NZ_InFerno 397 Report post Posted June 10, 2020 3 hours ago, Jacko said: Yeah it can do Yeah I went and did this on the black car, coded and registered within Carly. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 10, 2020 1 hour ago, qube said: You may need to replace the shaft itself 1 hour ago, Gaz said: Seen entrenchment/wear on the eccentric shafts a number of times Would this cause rough idle/running and similar fault codes for valvetronic? Any idea of cost? Digging into the engine is likely beyond my skills. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 10, 2020 1 hour ago, Jacko said: Has the valvetronic motor itself been changed, or were the endpoints just relearnt? Have you tried transposing the valvetronic motor from one 130 to the other and seeing if the fault follows? Yeah, it was a new valvetronic motor and endpoints relearned. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 10, 2020 3 minutes ago, NZ_InFerno said: Would this cause rough idle/running and similar fault codes for valvetronic? Any idea of cost? Digging into the engine is likely beyond my skills. Yes it can do, they wear or rust up due to lack of servicing and too many short trips. New shaft with teflon rings, and recommend levers also replaced. Cost wise, not cheap, cams can be $1000ish and then some plus labour, levers gaskets etc 1 Quote Share this post Link to post Share on other sites
qube 3570 Report post Posted June 10, 2020 1 hour ago, NZ_InFerno said: Would this cause rough idle/running and similar fault codes for valvetronic? Any idea of cost? Digging into the engine is likely beyond my skills. in my N55 engine, worn eccentric shaft and subsequently damaged valvetronic motor resulted in rough idle/running at low rpm but the bigger issue was it would randomly just die/turn engine off while driving. replaced the shaft and motor and it was fixed.. cost.... dont wana talk about it 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 10, 2020 Jesus, what a bloody nightmare. It was running so well! Looking into the hole with the motor removed you could visibly see wear/cupping on the teeth that engage with the motor. Im not sure what "normal" looks like, so not sure if it was excessive. New motor/gasket was fitted and end stops were learned with INPA with no issues. 1 1 Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 10, 2020 4 hours ago, Gaz said: Needs to be registered when replaced with a new one. Coded if you change specs Are you using an obtuse way of saying coding and registering are mutually exclusive or have I misunderstood? Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 10, 2020 (edited) As a bit of a left-field consideration... since you seem to be able to set it and it then goes out over a relatively short period of time... Are you confident the timing chain, guides and tensioners are good? I can imagine a scenario where if the chain were a little bit out of kilter it could (because of the VVT/Valvetronic) pull the timing out of kilter also. Having said that, I'd expect it to get progressively worse to the point of not starting, rather than settle. Edited June 10, 2020 by M3AN 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 10, 2020 1 hour ago, M3AN said: Are you using an obtuse way of saying coding and registering are mutually exclusive or have I misunderstood? On Carly they're two seperate things. You have to code the Ah(amperage?) size then register it to the vehicle. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 10, 2020 1 hour ago, M3AN said: As a bit of a left-field consideration... since you seem to be able to set it and it then goes out over a relatively short period of time... Are you confident the timing chain, guides and tensioners are good? I can imagine a scenario where if the chain were a little bit out of kilter it could (because of the VVT/Valvetronic) pull the timing out of kilter also. Having said that, I'd expect it to get progressively worse to the point of not starting, rather than settle. Yeah I'm reasonably confident they're OK. Pre covid I had it in with the mechanics for this issue and they pulled the front of the engine off and checked the tensioners/guides and chain. Reported those were fine. They changed the eccentric shaft sensor and rocker cover gasket at the same time. It then ran for a couple days before playing up again. Going to ring them tomorrow and see if they remember what the eccentric shaft looked like but like KwS said we could see some marks/wear on the gear inside the engine that the valvetronic motor connects to. Also going to swap coils over if the weather is ok and see what's up with the misfire, as I haven't had that fault previously when a valvetronic error has presented. Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 10, 2020 4 hours ago, Gaz said: Yes it can do, they wear or rust up due to lack of servicing and too many short trips. New shaft with teflon rings, and recommend levers also replaced. Cost wise, not cheap, cams can be $1000ish and then some plus labour, levers gaskets etc Searched the part number and seems like $1.5k just for the eccentric shaft on its own from various parts sites. I'll ring around locally and see what they would price up for the job. Quote Share this post Link to post Share on other sites
B.M.W Ltd 951 Report post Posted June 10, 2020 After reading all this I would conclude that the problem is wear in the back circles of the camshaft lobes, and or wear in the back circle lobes of the eccentric shaft causing the hydraulic lifters to pump up which in turn will not allow the valves to close and seal properly. Had this once on a merc (another horror story) It needs to be diagnosed by someone conversant with the product rather than the local garage. 1 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 10, 2020 11 hours ago, M3AN said: Are you using an obtuse way of saying coding and registering are mutually exclusive or have I misunderstood? No they are two separate procedures. If you replace a like for like battery, no need to code it, assuming it hasn't been mucked around with before Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 10, 2020 1 hour ago, Gaz said: No they are two separate procedures. If you replace a like for like battery, no need to code it, assuming it hasn't been mucked around with before Cool, that's what I thought (and thought I said). Quote Share this post Link to post Share on other sites
Jacko 2355 Report post Posted June 11, 2020 Bloody N52s, unreliable things, should have bought an N54 What a PITA, I agree it might be at the point where the best option is just to grab another good N52 and swap ya new parts on to it (HELLBM definitely has one). If the previous servicing on it has been so bad to cause extreme wear like that, makes ya wonder what else has taken a metal on metal beating. Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 11, 2020 Manual swap the black 2dr 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 11, 2020 2 hours ago, Jacko said: Bloody N52s, unreliable things, should have bought an N54 What a PITA, I agree it might be at the point where the best option is just to grab another good N52 and swap ya new parts on to it (HELLBM definitely has one). If the previous servicing on it has been so bad to cause extreme wear like that, makes ya wonder what else has taken a metal on metal beating. There is an N54 on Facebook marketplace.... I have the service history which is solid so really unsure why its gone so bad. Quote Share this post Link to post Share on other sites
M3AN 4192 Report post Posted June 11, 2020 S65 3 Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 11, 2020 3 hours ago, NZ_InFerno said: There is an N54 on Facebook marketplace.... I have the service history which is solid so really unsure why its gone so bad. It's only a theory at the moment, if lean more to fixing your engine, there's not much else that could go wrong with them after this. Could end up doing all this to the new motor yet 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 11, 2020 3 hours ago, NZ_InFerno said: There is an N54 on Facebook marketplace.... I have the service history which is solid so really unsure why its gone so bad. I dont understand it. The km arent that high, and its had regular servicing. What causes the wear? Surely if it just "wears out" the cars with higher KM would be falling over too and it would be a more common issue that it appears. 1 Quote Share this post Link to post Share on other sites
KwS 2450 Report post Posted June 11, 2020 @NZ_InFerno just as a last ditch check, disconnect the electrical connector from the eccentric shaft sensor on the valve cover and see if there is oil in there. I know its been replaced recently, but worth checking before going down the rabbit hole. 1 Quote Share this post Link to post Share on other sites
Jacko 2355 Report post Posted June 11, 2020 Just saying. https://www.trademe.co.nz/motors/car-parts-accessories/bmw/engines/listing-2652240429.htm 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 11, 2020 1 hour ago, Gaz said: It's only a theory at the moment, if lean more to fixing your engine, there's not much else that could go wrong with them after this. Could end up doing all this to the new motor yet Yeah I was just joshing around with the N54. Its a hard theory to confirm it's the shafts without pulling the rocker cover off afaik. I'm not really sure what I'll do, having put a few grand into it to get it running and it's still not working. Budget has kinda run out, especially for something like eccentric shafts/cam shafts. Cars probably not worth that much if I sell either ? 1 Quote Share this post Link to post Share on other sites
NZ_InFerno 397 Report post Posted June 11, 2020 1 hour ago, KwS said: I dont understand it. The km arent that high, and its had regular servicing. What causes the wear? Surely if it just "wears out" the cars with higher KM would be falling over too and it would be a more common issue that it appears. Yeah idk. The valvetronic motor has been changed previously. When I had it at the euro mechanics they had the rocker cover off so would have thought they would have seen any issues there. 1 hour ago, KwS said: @NZ_InFerno just as a last ditch check, disconnect the electrical connector from the eccentric shaft sensor on the valve cover and see if there is oil in there. I know its been replaced recently, but worth checking before going down the rabbit hole. Yeah will do that, while I investigate the misfire I need to get in there anyway. Quote Share this post Link to post Share on other sites
Gaz 1077 Report post Posted June 11, 2020 1 hour ago, KwS said: I dont understand it. The km arent that high, and its had regular servicing. What causes the wear? Surely if it just "wears out" the cars with higher KM would be falling over too and it would be a more common issue that it appears. They also rust up due to short trips causing them to stick and wear out, or lack of lubrication 9 minutes ago, NZ_InFerno said: Yeah idk. The valvetronic motor has been changed previously. When I had it at the euro mechanics they had the rocker cover off so would have thought they would have seen any issues there. Yeah will do that, while I investigate the misfire I need to get in there anyway. Can't really see the wear unless you pull out the shaft, worst one I've seen was it wore into the head Quote Share this post Link to post Share on other sites
