Eddie 66 Report post Posted April 4, 2012 The compact could be on the way out and a Couple be in I got this today I hope there are enough parts in there to put it back together Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 4, 2012 Do it! Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted April 4, 2012 12hp with an afm tweak. Not bad! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 4, 2012 The top of the AFM had already been off before I got the car. I didn't think that it would effect WOT but it did Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 9, 2012 The car had heaps of parts in it. New ignition and door locks replacement radiator support panel Grills, front panel new inter tyre rods. head lights some interior panels and some indicators and tail lights, but they are off a 4door damage panels removed reassembled four door indicators don't fit sad no tail light so no hooning around Quote Share this post Link to post Share on other sites
polley 916 Report post Posted April 9, 2012 amazing the small differences between 2 door and 4 door E36's. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 9, 2012 Got up early and pulled the auto out this morning Quote Share this post Link to post Share on other sites
Steve K-B 51 Report post Posted April 10, 2012 So is this replacing the compact?? Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 13, 2012 (edited) It looks like it may,The wife has put claim to the compact. The couple is a real mess on the inside The auto is installed back into the compact, also swapped out the radiators and fans. Just so I could put the electric fan into the couple Edited April 13, 2012 by rot62 Quote Share this post Link to post Share on other sites
*Glenn* 856 Report post Posted April 13, 2012 It looks like it may,The wife has put claim to the compact. The couple is a real mess on the inside The auto is installed back into the compact, also swapped out the radiators and fans. Just so I could put the electric fan into the couple Coupe You & wifey are the couple Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 14, 2012 Replace the rear crank seal in the coupe today. I was a bit surprised that it would be leaking at 100k Anyway I will put the manual box in tomorrow Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 18, 2012 Been doing a bit on the car the last couple of nights Got the interior stripped out removed the tar stuff off the floor Removed the sun roof and controls then glued just the panel in Can I drive Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted April 18, 2012 Got some tail lights now Started to sort out some some of the wiring inside the car that wont be need. Came across this plug, what a plug for f all This may have a job soon Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 18, 2012 Cool. Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 1, 2012 its on and running. Its a crude setup at the moment as I just want to see how its going to run Quote Share this post Link to post Share on other sites
sp8s 1 Report post Posted May 2, 2012 Hot Digitty Dog Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 2, 2012 A bit a a design f##k up need to move the throttle body to before the blower Quote Share this post Link to post Share on other sites
MLM 57 Report post Posted May 2, 2012 Always wondered if the charger would sit on top of the lower half of the manifold and clear the bonnet.. Could make for a tidy package Quote Share this post Link to post Share on other sites
SLOW36 0 Report post Posted May 2, 2012 Great project have you run this set up on a dyno yet?.Is the engine a M42B18 or M44B19? Quote Share this post Link to post Share on other sites
thorburn 122 Report post Posted May 2, 2012 A bit a a design f##k up need to move the throttle body to before the blower Can you not just use a bypass after the supercharger?What ratio is the supercharger being spun at Looks like you've done well welding those cast bits. Would you be able to explain what you use for cleaning and welding? 4043 rod, pre heating and plenty of cleaning? Keep up the good work Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 20, 2012 A bit of an update Remounted the alternator Removed the ABS Install a new fuel pump Walbro 341 Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted May 20, 2012 Very cool project and different. Love the 6spd box! Quote Share this post Link to post Share on other sites
Eddie 66 Report post Posted May 21, 2012 The car went on the dyno after work today. Standard atw 95hp (70kws) supercharged @7psi 135hp (98kw) While it doesn't sound like much its still a 40% increase Had to change the injectors, stole some from a 90's rvr Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted May 21, 2012 Pics! .. and videos! Quote Share this post Link to post Share on other sites
