1rotty 40 Report post Posted October 7, 2010 Got two tyres refiited on the Eagle-rolled them off on my cross country at the taupo trackday lol. New alternator in the 540-at least now it starts-still doesnt like going backwards tho. Trans is officially f**ked. Methinks into the shed for 12 mths & ponder if Im brave enough to do a 6spd convo. Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted October 7, 2010 Put in a rebuilt alternator from mops. No more not wanting to cold idle, although I don't know if that's because of the alternator or the fact that the battery was disconnected so the ecu got reset. time will tell. Oh and new front brake pads. Did you brake the dtm shifter Ashkan? Naaaah. Just broke the pin at the bottom while taking it apart. I'm trying to reduce some of the play in it and pull the shifter back a bit. At the moment with the OEM shifter rod it sits as its in first when it is in second. Going to shorten that rod a little bit and also machine down the sleeve that fits into the shifter to reduce some of the play. Will also do bushes etc at the same time. Quote Share this post Link to post Share on other sites
Ben 0 Report post Posted October 7, 2010 Sprayed my back bumper today and test fitted skirts Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted October 7, 2010 Put it all back together after replacing engine mounts/adjusting steering box. Just waiting on radiator hoses and i'm good to go Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted October 7, 2010 manual conversion, cooling system overhaul and some offset bushes cheers jono, legend Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted October 7, 2010 ^ OT but if you could drop my scanner off at some point that would be good if you are finished with it? just leave it same place ya found it thanks Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted October 7, 2010 Broke my passenger side door handle... AGAIN. Fml. Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 8, 2010 My next door neighbours blocked my driveway AGAIN. so i parked on the street. It was there for 1 hour and this is what happends... The whole time i was driving to work i thought "some people just don't deserve to be living" haha - i mean, who that f*ck does that? (i know it was my neighbors, they are retards) Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted October 8, 2010 What is it? Paint? Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 8, 2010 (edited) What is it? Paint? yip, had to use paint thinners to get it off. (and they have chipped it, and scratched it) Edited October 8, 2010 by _Matt_ Quote Share this post Link to post Share on other sites
Guest Simon* Report post Posted October 8, 2010 Some silent revenge may be in order perhaps? Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 8, 2010 Some silent revenge may be in order perhaps? I would but every car they own is a heap of junk, it wouldn't do any good....and they are in the mongrel mob. So i don't wanna go there Quote Share this post Link to post Share on other sites
Lucan 196 Report post Posted October 8, 2010 (edited) Nail under tyre? PS: you'd think they'd appreciate you having a nice red car next door. Edited October 8, 2010 by Blackie Quote Share this post Link to post Share on other sites
_Matt_ 42 Report post Posted October 8, 2010 yea, but i don't construct my sentences solely out of the word f*ck. Quote Share this post Link to post Share on other sites
Wom 0 Report post Posted October 8, 2010 ^ OT but if you could drop my scanner off at some point that would be good if you are finished with it? just leave it same place ya found it thanksyep no worries mate I'll drop it off in the next couple of days Quote Share this post Link to post Share on other sites
Greg111 13 Report post Posted October 8, 2010 Trans is officially f**ked. Methinks into the shed for 12 mths & ponder if Im brave enough to do a 6spd convo.Do it...DO IT!Got a Simota panel filter for the 3, took the plenum off it, cleaned down the block from where it had its Taupo woopsy, i got carried away and now the engine bay is in pieces, currently constructing a "cold" air intake from the L/H brake duct. Quote Share this post Link to post Share on other sites
Top Secret 2 Report post Posted October 9, 2010 Took the engine out of one. No dramas there. Attempted to replace the fuel pump in the other, only to find that the pressure was too low once we eventually got it fitted. This is after making small adapters on a jig as the return/pressured lines are reversed. Who'd have thought out of 3 E30 325is the fuel pumps are different on every single one. Quote Share this post Link to post Share on other sites
1rotty 40 Report post Posted October 9, 2010 Do it...DO IT! Yeah i think-might need some pro help..............maaaate Got a Simota panel filter for the 3, took the plenum off it, cleaned down the block from where it had its Taupo woopsy, i got carried away and now the engine bay is in pieces, currently constructing a "cold" air intake from the L/H brake duct. Look forward to seeing this Quote Share this post Link to post Share on other sites
tire 10 Report post Posted October 9, 2010 Flushed and replaced power steering fluid and brake fluid. Replaced front rotors with standard spec brembos from Dan (driftit) - legend! Oh and replaced hazard light switch also thanks to Dan. Quote Share this post Link to post Share on other sites
Mark 178 Report post Posted October 9, 2010 Drove to the supermarket and back. Got eyeballed by a guy in a E46 318i poverty spec bouncing around on chinese made 5 spokes. I LOL'ed, he didn't. Quote Share this post Link to post Share on other sites
gouba 0 Report post Posted October 9, 2010 yea, but i don't construct my sentences solely out of the word f*ck. Awesome, I laughed.I replaced my sun visors, installed a fire extinguisher, refitted my passenger door, sprayed my front grill, made a face plate for my sub/amp installed in the boot and gave it a massive clean. Quote Share this post Link to post Share on other sites
pjay 8 Report post Posted October 11, 2010 Weight reduction Quote Share this post Link to post Share on other sites
bimmer boy 21 Report post Posted October 11, 2010 Checked my water and oil and tried to work out how to take out my headlights for when my new ones arrive Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted October 11, 2010 picked up my new E30. Factory Motorsport 318i, one of only seven assembled from the factory like this in new zealand. Will put up a thread soon Quote Share this post Link to post Share on other sites
Creaver 55 Report post Posted October 14, 2010 Installed new street/track pads and machined rotors Quote Share this post Link to post Share on other sites
