aja540i 1925 Report post Posted November 16, 2016 4 hours ago, gjm said: Makes space under the back of the car, smooths airflow, or... Something else? I can see some benefits but just checking I've not missed anything! Richard - what size rims (including offset) are you running? More room for Aston Martin mufflers! 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted November 16, 2016 wheels are 18x10j offset +20 I also have 17mm spaces Quote Share this post Link to post Share on other sites
richard 384 Report post Posted November 16, 2016 1 hour ago, aja540i said: More room for Aston Martin mufflers! NO mufflers straight pipes turned out by rear wheels 1 Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted November 17, 2016 On 11/16/2016 at 11:24 AM, gjm said: Makes space under the back of the car, smooths airflow, or... Something else? I can see some benefits but just checking I've not missed anything! Richard - what size rims (including offset) are you running? exhaust space and makes changing the diff so easy too. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted December 6, 2016 update: So had to widen the guards from felony form by 35 mm over their std 45mm to a total 80mm not ideal but have chosen function over fashion. Still have to do the fronts but I'm wanting for front bumper to make my finale decision on how they will be formed. These won't be everyone's cup of tea but hay, its mine. Pics: Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted December 7, 2016 should have just put on some stretched tyres and more camber Quote Share this post Link to post Share on other sites
richard 384 Report post Posted May 21, 2017 red 4 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted May 24, 2017 Today after work I decided to check the water hoses on the engine and look for way to hook up the expansion tank. The hose from the back of the head was the first to come off and to my surprise found this inside, have no idea how it got there. Then gave the rest the squeeze test had a fail so have decided to replace the lot. 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted May 24, 2017 That interior pic is awesome Quote Share this post Link to post Share on other sites
richard 384 Report post Posted May 24, 2017 Yea, Red sure shows more than Green. Red and something ....Black is my pick at the moment or maybe dark gun metalgrey on all the other panels Quote Share this post Link to post Share on other sites
richard 384 Report post Posted June 8, 2017 Update. Been a bit slow over the last couple of weeks. Fitting off the brakes from peddle box to the front brake lines and where it meets the rear lines. Running the lines through the bulkhead and tiding it up. I've used lots of braided lines as the peddle box is adjustable not the drivers seat. Fitted a pressure switch for brake lights. Expansion tank install in the water system, I plumbed this into what was the heater inlet and return. Oil cooler. Radiator' power steering pump and lines. Ready for liquid's , If all goes well I may even have it running over the weekend. Pics 3 Quote Share this post Link to post Share on other sites
Olaf 3426 Report post Posted June 8, 2017 mate, that's trick. love the bottom-pivot pedal box. Dr Porsche 'got it' decades ago. need mored detail pics of your pedal box, want to see the adjustment mechanism. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted June 9, 2017 (edited) 17 hours ago, Olaf said: need mored detail pics of your pedal box, want to see the adjustment mechanism. Nothing to special just some box steel with holes drilled and taped every 25 mm x 5 and held down with some bolts. you can kind of see it in this pic Edited June 9, 2017 by richard add more pics Quote Share this post Link to post Share on other sites
richard 384 Report post Posted June 25, 2017 she lives, the real credit goes to Ray at HELBM. I just reconnected. first_start_up.MOV 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted June 27, 2017 (edited) E36 wide body kit arrived today. after 4 months of waiting I saved about 76kgs over standard bare body parts.( No glass , door latches, locks ) . Biggest problem was getting it over the customs line and the TAX that DHL charge. Edited June 27, 2017 by richard spelling 3 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted June 27, 2017 This just gets better and better Quote Share this post Link to post Share on other sites
richard 384 Report post Posted June 27, 2017 and costs more and more. 1 Quote Share this post Link to post Share on other sites
richard 384 Report post Posted August 12, 2017 stuff I don't need 1 Quote Share this post Link to post Share on other sites
Garett 103 Report post Posted August 12, 2017 That's a lot of wires.... Quote Share this post Link to post Share on other sites
gjm 3300 Report post Posted August 12, 2017 Just now, Garett said: That's a lot of wires.... That's a lot less wires. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 12, 2017 6 hours ago, richard said: stuff I don't need What do you reckon that lot weighs? Quote Share this post Link to post Share on other sites
richard 384 Report post Posted August 12, 2017 on the fish scales 11.5kgs, but like all fish stories maybe a little heaver than really is... on a different note I'm filling up the gearbox and manufactures guide says ATF, is there a better product for racing application... Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted August 13, 2017 7 hours ago, richard said: on the fish scales 11.5kgs, but like all fish stories maybe a little heaver than really is... on a different note I'm filling up the gearbox and manufactures guide says ATF, is there a better product for racing application... Kayne Barrie would be a good person to ask. Quote Share this post Link to post Share on other sites
richard 384 Report post Posted September 27, 2017 .small update not much going on at the moment had to throw down 90m2 of concrete as the grass and mud got to much. moulded the fibre glass rear guards together and fitted doors and front guards. front and rear bumpers are a bit tricky as they require a little lateral thinking on how to attach with 1/3 turn clips. 1 Quote Share this post Link to post Share on other sites
HaNs 226 Report post Posted September 27, 2017 Nice rear wing, you make it up? Quote Share this post Link to post Share on other sites
