_BRS_ 209 Report post Posted March 14, 2016 (edited) After a lengthy wait some more parts have arrived for the V8 Touring from Ergen Motorsport in the UK, some stainless RHD headers, made to fit for this application so no worrying about any custom work or fabrication. Straight bolt on! Along with an in car brake booster relocation kit that is the custom bracket and miniature booster unit, with a 23mm master cylinder that eliminates the booster from the engine bay and rotates it 90 degrees to sit in the glovebox location. Edited October 19, 2017 by _BRS_ 1 Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted March 14, 2016 Man those headers look the business!!!! looks like they are worth every penny. Cant wait to get my booster setup too.....looks like a nice piece of kit 1 Quote Share this post Link to post Share on other sites
e30ftw 433 Report post Posted March 14, 2016 After finally looking at it, I only just thought about how much fun that will be routing brake lines and the vacuum line in to where the booster will be lol, but it does look nice. 1 Quote Share this post Link to post Share on other sites
polley 916 Report post Posted March 14, 2016 On 3/14/2016 at 6:29 AM, e30ftw said: After finally looking at it, I only just thought about how much fun that will be routing brake lines and the vacuum line in to where the booster will be lol, but it does look nice. Could just spend lots of money and run braided lines from the master cylinder, would be easier lol. 1 Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted March 14, 2016 Great build. Is the diff the larger case 210mm one? Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted March 15, 2016 On 3/14/2016 at 9:13 AM, zero said: Great build. Is the diff the larger case 210mm one? Cheers, its a medium case from an e28 with the rear cover changed. Quote Share this post Link to post Share on other sites
polley 916 Report post Posted March 15, 2016 Is that standard steering rack or did you go z3 / e36? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted March 16, 2016 shows in one of his other posts he acquired a z3 rack as part of his conversion Quote Share this post Link to post Share on other sites
polley 916 Report post Posted March 16, 2016 On 3/16/2016 at 12:34 AM, WYZEUP said: shows in one of his other posts he acquired a z3 rack as part of his conversion Sweet, I thought so. Just couldn't find it. Quote Share this post Link to post Share on other sites
nick496 271 Report post Posted March 11, 2017 Any update on this? Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted March 11, 2017 haha a lot since my last update! Will update this in a few months when its nearly road legal. Quote Share this post Link to post Share on other sites
Olaf 3415 Report post Posted March 11, 2017 come on man, we're on the edge of our seats! how's about some words and pictures to tell us about your journey since last time? Quote Share this post Link to post Share on other sites
WYZEUP 283 Report post Posted March 13, 2017 Its been a bit of a bumpy ride aye blair Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted March 14, 2017 On 3/13/2017 at 1:14 AM, WYZEUP said: Its been a bit of a bumpy ride aye blair That it has! Will all be worth it though! Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 28, 2018 About time i updated this! The project is still alive and going well. With some extra help and knowledge needed i decided to send the car up to Kerry at Mosen Euro Parts in Hamilton. First off we wanted to make a clean and tidy removable front rad support to make the engine install and removal as easy as possible, so Jonseys Garage undertook the fabrication work. 1 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 28, 2018 Next came time to test fit the engine with the Garagistic engine mounts and subframe spacers i had purchased for the ease of a bolt in application. I got fellow member will to help out with this side of things. This discovered the kit design to have a few flaws, mainly the angle of the mount to the subframe, the fact that the steering geometry gets messed up by spacing the subframe down 20mm and there is no provision for the oil lines that run through the factory mounting arms and into the block. The decision was made to move on from the kit and custom fabricate some engine mounts and mount them off the chassis rails as will has done in the past, and also allowing the entire front subframe, steering rack and suspension to be removed while the engine can remain in the car. Finished mounts installed, with crush tubes located within the middle of the chassis and gussets to prevent the engine moving forward in a frontal impact, as requested by the certifier upon inspection. This allowed us to locate the engine where we thought was best to give us enough room behind and infront, and as low as possible, and also allowed us to run the factory m62 engine arms with the oil lines running through them and into the block. With the engine sitting so low, we had to notch the sump for clearance of the Z3 steering rack, work was carried out by Aero Machinists & Engineers in Hamilton With that done it was time to move on to mounting the driveline and 6 speed Getrag 420G gearbox and getting the alignment sorted with the driveshaft, an issue that many people run into, this was sorted when the engine mounting position was decided on without having to run and rear diff risers/ spacers in the rear. Im running Revshift 95A hard, street/track mounts throughout sourced from Mike at Euroturbo along with his driveshaft hoops that meet all certification specifications and are designed and made by his business here in NZ. 3 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 28, 2018 (edited) With the engine mounted it was time to focus on the engine bay and the location of the remote oil filter, power steering reservoir and coolant expansion tank, keeping in mind i wanted an uncluttered, smooth and clean bay. Cheers to Kerry for his time, efforts and communication at this point, where he nailed exactly what i had a vision for in this stage. Im running a Mishimoto e36 aluminium radiator, so this was mocked up to check clearances With everything starting to come together, the vision was becoming a reality so it was time for me to prep the bay to keep things moving forward. The messy job of removing all the ugly factory seam sealer for that smooth and shaved bay, filling in holes and getting some flat plate installed was a must for my vision. Jonseys Garage carried out the fabrication of the flat plates and getting the bay sprayed in primer, how good did that white look! Bringing back memories! while the engine was out i couldn't resist getting stuck into cleaning the block up, so with a tooth brush and 3-4 hours later, this was the result Edited May 1, 2018 by _BRS_ 4 Quote Share this post Link to post Share on other sites
Jacko 2296 Report post Posted April 28, 2018 Awesome work! Doing it the right way the first time Quote Share this post Link to post Share on other sites
zero 1162 Report post Posted April 29, 2018 Amazing work on the engine bay! How close does the engine sit in relation to the firewall? Quote Share this post Link to post Share on other sites
musccoo 82 Report post Posted April 29, 2018 looks mint bro, shaved bays for all Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 29, 2018 (edited) To finish off the running gear i stuck with a standard flywheel with the ring gear pressed on and a standard clutch and pressure plate setup, just to keep it easy and cost effective to replace if needed. I decided to revisit my original brake set up plan and came across MRP's kit advertised on trademe so did some emailing and finalised a full kit consisting of: 280mm slotted Zinoelli Rotors front and rear with Dynapro 6piston callipers on the front and 4 piston callipers on the rear with the necessary adaptor plates along with braided lines all round. Custom lines were made to plumb in the brake booster and reservoir now located in the existing glove box location using Ergen Motorsports kit from the UK, which also had to be weld crack tested before fitted. Edited May 22, 2019 by _BRS_ 1 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 29, 2018 In between stages theres always other small things that cannot be overlooked if i want to achieve the vision i have in mind so these jobs weren't missed. Genuine iS front lip and Splitter Blue Cloth Recaro sport seats that i picked up locally for a good deal that will eventually be recovered Rocker covers removed, blasted and powder coated black for that clean and tidy engine bay look Got around to fixing up my headlights, as my car only had one smiley light when purchased. 1 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 29, 2018 (edited) After discovering a set of wheels in 2011 on R3V Limited that i absolutely loved, i knew these had to be added to the Touring, not everyones taste, but i think they will look great on the finished product. 16x8.25 et0 wrapped in Kumho KU31 that i had on my old car and liked the performance of. Test fit Edited April 29, 2018 by _BRS_ Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 30, 2018 Time to throw some colour at the bay! Scott from Scooters Customs in Hamilton did an amazing job, the photos speak for themselves! 4 Quote Share this post Link to post Share on other sites
_BRS_ 209 Report post Posted April 30, 2018 With the previous headers from Ergen Motorsport in the UK not fitting as planned after we changed the mounting configuration, they were onsold and a full set of custom stainless headers and exhaust was completed by Gaz from LDS Fabrication, i went with a 2.5" system with 2 Borla buffers which have the crossovers inside of them, it is a little loud so will see if i have to quieten it down for cert closer to the time. To keep things cool I'm running the Mishimoto e36 Aluminium radiator, cheers to Neil from 41 Automotive for sourcing this for me. I just couldnt resist a quick bolt up to see what the finished product will look like! The small details, like notching the strut tower support for the stainless line from the coolant expansion tank adds to the overall tidiness of the install and Kerrys attention to detail. 2 Quote Share this post Link to post Share on other sites
