will 169 Report post Posted December 21, 2014 Those guns are not designed to spray underbody/liner, they do not have the correct nozzles. Those sort of guns are designed to atomise the liquid, with underbody/liner type coatings you want a large nozzle that just propels the liquid without trying to atomise it. The best gun is a Shutz type, I have several different ones for use with liquids of varying viscosities. Even the 'paraffin' type engine cleaning gun will work, sometimes with the standard long nozzle if the liquid is reasonably thin, other times you need to remove the standard long nozzle and replace it with a 50-100mm long piece of hollow tube, depending on what finish you are after. The shorter tube will disperse the liquid in a wider arc than a longer one. The advantage of the paraffin gun is that it comes with its own liquid container, the others use the container holding the liquid. If buying a paraffin gun, make sure that you buy one where the long nozzle is removable so you can interchange nozzles. Examples.. http://www.ebay.co.uk/itm/Draper-Shutz-Dispensing-spray-underseal-Schutz-Gun-/171184664889?pt=LH_DefaultDomain_3&hash=item27db66b139 http://www.ebay.co.uk/itm/Stonechip-Shutz-Waxoyl-Gun-Brand-New-Shutz-Gun-Car-Paint-/221594856024?pt=LH_DefaultDomain_3&hash=item3398152a58 http://www.ebay.co.uk/itm/222112-Long-Nozzle-Paraffin-Diesel-Air-Spray-Gun-Engine-Cleaner-Economy-Price-/271394075510?pt=LH_DefaultDomain_3&hash=item3f3058f376 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 21, 2014 Those guns are not designed to spray underbody/liner, they do not have the correct nozzles. Those sort of guns are designed to atomise the liquid, with underbody/liner type coatings you want a large nozzle that just propels the liquid without trying to atomise it. The best gun is a Shutz type, I have several different ones for use with liquids of varying viscosities. Even the 'paraffin' type engine cleaning gun will work, sometimes with the standard long nozzle if the liquid is reasonably thin, other times you need to remove the standard long nozzle and replace it with a 50-100mm long piece of hollow tube, depending on what finish you are after. The shorter tube will disperse the liquid in a wider arc than a longer one. The advantage of the paraffin gun is that it comes with its own liquid container, the others use the container holding the liquid. If buying a paraffin gun, make sure that you buy one where the long nozzle is removable so you can interchange nozzles. Examples.. http://www.ebay.co.uk/itm/Draper-Shutz-Dispensing-spray-underseal-Schutz-Gun-/171184664889?pt=LH_DefaultDomain_3&hash=item27db66b139 http://www.ebay.co.uk/itm/Stonechip-Shutz-Waxoyl-Gun-Brand-New-Shutz-Gun-Car-Paint-/221594856024?pt=LH_DefaultDomain_3&hash=item3398152a58 http://www.ebay.co.uk/itm/222112-Long-Nozzle-Paraffin-Diesel-Air-Spray-Gun-Engine-Cleaner-Economy-Price-/271394075510?pt=LH_DefaultDomain_3&hash=item3f3058f376 The second gun has interchangeable nozzles. It comes with 4 different attachments. Even the largest attachment would work with my compressor, but it worked fine on my mates industrial compressor. He is a panel beater by trade and says my compressor isn't designed for spraying a compound like the deck liner. But its okay for now, it will be getting a few more coats done next month when he sprays the car. Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 26, 2014 Merry Xmas all. Hope we all had a good time. Did some DIY and clean up in the garage today after picking up some M5 bits this morning. Decided to take the beasty out for a bit of a clean up and to get some shots from different angles other then the rear. Also got me some M5 wing mirrors, interior trim, another M5 bumper and some AC Shitz parts (will be selling most of these) Will hopefully have everything finished by mid January in terms of "Paint Ready" 2 Quote Share this post Link to post Share on other sites
Tristan 338 Report post Posted December 27, 2014 Looks great, mate. Fast progress! 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 27, 2014 Thanks TJ. Need to get s genuine front spoiler tho. The fake one doesn't cut it sadly 1 Quote Share this post Link to post Share on other sites
atlantiskiwi 73 Report post Posted December 27, 2014 Just spent the last 30mins reading your build! Soo soo cool! Cannot wait to see it! Where are you opening your garage exactly? Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 27, 2014 Just spent the last 30mins reading your build! Soo soo cool! Cannot wait to see it! Where are you opening your garage exactly? Thanks man. It will be in Mt Wellington off Morrin Road. Hoping all me gear arrives next month as I left the ordering of it a little late. Quote Share this post Link to post Share on other sites
atlantiskiwi 73 Report post Posted December 28, 2014 Ah ok, I drive past there everyday on my way to work. Look forward to seeing how it all comes together. Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted December 29, 2014 http://www.benzboost.com/content.php?976-Speaking-of-BMW-pick-up-trucks-here-is-Stuart-Appleby-s-E39-M5-truck found this might give you some insperation Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 29, 2014 http://www.benzboost.com/content.php?976-Speaking-of-BMW-pick-up-trucks-here-is-Stuart-Appleby-s-E39-M5-truck found this might give you some insperation Hah thanks. I been using his build thread as reference as much as I can. Www.m5ute.com.au but the build quality is allot better then mine. I do love the finished result, it is indeed inspirational Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 30, 2014 Finishing up the inner tail lights delete. Hoping to have the tailgate finished tomorrow with the reverse camera and the new locking system. Plan on using 2 central locking locks triggered by a momentary switch to unlock the tailgate. The switch will be fabricated to the rear BMW badge. Currently working out the electrics but should have it installed tomorrow 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted December 31, 2014 Tailgate light delete completed. Designed and tested the tailgate lock using 2 universal central locks running through a On/Off switch. Works a charm. Now to weld get all the wiring tidied up for the lock, reverse camera and reverse lights Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted January 5, 2015 Not much of an update, been busy with family holidays and what not. But managed to start on the rear window sails and complete rear door delete. I guess its all the hard stuff to do now, detailing everything to make an even flow from front to rear and also ensuring that the left and right side are as close match as possible. Using primer brings out all the imperfections in the body filler, so still some work to do yet :-) Ive also decided to not do a wide body, as it will more then likely kill the look. Also trying to decide on 'blind spot' windows, I wont even be able to see through them, so if I do the windows, it will be more for looks then anything else. 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 25, 2015 Been a wee while since I've updated this due to work and the track car build. Been ticking at the bogging and sanding which doesn't seem to ever go anywhere, but started on the rear sail for the rear window and also the rebuild of the M62 next week when the parts arrive. Aaallloootttt of foam... Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted March 31, 2015 Rebuild kit arrived today S62 intake should be here over the next week or two 1 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 4, 2015 (edited) Got the base shape for the rear sail done. Will start glassing tomorrow and see how it starts shapping out, might have to open the rear window a bit more. Edited April 4, 2015 by FrancoisPV Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 6, 2015 Got the lines for the rear guards done today. Many many weeks of sanding and bogging and sanding again. Rear starting to take shape now. Glassed some of the sail as well, will finish that off this week. Quote Share this post Link to post Share on other sites
westy 614 Report post Posted April 6, 2015 Looking good. Quote Share this post Link to post Share on other sites
Michael. 2313 Report post Posted April 6, 2015 Extreme DIY. Looking forward to more updates! 1 Quote Share this post Link to post Share on other sites
hybrid 1045 Report post Posted April 6, 2015 Awesome work dude ... keep it up! Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 6, 2015 Cheers fellas, been a busy few weeks. Hoping to have all the body work finished and prepped for paint by the end of the month. Have also decided on the colour, going for the new BMW i8 blue/grey, but a little darker... 1 Quote Share this post Link to post Share on other sites
_ethrty-Andy_ 2153 Report post Posted April 7, 2015 very cool! Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 11, 2015 Finished the left guard and door delete today. Ready for primer, just some final touch ups in the right guard and then the rest sail. 2 Quote Share this post Link to post Share on other sites
francoisv 466 Report post Posted April 12, 2015 Just ordered this yummy set up, www.advancedkeys.com/prod_ak105B.html which mimics the set up from the F30 / F80 etcSo will get that wired up when she gets back from paint Quote Share this post Link to post Share on other sites
Nobimmer 694 Report post Posted April 12, 2015 Nice Quote Share this post Link to post Share on other sites
