HalfJobHarry 106 Report post Posted September 8, 2020 So I'm starting to plan short/medium term upgrades for my 135i. Suspension changes is not something I have much experience with beyond swapping like for like.... I'm not interested in lowering really from the current ride height, seems low enough already really....this seems to be one of the mainly described benefits of going for coilovers (I appreciate they will need certification). However with that in mind and there being plenty of good aftermarket shock and spring combos (or even plenty of love out there for Bilsteins with the stock springs), do I even need/want coilovers? Any experiences, advice or war stories are much appreciated. Quote Share this post Link to post Share on other sites
Navin 180 Report post Posted September 8, 2020 If I had kept mine longer this was the next thing I would've invested in. Did a bit of research on it over the years and I came to the conclusion that the Bilstein B8/eibach springs combo was the most ideal. I don't believe the drop is too significant and the Eibachs seemed to have a smaller drop than the H&R's from memory. The factory E82 M-sport suspension just doesn't suit our roads at all. 2 Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 8, 2020 Suspension dynamics are complex, unless you're prepared to learn all about it, and have the ability to undertake back-to-back assessments at a track then coilovers are a waste of money, most people set-and-forget and if you're going to do that then you'll get a better result from an off-the-shelf combo. Assuming the E82 is as horrible as the E87 off the production line then read up here: https://www.babybmw.net/forum/viewtopic.php?t=80208 https://www.babybmw.net/viewtopic.php?f=20&t=126836 TLDR; a matched Bilstein and Eibach setup works well off-the-shelf. Quote Share this post Link to post Share on other sites
Eagle 1778 Report post Posted September 8, 2020 (edited) Id wager most put them on for ride height adjustment\stance. They obviously don't care too much about handling because most of these cars with them fitted (esp Jap stuff) are typically on some sh*t spec rubber. Edited September 8, 2020 by Eagle 2 Quote Share this post Link to post Share on other sites
qube 3571 Report post Posted September 8, 2020 biggest upgrade you can do would be to install an LSD, transfers all that power into actual usable power 1 Quote Share this post Link to post Share on other sites
andrewm 236 Report post Posted September 8, 2020 Ive done it to various cars with different brands (KW, fortune auto, bilstein) and usually regretted it, never used the super cheap junk especially after seeing some shock dynos. If you go for camber plates then you need bearings or it will bind and your car with groan and clunk all over the place. If you go bearings and camber plates then you wont have a rubber strut mount and you will feel tiny imperfections all day long. Then the cert is a pain +$4-500 and then you are fixed to a width and size of wheel permanently, you cant even return to OEM without re certifying for another $4-500. If you have $4k+ spare and are fitting kw v3 or anything better(ohlins) then go for it, if you are wanting anything less then dont bother. Quote Share this post Link to post Share on other sites
m325i 732 Report post Posted September 8, 2020 7 minutes ago, qube said: biggest upgrade you can do would be to install an LSD, transfers all that power into actual usable power If you've got the budget - that would be a big upgrade. And you would get a massive portion back if you ever sold it separately. 4 minutes ago, andrewm said: Then the cert is a pain +$4-500 and then you are fixed to a width and size of wheel permanently, you cant even return to OEM without re certifying for another $4-500. Beat me to it. That is what really kills the idea of coil overs in NZ. Different chassis, but I got Koni 'yellows' recently and am very happy. Post pics 1 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 10, 2020 On 9/8/2020 at 7:01 PM, andrewm said: Ive done it to various cars with different brands (KW, fortune auto, bilstein) and usually regretted it, never used the super cheap junk especially after seeing some shock dynos. If you go for camber plates then you need bearings or it will bind and your car with groan and clunk all over the place. If you go bearings and camber plates then you wont have a rubber strut mount and you will feel tiny imperfections all day long. Then the cert is a pain +$4-500 and then you are fixed to a width and size of wheel permanently, you cant even return to OEM without re certifying for another $4-500. If you have $4k+ spare and are fitting kw v3 or anything better(ohlins) then go for it, if you are wanting anything less then dont bother. Thanks! Based on the input from everybody on the thread, coilovers seems to be a step too far. I'll look at shock/spring combos. On the camber plate thing. The 'sages out there' seem to suggest that putting the E82 front to about -2 degree of camber is a big help on understeer. Just changing the camber plates is touted (again by the sages 'out there on the web') as the way to do this. In the non-coilover scenario i'd also need bearings? Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 10, 2020 On 9/8/2020 at 5:19 PM, M3AN said: Suspension dynamics are complex, unless you're prepared to learn all about it, and have the ability to undertake back-to-back assessments at a track then coilovers are a waste of money, most people set-and-forget and if you're going to do that then you'll get a better result from an off-the-shelf combo. Assuming the E82 is as horrible as the E87 off the production line then read up here: https://www.babybmw.net/forum/viewtopic.php?t=80208 https://www.babybmw.net/viewtopic.php?f=20&t=126836 TLDR; a matched Bilstein and Eibach setup works well off-the-shelf. Thanks! I wouldn't say it's bad at all really, but there is clearly room for improvement. My shocks are old and to me the damping doesn't feel great (a commonly reported E82 complaint). I mean relatively not great...not Renault Espace 'not great' Suspension is so far out of my wheelhouse , I really don't want to become an expert on it. A known recipe of shocks and springs is probably the way I'll go. Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted September 10, 2020 1 hour ago, HalfJobHarry said: Thanks! Based on the input from everybody on the thread, coilovers seems to be a step too far. I'll look at shock/spring combos. On the camber plate thing. The 'sages out there' seem to suggest that putting the E82 front to about -2 degree of camber is a big help on understeer. Just changing the camber plates is touted (again by the sages 'out there on the web') as the way to do this. In the non-coilover scenario i'd also need bearings? I've just purchased an E82 and have been looking into this aswell. You can buy Dinan fixed camber plates that give about 0.7 of a degree extra camber and keep the original BMW top mount. When the alignment pin is removed this should get close to the magical two degrees. 1 Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 10, 2020 1 hour ago, HalfJobHarry said: On the camber plate thing. The 'sages out there' seem to suggest that putting the E82 front to about -2 degree of camber is a big help on understeer. Just changing the camber plates is touted (again by the sages 'out there on the web') as the way to do this. In the non-coilover scenario i'd also need bearings? Camber plates officially need a cert but if you get fixed ones nobody can tell. M3 LCA's will also help increase the camber. 3 minutes ago, c.robertson00 said: I've just purchased an E82 and have been looking into this aswell. You can buy Dinan fixed camber plates that give about 0.7 of a degree extra camber and keep the original BMW top mount. When the alignment pin is removed this should get close to the magical two degrees. Yes, remove the camber pin first, then I'd say add M3 arms and finally camber plates. I'm sure the Dinan ones are hella expensive but you can get some from the UK for peanuts. I'll check my alignment sheet when I get home, I've removed the camber pin and added M3 LCA's, I think I've got about 1.5 degrees max. 1 Quote Share this post Link to post Share on other sites
c.robertson00 11 Report post Posted September 10, 2020 1 minute ago, M3AN said: Camber plates officially need a cert but if you get fixed ones nobody can tell. M3 LCA's will also help increase the camber. Yes, remove the camber pin first, then I'd say add M3 arms and finally camber plates. I'm sure the Dinan ones are hella expensive but you can get some from the UK for peanuts. I'll check my alignment sheet when I get home, I've removed the camber pin and added M3 LCA's, I think I've got about 1.5 degrees max. The plates are about $250 landed. That's through Turner Motorsport. Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 10, 2020 1 minute ago, M3AN said: Camber plates officially need a cert but if you get fixed ones nobody can tell. M3 LCA's will also help increase the camber. Yeah I've been eyeing the turner motorsports blue fixed camber plates, spraying them to make them not stand out and then who'll know....still got a fair bit of reading to do to really understand this. 1 minute ago, M3AN said: Yes, remove the camber pin first, then I'd say add M3 arms and finally camber plates. I'm sure the Dinan ones are hella expensive but you can get some from the UK for peanuts. I'll check my alignment sheet when I get home, I've removed the camber pin and added M3 LCA's, I think I've got about 1.5 degrees max. Ah...camber pins, good ideal. Some "free negative" adjustment there. Any idea how much negative just the pins would get..less than half a degree? Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 10, 2020 (edited) Yes, less than half a degree. I've just checked my alignment sheet, camber pin mod + M3 front arms = 1*34' so 1.5 degrees 1*12' (was reading the wrong column!). FYI: https://babybmw.net/forum/viewtopic.php?f=20&t=96465 Edited September 10, 2020 by M3AN 1 Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 10, 2020 (edited) 1 hour ago, M3AN said: Yes, less than half a degree. I've just checked my alignment sheet, camber pin mod + M3 front arms = 1*34' so 1.5 degrees 1*12' (was reading the wrong column!). FYI: https://babybmw.net/forum/viewtopic.php?f=20&t=96465 Thanks that's a good thread. Somebody from NZ asking for a set at the beginning of August....wish I could have piggy backed on that! Edited September 10, 2020 by HalfJobHarry spelling Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 10, 2020 1 hour ago, 3pedals said: ith running so much static negative camber on the front - the chassis runs decent caster and develops dynamic camber when turned so high static is not necessary and the roll centres are quite low so the body roll is minor unless you are a stomp-chuck-stomp style driver . That's interesting actually...I'm just following the herd without the suspension knowledge myself. I do know enough to know that camber changes due to many things, so it makes sense that -2 degrees static camber might not be the "magic number". Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 10, 2020 1 hour ago, HalfJobHarry said: Thanks that's a good thread. Somebody from NZ asking for a set at the beginning of August....wish I could have piggy backed on that! If you decide to get some I'll get a set as well (stage 1) so we could split the shipping. -2* camber up front is no problem, there's no disadvantage so it's sort of a "why not?" equation. 1 Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 10, 2020 My point being that -2* is nothing, it won't adversely affect you in any way unless you're running around with the wrong pressures. All the things you mention need to be considered once you start winding in excessive camber, 2 degrees isn't excessive. Quote Share this post Link to post Share on other sites
HalfJobHarry 106 Report post Posted September 11, 2020 16 hours ago, M3AN said: If you decide to get some I'll get a set as well (stage 1) so we could split the shipping. -2* camber up front is no problem, there's no disadvantage so it's sort of a "why not?" equation. I need to signup over on that forum and ask how much they are even selling the stage 1 for. Totally up for splitting the shipping if they are selling at a fair price. Quote Share this post Link to post Share on other sites
GorGasm 563 Report post Posted September 11, 2020 On the topic of adjustable coilovers, I had 2 sets on my some of my Subaru Legacy's and they were AMAZING. The Legacy already handles as well as most BMWs anyway but the adjustable suspension improved both the handling and the comfort. Around town was firm but not jarring and on the open road at 100 literally everything was soaked up, it was SO much better. These particular units were a niche Subaru specialist brand called Prova though and had nothing more than a basic install and alignment done. Height was maybe a little lower than factory but not much. On the same note I had Ohlins coupled with Swift springs in one Legacy and they were so hard that they were dangerous, no traction at all and braking distance was terrible as it would skip over the ground. I'm not sure what the likes of BC and KW are like in BMW offerings but when I looked at M5 suspension they consensus was that KW was much better than stock. YMMV as always but I suspect a KW setup would do a decent job of things. Certainly my experience has shown that BMW do a pretty average job of suspending their cars, probably cheap $$ targets, cheap components and a weird desire to have adjustable suspension modes from comfort to sport. 1 Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 11, 2020 1 hour ago, HalfJobHarry said: I need to signup over on that forum and ask how much they are even selling the stage 1 for. Totally up for splitting the shipping if they are selling at a fair price. I'll send him a PM over there and ask. 1 Quote Share this post Link to post Share on other sites
M3AN 4175 Report post Posted September 11, 2020 We're talking about an E82 William, don't wander away from the context. I'd be surprised if any BMW has 9 or 10 degrees caster, the 1 series, and E82 in particular certainly does not. Your theory is probably right (I'm not one to judge) but it has no practical application in this case. -2 degrees front camber in an E82 has absolutely no disadvantages, it's not even a trade-off. 1 Quote Share this post Link to post Share on other sites
GorGasm 563 Report post Posted September 12, 2020 In my mind front end camber would directly affect braking performance? Quote Share this post Link to post Share on other sites
