nzsapper 82 Report post Posted July 16, 2020 (edited) Hi - I know I have been here before but cant find any posts on the topic, basically I have now been backed into a corner and need to get at least two new tyres and my go to Falkens 452/453s are no longer available. So I am now struggling to find a decent replacement and today I was asked if I wanted to go to Bridgestone RE003s in 245/40/17 Can get a Maxis in 235 40 17 but this brand is a total unknown to me Car has style 22s , not staggered Thoughts - 235 vs going 245 Edited July 16, 2020 by nzsapper add content Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted July 16, 2020 Bridgestone RE003s are great tyres, I've seen good reviews of them even in more powerful cars like the 335i. Eagle F1 Asymmetric are probably better so if pricing is similar I'd go for them. Can't go wrong with the Michelin Pilot sport range either. If you want to have fun in your M3 don't get the budget Chinese tyres. Those might be ok in a Toyota Passo, but not in a sports car! Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted July 17, 2020 I have just returned from another tyre dealer and they have said that going to a 245/40/17 will be fine Suggested PS4, Eagle F1s and Z tyre Z1, never heard of the last one , apparently its a UK tyre. http://www.ztyre.com/ Quote Share this post Link to post Share on other sites
Neal 569 Report post Posted July 17, 2020 I had conti sports contacts on the front of my e46 m3 . Size was 225 /45 R18 on a 8 inch front. On the e46 they had the best front steering and great feel. I’ve since run 235 fronts in Bridgestone re11 and Michelin PSS and whilst these have more grip the turn in and feel imho was better with the conti. Worth putting on your list and in 17inch friendly sizes 1 Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted July 18, 2020 You may already know this Paul but in case you don't... Stock e36 square (7.5") setup (3.0) is 4 x 235/40ZR17 Stock e36 staggered (7.5" + 8.5") setup (3.2) is 2 x 225/45ZR17s (front) and 2 x 245/40ZR17s (rear) The maximum recommended tyre width for a 7.5" rim is 235mm but you can stretch 245's on. This means you can open your options up by going for the staggered setup above on square wheels. I would prefer that to a square 245 setup because I would suggest a 245 is too wide at the front for an e36 M3. The other option, since you only need two new tyres is to consider bumping the profile of the 235's up to 45 because there are a lot more 235/45/17 options out there than for 40's. They'll fit just fine but you'll have a taller sidewall. Also, in my very subjective and humble opinion, all RWD sports cars should run a staggered setup. ? Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 18, 2020 I agree completely with William, I tried a 245 on an 8 inch rim and it just felt off. I went staggered and on my E46 with Ohlins suspension and bigger sway bars etc and it worked really well. Just persevere and find decent 235s or go staggered, I agree its not easy. Buy once cry once. Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 18, 2020 Hyperdrive have Yokohama AD08r's and Falken Azensis Rt615k+, both are reasonable tyres if not class leading. Staggered setup solves a lot of problems. Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted July 18, 2020 Thanks everyone for your experiences re this minor issue I have, just to confirm a staggered set up on my 7.5s is all good? so 225/40s front and 245/40s on the rear? Will keep an ear to the ground re some style 39s or maybe I have a look at those style 24s Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 18, 2020 Staggered will require 8.5s at the back. here is a review of the Falken Azensis. https://www.tirerack.com/tires/tires.jsp?tireMake=Falken&tireModel=Azenis+RT615K%2B Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted July 18, 2020 58 minutes ago, 3pedals said: If the suggestion above is 235/45 fronts and 245.45 rears on 7.5 wide rims the science doesn't play out too well Mine? No, it wasn't meant to read that way. IMHO: 245/225 is a viable, if not optimal, setup. 235 square is the alternative, no other combos. Separately, one has more options with 235/45 v's 235/40 these days so worth considering. That's all. ? Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted July 18, 2020 my bad that was meant to read 225 not 235 - I should have proof read before posting Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted July 18, 2020 to be honest, I think you need to look for staggered wheels in order to fit staggered tyres on. I would put 235 40 17 on the wheels you have now (7.5" and drive that as it is, then keep an eye out for a set of staggered wheels then fit the correct 225/45+245/40 combo then. 1 Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted July 18, 2020 2 minutes ago, 3pedals said: Suss out those 24's theye are lightest factory M3 wheel - style 39's are second best but quite a bit stiffer - my wheel of choice on an E36 Have pm'd him re the 24s and will also keep looking some 39s. Quote Share this post Link to post Share on other sites
leichtbau 525 Report post Posted July 18, 2020 (edited) 1 hour ago, 3pedals said: Suss out those 24's theye are lightest factory M3 wheel The cast 24's are lighter than the forged 24's. Not by very much, but enough to make a point of it. Edited July 18, 2020 by leichtbau Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 18, 2020 Style 32s are also reasonably light. Quote Share this post Link to post Share on other sites
GorGasm 563 Report post Posted July 19, 2020 AD08R wouldn't be bad if you want to stay square. Quote Share this post Link to post Share on other sites
nzsapper 82 Report post Posted July 21, 2020 (edited) Cheers all - went with some Goodyear Eagle F1s to say square for now and to be honest there is not much out there at the moment, this UK review of 3 tyres sealed it for me. Granted review was with Skoda but beggars cant be be too fussy , still intend to purchase a set of style 24s or 39s. Oh and the price - $239ea fitted Edited July 21, 2020 by nzsapper 1 Quote Share this post Link to post Share on other sites
M3AN 4148 Report post Posted July 21, 2020 1 hour ago, nzsapper said: Cheers all - went with some Goodyear Eagle F1s to say square for now and to be honest there is not much out there at the moment, this UK review of 3 tyres sealed it for me. Granted review was with Skoda but beggars cant be be too fussy , still intend to purchase a set of style 24s or 39s. Oh and the price - $239ea fitted Good call. I've been running F1's for years on my M3 and have no complaints. 2 Quote Share this post Link to post Share on other sites
Matth5 471 Report post Posted July 21, 2020 They're excellent tyres. Handled great on my modded 335i, and I've properly thrashed them on backroads and the track. I liked them more than the PS4 on that car. PS4 had more ultimate grip but it just seemed to 'snap' when it lost grip in the wet, while the Goodyears always had a nice smooth transition that was easily controllable. Even the traction control would cut out harshly with the PS4, but was able to smoothly modulate power on the Goodyears. Might just be that the slightly wider than stock PS4 wasn't a good match for that car as they generally have excellent reviews. Got the stock MPSS on my M4 and not sure how I feel about them so far, they felt a bit 'snappy' in some situations but part of that could be the car and me still getting a feel for it... 2 Quote Share this post Link to post Share on other sites
Herbmiester 947 Report post Posted July 26, 2020 On 7/22/2020 at 8:32 PM, 3pedals said: Interesting comments in the video about 'the car' 'a volkswagen in a dress with slammy suspension' . Tyres are part of the suspension system and matching tyre choice to suspension set up and car balance is generally overlooked. A slammy, hard sprung car that loads up the front tyres needs a very firm tyre case and solid shoulder , does he bother to mention the load ratings of the tyres - were they all the same ? in 18 ich sizes PS4's are 91/92 and Conti are 95 /97 so the latter will perform better on a FWD Having driven one its not that firm, no firmer than say a an 90 Msport car. Quote Share this post Link to post Share on other sites
