LsBeema 469 Report post Posted November 20, 2018 2 Zimbabwean Dollars to the winner... Quote Share this post Link to post Share on other sites
M3AN 4017 Report post Posted November 20, 2018 2 people and gravity! Quote Share this post Link to post Share on other sites
LsBeema 469 Report post Posted November 20, 2018 22 minutes ago, M3AN said: 2 people and gravity! Uhhh...getting there....but na Quote Share this post Link to post Share on other sites
M3AN 4017 Report post Posted November 20, 2018 Damn, I thought that loot was all mine. Quote Share this post Link to post Share on other sites
KwS 2433 Report post Posted November 20, 2018 Depends how bad it is. Vacuum bleeder, followed by two people one bottle (manual bleed) to finish it off. Quote Share this post Link to post Share on other sites
nick496 269 Report post Posted November 20, 2018 I left mine to gravity bleed for 30 minutes into a tray. Then finished it off with a 2 person bleed. This was after replacing master, slave, line. Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 20, 2018 i use gravity 1st , then use a small bottle of fluid that i can squeeze with a rubber hose connected to the bleed nipple and force the air up (which is the way it wants to go) , 2 squeezes and lock off the nipple and you are done. 1 Quote Share this post Link to post Share on other sites
NZ00Z3 190 Report post Posted November 20, 2018 Guess it depends on the model of BMW you are working on. The E36 slave cylinder has a bleed nipple that will not bleed all the air out of the cylinder with it installed. You need to take it off the car, turn it around so the nipple is facing up, open the nipple and push the push rod against the bell housing to force the air out. The official BMW bleed tool compresses the push rod and holds it in while you do a 2 person bleed. Quote Share this post Link to post Share on other sites
Young Thrash Driver 1021 Report post Posted November 20, 2018 None of these ^ methods involves a burnout, so I am skeptical about their effectiveness. 3 Quote Share this post Link to post Share on other sites
BM WORLD 1291 Report post Posted November 20, 2018 1 Quote Share this post Link to post Share on other sites
LsBeema 469 Report post Posted November 27, 2018 Ok...so we need to find a way to split the 0.00814732NZD KwS came close...i did that with the e36 Nick496 also was up there BMworld & NZ00Z3 up soo close. ..did that to my 39 So at the next meet ....we can split the loot... but most goes to Young Trash Driver. Thanks guys. Quote Share this post Link to post Share on other sites
dirtydoogle 383 Report post Posted November 27, 2018 You can just hook a line up from the nearest caliper, open both nipples and pump away on the brakes Easy. Do it all the time in the paddock Quote Share this post Link to post Share on other sites
M3AN 4017 Report post Posted November 27, 2018 I do agree with @Young Thrash Driver but if you can't do it with gravity and two people then you're best to take it to a proper* mechanic. * If you can't tell, I'm quite bitter for missing out on that loot. ? Quote Share this post Link to post Share on other sites
