints Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 25, 2010 at this rate it will be going by the weekend man. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted January 25, 2010 I like! Very cool dude Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 25, 2010 Yeah I still wanna pull the rear end out to throw some urethane bushes in there, also swapping diffs with Stephen. My 3.64LSD for his 3.46LSD. Still a high ratio for a 1:1 final drive e36 box but meh.. Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 25, 2010 i love my 3.64 final drive it hauls arse Quote Share this post Link to post Share on other sites
e30ftw 435 Report post Posted January 25, 2010 3300rpm at 100kmh though lol, would be changing gear too often cos your gears would be short as Quote Share this post Link to post Share on other sites
kerry 10 Report post Posted January 25, 2010 fun though mind you loss of traction is a nono these days aint it Quote Share this post Link to post Share on other sites
mark247 42 Report post Posted January 25, 2010 You dont muck around do ya? Quote Share this post Link to post Share on other sites
